RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   LARGEST Engine Available?? (https://www.rcuniverse.com/forum/gas-engines-142/8621494-largest-engine-available.html)
sparg93 03-27-2009 09:26 AM
Subject says it all, what is the largest engine available for remote controlled planes with out actually buying a plane engine... which i know a few have thought of :)
Any links or photos??
wjvail 03-27-2009 09:40 AM
RE: LARGEST Engine Available??
1 Attachment(s)
I don't believe there are very many gaps in power plant sizes beginning with CO2 motors and Cox .010ci through 36 cylinder turbo charged WWII engines. Where Satio and OS leave off, 3W takes over. Where 3W ends, Rotax fills in... and on it goes. There may be some thin spots in the power plant size-line but I'd guess there are very few if any gaps.
3W's largest... http://www.3w-modellmotoren.com/engl...r404.html~main
Rotax's smallest... http://www.rotax.com/en/Engine/2004/...ine.Models.htm
Bill
sparg93 03-27-2009 09:55 AM
wow - that is a big motor.
I looked through their engines and 3W has one for ~9k (eur) that has enough HP to probably fly a small plane with a person in it....
arobatx 03-27-2009 03:33 PM
Do a little googling on the Cri-Cri you'll find some very interesting twin engine home builts, if you want to see what appear very similar to our hobby engines flying a small manned craft. These certainly aren't all that large, but thought you might enjoy.
Here you go: http://www.youtube.com/watch?v=TDmnjwbJrVM
sparg93 03-27-2009 04:10 PM
i was absolutely astonished that thing could climb vertically that fast and bank that hard....
Tired Old Man 03-27-2009 08:36 PM
A Ford V-6 comes to mind for some rpv stuff.
Marcol 03-28-2009 03:50 PM
ORIGINAL: wjvail
Bill
Hi Bill,
The largest number of cylinders I could think off was in the P&W R4360 radial . This had 28 cylinders.
Do you have a link for the 36 cylinder engine ? The reason I ask is that I have been compiling various documents on operational WW II aircraft engines and it would be good to add some more info.
All the best
Colin
oldtimer2 04-19-2009 01:12 PM
Go to google and type 36 cylinder aircraft engine, There are a couple of articles about the engine.
liquid_TR 04-19-2009 02:45 PM
this is one beautiful engine... Moki 400cc Radial.. fantastic sound..
http://www.troybuiltmodels.com/ns/im...0r/rcs400r.jpg
Displacement 400cc
Power 25hp
RPM Range 500-3800
Weight 20.3 lbs - (includes ignition)
Fuel/Ratio Premium Gas mixed 30:1 synthetic only
Ignition 4.8v-6v Microprocessor Auto Advance
Prop Size MSC 40x18
Dimensions 13.75" Diameter - 10.24" from backplate to prop hub
blw 04-19-2009 03:55 PM
I've seen the 250cc run, and it is really nice. Nice gas 4 strokes.
