prop mounting
I have been told that if the prop is mounted at 90 degrees from the piston at top dead center it will reduce vibration is that true?
RE: prop mounting
It depends.
Try it and see what you think? There are a lot of variables |
| All times are GMT -8. The time now is 08:47 AM. |
