RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   CH Electronics Syncro Spark Temperature Tolerance (https://www.rcuniverse.com/forum/gas-engines-142/970450-ch-electronics-syncro-spark-temperature-tolerance.html)
tkg 07-18-2003 06:12 PM
CH has discovered a possible temperature sensitivity problem in the Syncro Spark timing board. One of the electronic parts on the board may not meet its design temperature specification
The symptoms are the ignition will start to fail when it gets hot. The engine will restart when the ignition cools off, but will stop when it heats back up.
We have determined that the affected ignitions are part of a particular production run. This run affects ignitions sold between Sept 2002 and June 2003. CH ignitions should be marked on the back side with a month and year made. Example SS OK 01/03 BC
Even though most of these ignitions are out of warranty CH will replace the Syncro Spark board in these units. The ignitions will be repaired and returned at no charge. Contact CH Electronics for details.
We at CH Electronics are sorry for any inconvenience this causes, but these repairs must be done to ensure that all of these units will meet CH Electronics standards.
This does not apply to non Syncro Spark units for engines with mechanical spark timing
CH Electronics 3420 Chandelle Blvd Riverton WY. 82501
M-F 10am - 5PM mountain time 307 857 6897
ritchie_rich 07-18-2003 11:58 PM
syncro spark
tkg, just received a ignition module yesterday that you folks repaired under warranty for me. Loved your tuner around repairs
it was really quick.
My question is is the ignition supposed to discharge to the spark plug when the kill switch is turned on because mine dose now and it didn't before. I have only one run one this module. It still discharges when you turn prop over.
Wondering if something is going bad again already?
Thanks again
Richard Barch
Tim_Indy 07-19-2003 12:05 AM
Richie, think it's all right, because thast's how I check mine, turn on the ignition and look to see the spark.
Eagle Flyer 07-20-2003 01:21 AM
Got to admire these guys service. not every company would go out like this to insure their product is up to par.!!!!!! :)
BigBird1 07-20-2003 04:26 AM
Just the module heating up or does it have something to do with the air temperature also like in the high 80's and 90's
I've got two in that time you posted, but haven't had any problems with them.
Michael
Ed Vollmer 07-20-2003 05:44 PM
Just the module heating up or does it have something to do with the air temperature also like in the high 80's and 90's.
Michael
It has to do with ambient temperature. Some of the ceramic resonators in that particular production run do not meet the minimum temperature specification of 182 (f) degrees. When the resonator goes funky, the processor shuts down and stops passing on the pulse signal to the ignition. Ergo, no sparky, no noise out of the exhaust.
If you, or anyone, has a CH Ignitions Syncro Spark unit built in the time frame that tkg noted, it is best to send it in to be checked. Better now than after a dead stick landing on a hot day.
Ed Vollmer
M-E Technical, LLP
BigBird1 07-20-2003 06:03 PM
That be true...
Ya gotta admit...that was awful nice of the to do the recall.
Volfy 07-21-2003 01:03 PM
This is why I like doing business with these guys. A lesser company would quietly fix the units customers send in complaining of deadsticks, while they publicly deny having a problem at all.
ram3500-RCU 08-02-2003 05:32 PM
This week my f.p.e. 3.2 with CH syncro spark quit for the first time. I went vertical after take off ( do this all the time ) got 80 to 100 ft before it suddenly quit with no warning. Just last weekend i read the posts about some problems your having but my unit falls out of your target dates. It is dated 04/02. Could the problem go back that far or do i look elsewhere for the cause? I purchased the engine last fall, built over the winter and have been flying it this season with about 7 gal. through it so far. By the way, the plane (waggstaff 300 ) did a nice tail slide, fell past the vertical down line buy about 20 deg. to the inverted side and i couldn't get enough speed to pull out into a glide or flare. Came in very hard on the gear and snapped the whole nose off. Didn't even crack the cowl though. Wish i'd just pulled out inverted and rolled over. O well.
tkg 08-02-2003 07:41 PM
Follow the trouble shooting guide. Check for pluse switch, ignition switch, battery, broken wire type stuff.
The "problem ignitions" start running ratty, then will not restart.
ram3500-RCU 08-02-2003 07:52 PM
Roger that tkg. Everything checked but battery voltage was 4.81 under a 250ma load and falling. Its a 1400ma pack. Would this voltage stop the box?
tkg 08-03-2003 02:47 AM
Not good. The ignition will draw about 400ma. So that v will be even lower when the engine is running.
Can you cycle it from this point and see how much juice was left.
dirtybird 08-03-2003 03:05 PM
Ignition stopping
Is there a way to cut out the ignition without cutting the supply voltage to the unit?
For reliability purposes I don't like running the supply voltage thru a switch
tkg 08-03-2003 06:40 PM
Ya gotta to have a switch between the ignition and battery. Even with the engine off the ignition is drawing 30-50ma. So you need to turn the ignition OFF
claysmith 08-04-2003 03:39 PM
The ignition on my BME 50 is dated 04-03. Should I send it in even though it hasn't given me any problems yet? How long does it take to fix it?
tkg 08-05-2003 01:37 AM
ON one hand is the cost of postage and a lost weekend of flying, on the other hand is the cost of a lost airplane. Your call
We normally get in one day out the next on this warranty action.
If you are willing to call and remove the back I can tell you what to look for to see if you have one of the units that need to be recalled.
Tapio 08-05-2003 01:45 AM
I second the exceptional speed of service, thank you tkg! Now my BME 102 is running great.
claysmith 08-05-2003 02:13 AM
I'll call tomorrow after I get the ignition off the plane.
Scott Claboe 10-03-2003 10:13 PM
RE: CH Electronics Syncro Spark Temperature Tolerance
I have one that went bad.Luckily it just stopped working on the ground.Use another ch that someone had at the field in my plane and it fired right up.So that being said I'm sure these recall ignitions will fail.Not if but when.So send them in.I have a lot of money in my plane.So I'm not risking it!!!
kenair 10-10-2003 03:31 PM
Does the recall apply to the syncro spark module that is a separate unit, and it plugged in line with an ignition module, I have one sealed in blue heat skrink.
--thanks - ken kalynuk, winnipeg, canada
tkg 10-10-2003 07:26 PM
Kenair
YES if it was purchesed between the dates in the first post.
rcpilotjae-RCU 10-11-2003 05:33 PM
I will third that! I sent in my CH ignition to be upgraded and the turn around was less than two weeks. Most of that time was spent in the mail going back and forth. I highly recommend CH Ignitions to anyone & everyone. Quality & Honesty keeps happy costumers coming back for more with new customers.
gasguzzler 08-30-2004 08:03 PM
More bad ignitions than the dates posted. One on a 3.2 FPE 050704, one on my H9 Sukhoi 5.8 FPE 050904 and one more on a Zenoha conversion 050604. Mine just failed today and the is no way it was heat related. 71 degrees outside and the engine would just not start. Grounded the white wire going into the ignition still no spark. Will be sending it in for warrenty. The other two planes landed deadstick.
