Some advice needed.
I have been flow nitro plane for more than 9 years.I got an old Kangke F3D recently,tried last week,there some special character noticed.
First,during takeoff.As airplane lift off there was a significant left roll tendency.was it normal?(I did rolling take off just like normal airplane.) Second,in order slow this thing down for landing I offset some up elevator.Do you did same thing?or any better idea? Third,I did pull vertical to check thrust line,find little left deviation exist.Should I correct it? It is really enjoyable to fly this racer. thank you . |
Correcting the thrust line should help the take off.
Also check the CG and make sure that you are not tail heavy. |
Most pylon racers take-off holding ALOT of right rudder. Then slowly let it out...you cant release it all at once. I know some racers who adjuct the rudder throw so that max right rudder held during take-off keeps the plane straight. Not a normal sport plane take-off technique! So you are on the right track Regarding elevator on landing, I do exactly what you are describing. I activate the “airbrake” feature for landing and have it add approximately 10-15% up elevator for landing. It acts like a new elevator trim posititiion. It takes a few flights to dial in the correct value. I also use it as an airspeed indicator...if the plane climbs after activating the airbrake feature, I am too fast. If I find myself holding up elevator after activating the airbrake feature, I am TOO SLOW. This is the best feature of modern transmitters. Kurt |
I did correct thrust line by insert a washer under the engine,Now vertical line is straight.
And i also activate air-brake after touch down,but is is still pretty fast thought.Keep working on it. |
| All times are GMT -8. The time now is 10:50 AM. |
