RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   RADIAL ENGINE (https://www.rcuniverse.com/forum/gas-engines-142/9220974-radial-engine.html)
wingstrut 11-01-2009 07:21 PM
RADIAL ENGINE
FELLOW AIRCRAFT LOVERS, I AM LOOKING FOR A RADIAL ENGINE TO POWER MY BUSA SOPWITH PUP WHICH HAS A 9 INCH COWL.
I AM LOOKING FOR A FOUR CYCLE GASOLINE POWERED RADIAL. I HAVE NOT FOUND ONE YET, DOES ANYONE KNOW OF A MANUFACTURER THAT PRODUCES ONE.
THANK YOU,.... YOUR TIME AND HELP IS GREATLY APPRECIATED.
w8ye 11-01-2009 08:12 PM
RE: RADIAL ENGINE
of the gas radials this is the smallest one and it is too big for your application
http://www.troybuiltmodels.com/items/RCS150R.html
SoCalSal 11-02-2009 10:36 AM
RE: RADIAL ENGINE
Check out a place called "Brown Bear" engines in the Netherlands. He makes some smaller radials...85cc and up I think.
http://www.brownbearmotors.nl/?lang=en
wingstrut 11-21-2009 06:17 PM
RE: RADIAL ENGINE
Thanks, SoCalSal, I believe this radial will just fit..........I will check it out, Thanks again.............Wingstrut
karolh 11-21-2009 08:37 PM
RE: RADIAL ENGINE
Those Brown Bear radials are glow powered.
Karol
w8ye 11-21-2009 09:12 PM
RE: RADIAL ENGINE
Engines are provided with ring exhaust and OS-F glowplugs.
All aluminium parts are anodized.
Fuel: Methanol, incl. 6 to 7 percent synthetic oil, 2 to 5 percent nitro.
wingstrut 11-23-2009 07:14 PM
RE: RADIAL ENGINE
Thanks, w8ye I think I'll wait and build a 1/3 scale then I won't have a problem with engines.
Thank you guys for the info and help.
For now I'll enjoy the 1/4 scale with a one lunger.
