RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   G-38 Plug in engine case (https://www.rcuniverse.com/forum/gas-engines-142/9985013-g-38-plug-engine-case.html)
LUDS96 09-06-2010 09:25 PM
I could not figure out why my G-38 was acting up when it always ran perfect!!! Had a dead stick and it woud not start. I pulled the cowl off and was checking the fuel lines. I then noticed the plug in the crank case was missing. It looks like 10mm is it pipe thread. I have a 10mm bolt in iot right now but I did not want to over tighten it. Can I get a plug any where that will fit it. Lucky find and a nice safe dead stick1 :eek:
aussiesteve 09-07-2010 06:24 AM
RE: G-38 Plug in engine case
Is it in the top of the crankcase or the bottom?
If it is in the top - maybe you are missing a sparkplug :D
Ok - sorry, I have no idea what the actual thread is.
w8ye 09-07-2010 06:32 AM
Some pictures would help
spaceworm 09-07-2010 02:37 PM
Maybe it is the option takeoff for a pulse tap for smoke or another type of carb. losing it would cause your cylinder base pressure to go away and thus no transfer of fuel/air mix to the piston top. Perhaps the G-38 parts breakdown schematic will give you the thread of the plug.
Regards, Richard
w8ye 09-07-2010 03:15 PM
1 Attachment(s)
http://www.horizonhobby.com/Products...D=ZEN312013510 $4.95 case plug
There's a gasket that goes under it http://www.horizonhobby.com/Products...D=ZEN313013520 $.99
In the second picture, you can see where it goes
captinjohn 09-07-2010 05:08 PM
Plug it off with anything that will thread in good. Use some sealer or loctite. Capt,n
w8ye 09-07-2010 05:20 PM
I think it is just regular 10mm
flygilmore 09-08-2010 12:12 PM
W8ye is right on with what you need.
spaceworm 09-08-2010 01:29 PM
Insure that the bolt is not so long that it interferes with the crankshaft counterweight. Use locking and sealing compound as others have said.
Or, get a smoke kit and make smoke!:D
Regards, Richard
