Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
EG MX2 100cc Build
Old 02-28-2011, 05:41 PM
rjeffrey
Default EG MX2 100cc Build
I just received shipment from Red Aero RC the EG Aircraft 100cc MX2 in the Gary Ward scheme.
Engine and most of the other components are from KING KONG HOBBIES.
I will attempt to post photos and comments during the build, and I sure would appreciate your suggestions and comments during the process.
SPECIFICATIONS:
Scale: 37%
Wing Span: 108”
Length: Including spinner 95”
Wing Area: 2093 square inches
Flying Weight: 26.5 pounds
100 CC COOL FEATURES:
Fuselage and Wing incorporate carbon fiber laminations for extra strength.
Aerofoiled Carbon Fiber Landing Gear.
Carbon Fiber Wing and Stab Tube.
Carbon Fiber Tail Wheel Assembly.
Extra strength fiber control Horns.
4.5” Carbon Fiber Spinner.
Anodized Extra Length Heavy Duty Servo Arms.
Extension Lead Safety Clips.
High Density Rubber Wheels.
Top Quality Heavy Duty Hardware including Titanium Pushrods.
Pre-hinged Control Surfaces.
Pre-assembled and mounted Gas Tank.
Installed Servo Wire Guide Tube.
Covered in Genuine Ultracote.
Complete and Detailed Instructions on CD.
These are the components I plan to use for the build:
COMPONENTS:
Engine: DLE 111
Servos: Ailerons 2 per wing
Servos: Elevator 1 per side
Hitec 7955TG Digital HT Titanium Gear Coreless Servo
0.15 sec/60 degrees at 6.0V 333.29 oz-in (24.0kg-cm) at 6.0V
Servo: Rudder
Hitec 7980TH Monster Torque Servo
6.0V Speed: 0.20 sec Torque: 500 oz/in (38 kg/cm)
7.4V Speed: 0.17 sec Torque: 611 oz/in (46 kg/cm)
Servo: Throttle Hitec 5665MH
Receiver: JR 922 PowerSafe™ receiver with failsafe switch
Batteries: (2) LiFe 3200 MAH Packs
WRC Wike R/C Products IBEF Ignition Battery Eliminating Filter
TME Smoke Pump
Servo Arms: Spot On (Blue) Ailerons 1.5" Elevator 1.75
Rudder Arm: SWB 4" offset <o></o>
Old 02-28-2011, 07:09 PM
rjeffrey
Default RE: EG MX2 100cc Build
It's time to get started! After un-boxing the kit, I found all parts well wrapped in bubble wrap and various bags of hardware.
First thing was to un-wrap the stabs and inspect them.
Two neat items, the servo bays are cut for the servo wire, and the rib
next to the fuse is not just plywood but plywood with G12.
Next I laid out the hardware and other items.
There are absolutely no wrinkles on the stabs, rudder or wings; however i will still take my time and seal all edges & trim followed by a good shrinking of the covering. (nice not having to spend a lot time working out wrinkles)
ID:	1571564   Click image for larger version
ID:	1571565   Click image for larger version
ID:	1571566   Click image for larger version
ID:	1571567   Click image for larger version
ID:	1571568   Click image for larger version
ID:	1571569   Click image for larger version
Old 02-28-2011, 07:13 PM
rjeffrey
After shrinking the wings, rudder and stabs it’s time to get going on the control horns and servos.Hard points are pre slotted. Just cut away the Ultracoat with a sharp #11 blade or using a fine point soldering tool.I like using the soldering tool as it not only easily opens up the area as it does so it seals the Ultracoat.Next I prepared the fiberglass control horns by cutting to the proper length and sanding the portion being inserted in the control surface for better bonding.I made sure to clean the horns with Isopropyl Alcohol and dry fitting prior to applying 30 minute epoxy.For the rudder prior to using epoxy dry fit measure and mark!
ID:	1571571   Click image for larger version
ID:	1571572   Click image for larger version
ID:	1571573   Click image for larger version
ID:	1571574   Click image for larger version
ID:	1571575   Click image for larger version
Old 03-01-2011, 04:04 AM
rcairflr
My Feedback: (44)
Very nice. The one thing I like to see on a build thread is posting the actual Wing Area, Wing Spar and Actual Weight as built, not just what the manufacturer says.
Old 03-01-2011, 04:57 AM
Taildragger726
Taildragger726's Avatar
I am betting that it will be well under 26.5 lbs.
Old 03-07-2011, 01:31 PM
Patto
Patto's Avatar
Any updates on the build? I'm wanting to order one of these, (just waiting for someone to give me the cash to do so).
-Pat
Old 03-09-2011, 05:19 PM
rjeffrey
I have been away from the build for awhile. Now all the control horns are prepped it’s time to mix up a small batch of 30 minute epoxy.Using a length of sharpened music wire coat the inside of a pair of control horn slots, than apply a even coat of epoxy to all sides of matching control horns.Remember to dry fit and clean prior to mixing the epoxy.The next evening I installed the servos for the ailerons and elevators.
ID:	1576202   Click image for larger version
ID:	1576203   Click image for larger version
Old 03-15-2011, 03:57 PM
Taildragger726
Updates?
Old 04-21-2011, 09:06 AM
blue77
My Feedback: (178)
There is a guy selling the smaller version, 73" I believe< in my area...he says the motor...DLE 30 has pulled the motor box apart twice...I would be interested in opinions about the plane, and about what the plane would be worth...just airframe...Thanks, WC
Old 04-21-2011, 10:27 AM
Eganwp
Eganwp's Avatar
Should be awesome! I'm excited to hear what you think of it. I'm curious to hear some flight reports from people on the new high torque Hitec magnetic induction servos as well.
Old 04-28-2011, 06:09 PM
Taildragger726
ORIGINAL: Eganwp
I have been using a Hitech 7990 magnetic induction servo on the rudder of our 100cc planes,,,, AWESOME !! Be sure to use an SWB rudder arm.
Blue, I think you are referring to the SlipStream airplane. Had one flying for over a year with no problems, Also had the EG 30cc prototype flying for 8-10 months again with no problems.
Old 04-29-2011, 02:36 PM
MetallicaJunkie
MetallicaJunkie's Avatar
i have the 50cc version(red white and blue).....pretty much the same layout, just a few more servos.... mine came in under 17#s dry
Old 05-05-2011, 05:03 PM
Taildragger726
I have one customer who has his 50cc MX under 15.5lbs !!
