RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   correct prop bolt size BME115 (https://www.rcuniverse.com/forum/gas-engines-142/8958987-correct-prop-bolt-size-bme115.html)
hutchi 07-23-2009 08:02 PM
what is the correct size of the prop bolts on a BME 115 10/32 or M-5 I'm switching to a Vess an need to increase the length
LanceLKs 07-23-2009 08:20 PM
RE: correct prop bolt size BME115
How old is it? The new BME's use 10/32 . If its more than 1 1/2 years old is probably a 5mm
Tired Old Man 07-24-2009 10:12 AM
They are all 10-32.
Bear in mind that the 10-32 screws are not the primary clamp fasteners for the propeller. The center nut is what is used to provide the propeller clamping force. The outer 10-32 screws are more for indexing and anti rotation pins. You only need to use two of them. Using only the outer screws to retain the prop on a 115/116 will cause propeller and/or hub failure.
hutchi 07-24-2009 04:30 PM
thank you, I do use the center nut T O M
