vaccum bagging...1st failed
WA
so had a friend instruct me how the process goes..lay went nice and smooth, pulled it out of the bag this morning and had a hard time peeling the mylar off, i waxed it three time yesterday before glassing it. bagging machine set at 7", i remeber the guy at fiberlay saying to wax the mylar other wise it will stick..useing fiberlay's proglas 4:1 epoxy..might go pick up some west systems today and retry
this epoxy i have gets hot in the cup,the left over resin i leave in the cup get hot after about an 1hr or so, so hot i starts smoking. maybe thats why?
got to clean up the wing now so i can try once i firgure out what happen, any ideas?
so disappointed
FL
RE: vaccum bagging...1st failed
Hi Steve,
What wax did you use on the Mylar? I would suggest using Partal Paste #2 wax or Meguiar's Mirror glaze wax, which are both made for composite lay-up and mold construction. Either of these will handle the heat build up much better than an automobile type wax. Your fiberglass store should have one or both of them and they are less than $20 for a big can.
The heat build up in the cup is from there being a large amount of resin in it, I would guess. The thinner the layer or resin (like what is more than likely on the surface of your wing), the less heat it will give off. Also, a slower epoxy tends to stay a little cooler as it doesn't have to go off so fast. Try to keep the batch of epoxy you are using in a thinner layer and it shouldn't kick so bad.
Don't get discouraged, once you get it figured out, you will love it!
MN
Steve, what is the working time of that epoxy, I am not familiar with it? Was it a laminating "slow cure" type epoxy??
I've been satisfied with EZ Lam 60, but others like west, MSG, etc...
I've been sheeting foam wings and othercontrol surfacesfor over 25 years. Never used a vacuum bag and I don't think I never will.
Am I missing something here? I certainly would like to know.
Charles
Charles
WA
well for the wax i used mothers carnuba automotive wax, i figured it would be ok..i know some other people have used simalar wax.
a friend mention that it may have started to kick off before i got eveything together, it only seemed like 5-10mins but it could have been longer, the thinner the layer of epoxy the faster it cures?
here is the specs on the resin(from fiberlays website, i have the med harderner):
Characteristics of Pro Glas Epoxy System | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Pro Glas epoxy is a high performance epoxy resin which may be combined with three different hardeners for optimal performance in different applications. The backbone of the Pro Glas epoxy system is the 1314 Resin. It features 100 percent solids (no Volatile Organic Compounds), low viscosity (allowing fast and efficient wet out of reinforcement material), relatively clear (good for clear casting applications) and low odor and toxicity. It may be combined with three different hardeners, namely 3102, 3103, and 3143.
thanks for the replys
WA
i picked up some west systems 105 resin with 206 hardener prob try that in the next couple days, ill prob pickup some mold wax too
FL
Steve, the thinner the layer of resin, the slower it cures. You can mix it in the cups, but I would get it on the wing or on a paper plate quickly to thin the film layer out. Once resin starts to kick and produce heat, it becomes a chain reaction and it all gos. That is why I suggest pouring it in a plate, or better yet, on the parts as soon as you can. The 12-15 minutes working time is pretty quick! The 15-25 may work if you can get it spread quickly.Thin layers and cooler temperatures will slow it some, but a slower resin would be better. I am one of the MGS guys, and I really like the long cure times since my weather is in the upper 80's to 90's most of the year. The 105 ~ 206 will give you very good results, and be a little friendlier to work with too.
Good Luck ...
Good Luck ...
for best results when using mylar is the 4 to 7 mil thickness. Its most common at Home Depot stores and its called painters plastic. It come in a variety of packages,,, its best to get it in the roll,,, folded up mylar will leave divots from the plastic where it was folded in your glass works.
never seen mylar stick to epoxy or visa versa,,, And you don t have to wax the plastic
BV
BV
FL
Are we talking about the vacuum bag sticking to the wing, or using a Mylar sheet for a finish on the outside (finished side) of the wing? If it is the bagging that is sticking, Bill is correct you shouldn't have to wax it at all! If you are waxing and painting a sheet on Mylar to finish the outer surface wing, I think you need to wax the Mylar sheet.
WA
ORIGINAL: Scorpion Racing
the glass and resin sitcking to the mylar, when i tried to peel of the mylar sheet it came with the glass..most of the glass didnt stick to the wing. it stuck to the mylar.
heading over to my friends house to redo it, hes helping me with it this time around
