Conveting G62 to Electronic ignition
G'day folks,
I'm in the process of convering my G62 fitted to a 90" Vailly Seafury to electronic ignition. Nothing wrong with the standard magneto igntion but looking for smoother idle and transition and to keep vibration down. Also looking for some addtional RPM at the top end which I'm told I should get, hope so anyway. Getting the RCxcel system from Glens Models in the UK. Any thoughts? cheers Peter |
RE: Conveting G62 to Electronic ignition
The G62 is a great engine and will certainly benefit from the conversion to CDI and will provide some benefits as you suggested including easier starting and a bit of weight reduction, however I'm not sure the switch of ignition systems will give any increased rpm.
Karol |
Your best bet for getting more power from a G62 would be to fit a canister or a full tuned pipe. Especially the tuned pipe will really increase the power, making it comparable to a GT-80 on mufflers.
A MenzS 24x10 should spin at around 6600 to 6700 rpm with a pipe. |
G'day Peter,
Firstly, why import the ignition when we have a local Aussie distributor - and a good one too. DL Engines Australia I doubt you will see any change in vibration form the change. If anything, you can expect more with the removal of the flywheel (if you remove it) Balance (and balance again) your prop. That's probably the biggest single thing. You will certainly get easier starting and smoother transition and quite likely somewhat increased output but again, the bext way to achieve smooth transition (and reduce vibration for that matter) is by fine tuning the carburettor and in particular the low end. My 2c worth :) ORIGINAL: Peter_OZ G'day folks, I'm in the process of convering my G62 fitted to a 90'' Vailly Seafury to electronic ignition. Nothing wrong with the standard magneto igntion but looking for smoother idle and transition and to keep vibration down. Also looking for some addtional RPM at the top end which I'm told I should get, hope so anyway. Getting the RCxcel system from Glens Models in the UK. Any thoughts? cheers Peter |
1 Attachment(s)
ORIGINAL: Peter_OZ G'day folks, I'm in the process of convering my G62 fitted to a 90'' Vailly Seafury to electronic ignition. Nothing wrong with the standard magneto igntion but looking for smoother idle and transition and to keep vibration down. Also looking for some addtional RPM at the top end which I'm told I should get, hope so anyway. Getting the RCxcel system from Glens Models in the UK. Any thoughts? cheers Peter Contact Scott at DL Engines Australia on 0488142352 and get the full Rexel kit. Simple bolt on conversion, I have done the conversion and the engine idles smother and also has more top end in mine. Cheers |
Take a photo of the G62 running with flywheel and a glass of water setting on test stand. Then when you get that conversion kit installed...take another photo with the same water in a glass. At same RPM also. That will be more convincing about the smoother running. I never seen a engine run smoother after removing the flywheel. But it may be possible. I think it is more in the fine tunning. Capt,n
ORIGINAL: Pelle Gris Your best bet for getting more power from a G62 would be to fit a canister or a full tuned pipe. Especially the tuned pipe will really increase the power, making it comparable to a GT-80 on mufflers. A MenzS 24x10 should spin at around 6600 to 6700 rpm with a pipe. I have tried slimline and now on a j-tec. The aim is to get RPM up as this is ina Seafury. Not trying to hang off the prop or do slow aeros. Hence 21x12 so that the motor unloads when going downhill. I need to get this motor up around 7500 rpm. |
Al
did not realise DL had a conversion kit for the G62, did not even think of them to be honest. Oh well no mind cheers Peter |
ORIGINAL: The Ghost ORIGINAL: Peter_OZ G'day folks, I'm in the process of convering my G62 fitted to a 90'' Vailly Seafury to electronic ignition. Nothing wrong with the standard magneto igntion but looking for smoother idle and transition and to keep vibration down. Also looking for some addtional RPM at the top end which I'm told I should get, hope so anyway. Getting the RCxcel system from Glens Models in the UK. Any thoughts? cheers Peter Contact Scott at DL Engines Australia on 0488142352 and get the full Rexel kit. Simple bolt on conversion, I have done the conversion and the engine idles smother and also has more top end in mine. Cheers now I find out LOL what rpm / prop ? |
Most dealers who sell the RCEXL ignitions also sell the kits for the G62
ORIGINAL: Peter_OZ ORIGINAL: The Ghost ORIGINAL: Peter_OZ G'day folks, I'm in the process of convering my G62 fitted to a 90'' Vailly Seafury to electronic ignition. Nothing wrong with the standard magneto igntion but looking for smoother idle and transition and to keep vibration down. Also looking for some addtional RPM at the top end which I'm told I should get, hope so anyway. Getting the RCxcel system from Glens Models in the UK. Any thoughts? cheers Peter Contact Scott at DL Engines Australia on 0488142352 and get the full Rexel kit. Simple bolt on conversion, I have done the conversion and the engine idles smother and also has more top end in mine. Cheers now I find out LOL what rpm / prop ? I'm getting 8400 on a Turnigy 22x10 wood and an idle of around 1200. Hand starting has become a snap as I have a damaged shoulder and the long wind up on the mag was killing me. The pick up mount on mine is my homemade on as the induction coil mounts were broken of mine(accident in the workshop) Cheers |
ORIGINAL: The Ghost ORIGINAL: Peter_OZ ORIGINAL: The Ghost ORIGINAL: Peter_OZ G'day folks, I'm in the process of convering my G62 fitted to a 90'' Vailly Seafury to electronic ignition. Nothing wrong with the standard magneto igntion but looking for smoother idle and transition and to keep vibration down. Also looking for some addtional RPM at the top end which I'm told I should get, hope so anyway. Getting the RCxcel system from Glens Models in the UK. Any thoughts? cheers Peter Contact Scott at DL Engines Australia on 0488142352 and get the full Rexel kit. Simple bolt on conversion, I have done the conversion and the engine idles smother and also has more top end in mine. Cheers now I find out LOL what rpm / prop ? I'm getting 8400 on a Turnigy 22x10 wood and an idle of around 1200. Hand starting has become a snap as I have a damaged shoulder and the long wind up on the mag was killing me. The pick up mount on mine is my homemade on as the induction coil mounts were broken of mine(accident in the workshop) Cheers bloody hell I'd be stoked to get 8400 on a 22x10, I can just get 7000 on a 21x12 mejanik at the moment. Did you port, balance and blueprint it! :D |
Both those brand mufflers you mentioned are not known for their power producing ability but rather for noise reduction, plus rpm readings can differ greatly between similar size but different brand props or from one tach to another.
