Walbro Membrane Pump
I did a search and couldnt find what i was looking for, i even went t the DL distributor that i know of ValleyView RC, didnt bother with DLUSA since i heard they were closing down.
I would like to order a carb kit for my DL50 since it is over2.5 years old, or atleast the diaphragm membrane pump, where can i order one? |
RE: Walbro Membrane Pump
Walbro WT-899 Get the kit at your local chain saw repair store
<table cellspacing="1" cellpadding="3" border="0" class="background"> <tbody> <tr> <td class="menudetail">D10-WAT</td> <td class="menudetail">Gasket/Diaphragm Kit</td> <td align="right" class="menudetail"><font color="red"> <font color="red">$4.94</font></font></td> </tr> </tbody></table> |
ORIGINAL: w8ye Enter the model number of your carb on the top right if it is a Walbro. If it is not a Walbro, then get one http://wem.walbro.com/walbro/family.asp You can find all the parts for a Walbro Example below <form name=''frmPartNumber'' action=''/walbro/partnumbersearch.asp''> <nobr>Search by Walbro Part # </nobr></form><input type=''text'' class=''smalloptionbox'' name=''ItemNumber'' size=''14'' /> <input type=''submit'' class=''smalloptionbox'' value=''Go!'' id=''submit1'' name=''submit1'' /> thanks W8ye! the only number i could find was on the throttle stop arm # 266 i tried entering it, nothing happened |
I changed my post
All the WT and WA carbs use the same repair kit if that is what yours is |
D10-WAT or D20-WAT
They both have about the same things in them. Very little difference. Both work. |
i found it its WT 741 i had to brush off the carb a bit ....its finely stamped into the carb
You didn't call me or I would have given you the part numbers for the repair kit. You don't need to take the carb off to find the model number, it's right next to nipple you connect your fuel line to.
ok, PM sent Jody
| All times are GMT -8. The time now is 10:23 AM. |
