Electronic ignition problem
I have a zenoah 445 with a conversion done by RC IGNITION. The first ignition failed quickly and was replaced at no charge by Ralph. I'm now getting back to the plane (Smith Mini-plane bipe) scaled to 33%. The initial ignition caused an awful lot of RF, causing the radio to go spaz. With the 2nd ignition, the wires were shielded to minimize this problem.
Started this motor today and the radio went wacko, not being able to control any surface. Shut off the transmitter and ran the motor using manual throttle. The wires to the plugs were "HOT", and reaching for the throttle arm resulted in a fairly perky shock!!! If anyone has any advice that will help me eliminate this RF feedback please feel free to jump in. I have moved all batteries far from the engine, no metal linkage goes from the engine compartment to the internal fuselage The ignition battery is close to the reciever, don't know if this could cause a problem... HELP...This is a sport plane and I would like to get it into the air... |
RE: Electronic ignition problem
ORIGINAL: Mrtazmaned [font=''Verdana''][/font][font=''Verdana'']I have a zenoah 445 with a conversion done by RC IGNITION. The first ignition failed quickly and was replaced at no charge by Ralph. I'm now getting back to the plane (Smith Mini-plane bipe) scaled to 33%. The initial ignition caused an awful lot of RF, causing the radio to go spaz. With the 2nd ignition, the wires were shielded to minimize this problem. Started this motor today and the radio went wacko, not being able to control any surface. Shut off the transmitter and ran the motor using manual throttle. The wires to the plugs were ''HOT'', and reaching for the throttle arm resulted in a fairly perky shock!!! If anyone has any advice that will help me eliminate this RF feedback please feel free to jump in. I have moved all batteries far from the engine, no metal linkage goes from the engine compartment to the internal fuselage The ignition battery is close to the reciever, don't know if this could cause a problem... HELP...This is a sport plane and I would like to get it into the air...[/font] |
Send it back, I will re convert it to mag ignition and refund your cost....
ORIGINAL: Mrtazmaned [font=''Verdana''][/font][font=''Verdana'']I have a zenoah 445 with a conversion done by RC IGNITION. The first ignition failed quickly and was replaced at no charge by Ralph. I'm now getting back to the plane (Smith Mini-plane bipe) scaled to 33%. The initial ignition caused an awful lot of RF, causing the radio to go spaz. With the 2nd ignition, the wires were shielded to minimize this problem. Started this motor today and the radio went wacko, not being able to control any surface. Shut off the transmitter and ran the motor using manual throttle. The wires to the plugs were ''HOT'', and reaching for the throttle arm resulted in a fairly perky shock!!! If anyone has any advice that will help me eliminate this RF feedback please feel free to jump in. I have moved all batteries far from the engine, no metal linkage goes from the engine compartment to the internal fuselage The ignition battery is close to the reciever, don't know if this could cause a problem... HELP...This is a sport plane and I would like to get it into the air...[/font] If you got a shock from the plug leads, the metal caps were not pushed far enough onto the plugs to complete the ground connection. Installed correctly, the metal cap will cover the hex part of the plug completely. Same problem causes your RFI problem ..... push caps on far enough ... problem should be gone. This is operator error, not an RCIGN problem. |
I tend to agree...seems like if cap is grounded good...it should not shock at all. If the cap has a metal ridge...remove ridge & use a good 1/4 wide worm gear hose clamp. I read that is a good fix. Capt,n
I usually put NGK BPMR6F in the conversions...if the plugs are differen the caps won't fit all the way down on the hex..Use some muscle and WD40 on the caps...Refund offer still applies...
ORIGINAL: Antique ...Refund offer still applies... HAHAHAH ... I like your style Ralph .... Refund - AND don't come back! Do I read this all wrong? |
You never mentioned what radio system including Rx you are using which could help, and your ignition battery should be located as far from your Rx as possible.
Karol |
:D
A long lead to the battery which is located by the receiver is not good either. I sure would like to See a couple of photos of his radio gear & ignition gear when he had all the problems. There are many good people that could give him good ideas on what could be changed to have instant success. Capt,n
A quick update. First, let me thank all of you for responding, for the most part, with positive replies. I in fact did everything that everyone suggested except for Ralph, because I don't want a refund. But I thought that was one of the most generous gestures that you could have made.
Okay back to business. Using WD-40 and lots of firm pressure I pushed the metal caps as far as they would go onto the spark plugs. I then used slightly larger than quarter-inch wide hose clamps and tightened them as firmly as possible using a nut driver. Then I moved the ignition system battery midway between the firewall and the receiver. Turned everything on and fired it up! You guessed it, No RF feedback, receiver was rock solid , and the engine throttle up and down evenly. It was a joy to behold! Again gentlemen, thank you for your help. It's especially nice to know that there are places like this forum to get help and guidance!! The Smith Mini will soon be flying!!! |
Good of you to admit this common error. I often feel the way Ralf did.
Yo uhad one of the best engine man in the business to do the conversion, So you should have many happy years with the engine.
ORIGINAL: BadAzzMaxx You had one of the best engine man in the business to do the conversion, so you should have many happy years with the engine. Karol |
ORIGINAL: Mrtazmaned [font=''Verdana''][/font] A quick update. First, let me thank all of you for responding, for the most part, with positive replies. I in fact did everything that everyone suggested except for Ralph, because I don't want a refund. But I thought that was one of the most generous gestures that you could have made. Okay back to business. Using WD-40 and lots of firm pressure I pushed the metal caps as far as they would go onto the spark plugs. I then used slightly larger than quarter-inch wide hose clamps and tightened them as firmly as possible using a nut driver. Then I moved the ignition system battery midway between the firewall and the receiver. Turned everything on and fired it up! You guessed it, No RF feedback, receiver was rock solid , and the engine throttle up and down evenly. It was a joy to behold! Again gentlemen, thank you for your help. It's especially nice to know that there are places like this forum to get help and guidance!! The Smith Mini will soon be flying!!! |
Will get some up as soon as the boss returns with the camera!!!
| All times are GMT -8. The time now is 06:17 PM. |