Karol |
j-tec = noise reduction that is funny hehehe:D
On a warbird no room for tuned pipe exhausts etc so normally just a canister or box style is fitted. |
Peter,
Did you port, balance and blueprint it! Cheers |
ORIGINAL: The Ghost Peter, Did you port, balance and blueprint it! Cheers i'm getting 7000 rpm with the 21x12 Mejznk on magneto and aj-tec muffler fitted, was getting about 6800 - 6900 with the slimline (smoke). will keep the j-tec as it allows a lot more cooling air to exit with that big cannister removed. looking forward to seeing how it goes with the electronic igntion fitted though till I get more hours on this engine I'm not expecting huge increase just yet. cheers Peter |
I bought an rcxcel ignition for my G-62 and the sensor bracket broke on the first flight causing me to belly land my P-47.The sensor bracket is plastic an vibration is hell on it.I suggest making a bracket out of aluminum or steel to counter this.
Is it possible to use the magneto to send the signal to the electonic ignition? I may try this as an alternative method. John |
We race 100 inch 26 lb AT6s....Stock G62, no muffler, just a pipe about 8 inches long...Special APC race prop..9000 rpm in the air, somewhere in the neighborhood of 120+ mph...The prop is a 19 something, APC might still have some, the T6 race class is about done....
A 62 will run 9000 rpm FOREVOR.... The T6s at 26 lbs have no vertical problem....;) |
mmm maybe but my Seafury is 42lb. If I can get from 7500 - 8000 rpm then I'll be very happy. Even getting an addtional 500 rpm will make ahuge difference to my ability to get off the deck aqnd have a good climb out as well as normal fighter type manouvers.
anyway will see what happens when I do the conversion. |
I had a 38 lb seaplane, used a G62...Took a loooong time to get off the water, flew scale in the air....
can imagine it would have, lots of drag with those floats. At least the seafury is slick once it is up and moving.
ANTIQUE
I BOUGHT A ZIROLI AT6 KIT A FEW YEARS AGO WITH A G62 SET UP FOR RACING. THE WING IS A ONE-PIECE WING VAVUUM BAGGED (CARBON FIBER) BY STINGER WALLACE. THAT ENGINE HAS A MAGNETO IGNITION ON IT. DID THEY RACE THOSE ENGINES WITH MAGNETO IGNITIONS? I DON'T PLAN ON RACING IT.......I JUST WANTED A HIGH PERFORMANCE AT6 FOR A GIANT SCALE WARBIRD. WOULD IT BEHOOVE ME TO PUT AN ELECTRONIC IGNITION ON THE ENGINE JUST TO MAKE HANDLING EASIER? I'VE BEEN SITTING ON THIS KIT FOR A FEW YEARS BECAUSE I NO LONGER HAVE A VEHICLE TO HAUL A 102" WING AROUND IN. I PLAN ON PURCHASING A NEW VEHICLE NEXT YEAR OR A TRAILER TO HANDLE IT. I ALSO HAVE A SECOND ZIROLI AT6 KIT WITH 2 PIECE WING. TRYING TO DECIDE WHICH TO BUILD. ANY COMMENTS OR RECOMMENDATIONS FROM ANYONE OUT THERE EXPERIENCED WITH THIS KIT WOULD BE DEEPLY APPRECIATED. |
The race 62s a box stock with open headers from Mac's products and a APC race prop...i was the engine inspector for 15 years, the 62s were magneto ignition and untouched internally...
EI won't make it faster, just lighter and easier to start.. |
That's the one I have.
Do you recommend using the spring starter? I've read about nightmares trying to start this engine by hand. Does that kit tend to build tail heavy? If so, I would rather leave it on magneto so that the extra nose weight is at least functional, so to speak..... as long as I can get it to start dependably. In the end, the less complexity, the better! |
The spring is the next best thing to the EI...
62s are not that hard to start without the spring, just takes a technique...Full choke, flip hard, it will pop...choke off, flip hard, it should start...They like to be pretty wet and the prop heeds to be set so the full force of the flip comes before the magnet comes before TDC...Use a good glove....With EI it's a one finger start.... |
