RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Help with engine ID (https://www.rcuniverse.com/forum/gas-engines-142/9032158-help-engine-id.html)
JWHITACRE 08-20-2009 07:36 PM
Help with engine ID
1 Attachment(s)
Ok guys, I picked up this engine in a trade(It was bolted to a Nosen 1/4 scale Citabria) and want to know what make/size it is. It appears to be a weedie or chainsaw conversion. The one thing I have discovered is it has a Walbro hda 23b carb but other than that I am at a loss. Thanks in advance.
51-D GUY 08-20-2009 08:55 PM
RE: Help with engine ID
Hello , The looks like a sachs
by looking at the Cylinder / crankcase
Not sure of the size ,
is it for sale ?
tkg 08-20-2009 09:22 PM
It looks like an old T&G conversion. TCSA and a basic ignition. The bolt pattern on the prop hub is an oddball one so you stuck with a six bolt prop. Measure the bore in MM and we could tell you what size.
JWHITACRE 08-20-2009 10:02 PM
I just measured and the bore is 44mm. 51-D Guy, I'm not really planning on selling it at the moment(mainly because I haven't even fired it up to see if it runs) but if I do, I will let you know.
Antique 08-20-2009 10:46 PM
3.2 Sachs, factory crankcase....
51-D GUY 08-21-2009 08:48 AM
Thank's JWhitacre,
Sound's good
51-D GUY.
