RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   What engine is this? (https://www.rcuniverse.com/forum/gas-engines-142/8744173-what-engine.html)
tenacious101010 05-05-2009 08:48 PM
1 Attachment(s)
I have a gas engine that I believe is a Quadra 42, but not sure. It has two rings. Dont know much more about it.
Thanks, Denny
buck1856 05-05-2009 10:00 PM
RE: What engine is this?
I have 3 quadra 35s,a 42,and a 55 and they dont look like that.
It is either larger than a 55cc wich they have the carb positioned like that or its a Roper saw motor.
Or its a different year than my Quadras.
Truckracer 05-05-2009 11:33 PM
ORIGINAL: tenacious101010
Thanks, Denny
Q65 or Q75
buck1856 05-06-2009 12:02 AM
Thats what i thought.I figured it was bigger than a 55,and i knew quadra had a 75,but i couldnt remember what was in between.
Didnt want to insert foot in mouth being wrong.
the Wasp 05-06-2009 01:50 AM
you see the round hole on the side of the case in the back, I have no idea what engine it is :D
tenacious101010 05-06-2009 04:47 AM
Thanks for the help guys, I just saw there is a number scribed on the crankcase, 7656 , could 76 be the year of manufacture? What is the black button just ahead of the spark plug for?
Thanks, Denny
mogman 05-06-2009 08:30 AM
[quote]ORIGINAL: tenacious101010
Thanks, Denny
Compression release... push it down, start the motor and compression pops the release back up.
Cheers, Dave.
Truckracer 05-06-2009 08:38 AM
ORIGINAL: the Wasp
Those cases that were round on the back (with hole) were special, made for RC cases. Most of these engines had a spring starter in that rear housing. These were very long lived engines, had good power and are well mannered. Only thing I can say bad about them is that they shake a bit but not excessive by any means. These seem quite happy on 24-10 props. My guess is that engine is a 75 as there seemed to be far more 75s out there than 65s. These make great warbird engines.
