RCU Forums
-   General Racing Discussion (https://www.rcuniverse.com/forum/general-racing-discussion-140/)
-   -   Help identifying this plane. (https://www.rcuniverse.com/forum/general-racing-discussion-140/11622894-help-identifying-plane.html)
ksbowhunter1998 10-19-2015 11:30 PM
2 Attachment(s)
Recently bought this plane at our local auction but don't know what it is. It is a fiberglass fuse with a 42.5" wingspan. Fuse length is 30" nose to tip of rudder.
http://www.rcuniverse.com/forum/atta...mentid=2126445
http://www.rcuniverse.com/forum/atta...mentid=2126444
fizzwater2 10-20-2015 06:09 AM
what size mount is in there for the engine? Perhaps a .15? Might be an old .15 sized quarter midget airframe. Need a good profile view of the fuse.
fizzwater2 10-20-2015 06:20 AM
Check out the ME109 on Matney's site under "quarter midget". He still has some .15 sized QM kits that he'll mold if you want.
http://www.matneymodels.com/qm.html
But those rounded wingtips look more Napier like. (Napier-Heston). You might google around some for pictures of old .15 QM planes.
fizzwater2 10-20-2015 07:03 AM
It could also perhaps be a Heinkel He-100 plane, believe it was Jim Gager that make that kit.
That might be most likely. A friend of mine that flew more .15QM than I did reminded me of that one.
ksbowhunter1998 10-20-2015 01:39 PM
I will try and get more pictures tonight yet. It came with a 2025 david brown motor mount.
ksbowhunter1998 10-20-2015 02:47 PM
6 Attachment(s)
http://www.rcuniverse.com/forum/atta...mentid=2126534http://www.rcuniverse.com/forum/atta...mentid=2126535http://www.rcuniverse.com/forum/atta...mentid=2126536http://www.rcuniverse.com/forum/atta...mentid=2126537http://www.rcuniverse.com/forum/atta...mentid=2126538http://www.rcuniverse.com/forum/atta...mentid=2126539
DHG 10-21-2015 10:10 AM
I'm pretty sure it's Jim Gager's He 100, although Gager's design called for a constant-chord midsection from the root to about where the wheels are. But the builder may have sanded a straight taper into it, or perhaps used cores from a Jim Gager P-39/P-63. The airfoil would've been close enough to work.
As QM15 airplanes go, this was definitely one of the better ones. The upright engine is a no-hassle setup, and the wide-stance, wing-mounted landing gear made for great ground handling. You should clean it up and fly it for sport!
Cheers,
Duane
