Spark plug wire
I am looking for somewhere l can order a new sparkplug wire and cap for my sachs 3.2 using CH ignition. Anyone know of a place on the web that mail orders. Don't need the whole ignition, just the parts.
Thanks |
Spark plug wire
Just use an old lawnmower wire or a car wire, I had one that got chopped up pretty bad on a fiberglass cowl, I removed it from the coil & replaced it with an old lawnmower wire & slipped the braided ground wire over it, screwed the wire to the ignition box & screwed it to a fin on the engine. I used some silicone when I inserted it in the coil & I shaved the wire off the tip about 1/8", It ran great. If you don't like that Idea go to chignitions.com they should have what you need.
Gil |
Spark plug wire
I want to order a new wire and Bosch Cap for my 3.2 as well.... I was going to order them through CH..........
Order me up a set and I'll go halfers on the shipping with ya..... |
Spark plug wire
Hi Flight RC has the Bosch Cap and wire listed as in stock.....
GEAHF2057 BOSCH CAP C/W RESISTOR LEAD part# 77026 They are a supplier in Alberta. Any one of the LHS could order from them....... I will be asking my LHS to look into one for me to.... :D hope it works out for us! |
Spark plug wire
Try Triad Aviation in Ponoka, Alberta.
1-888-783-3912 They can supply all kinds of R/C stuff including gasser parts. John |
Spark plug wire
Thanks guys.
I did not know Hi Flight had the stuff. I am in Cold Lake, 3 hours east of Edmonton (Hi Flights home). Unfourtunatly, our LHS closed up shop so l will have to mail order it from Edmonton. Better than a kick in the head. Cheers |
| All times are GMT -8. The time now is 11:57 PM. |
