Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Bridi Big Kaos engine choices???
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 04-09-2012, 04:13 PM
Scota4570
Default Bridi Big Kaos engine choices???
I am about to start a Bridi Big Kaos kit,
http://www.bridiairplanes.com/hangar/bigchaos.html
They are suggesting 90-180 glow. IMHO they tend to be conservative on engines. The wing area is 1140. The weight is suggested at "11-Lbs w/o the engine.
I have a conversion engine just like the one linked next,
http://tech.flygsw.org/OPS.htm
It weighs about 2000 grams or 4-pounds with the muffler. It produces 4 HP at 8300 rps (18x10 prop at 8300)
I looked up some engine specs:
OS AX120 produces 3.1hp for 870 gm
OS BGX 3500 4.04 hp / 1340 gm
ST G2300 3.7 hp/ 1077
Moki 210 3.3hp/ 1275
Moki G180 3 / 1200
I want as much power as the airframe can handle. I also do not want to use an engine that is so heavy as to destroy the handling qualities. I am not interested in glow engines, only gas need apply. From what I am gathering I will be increasing the all up weight by about a pound, all else remaining equal, IF I use my OPS.
Anyone have any help they can give me on the suitablility of my OPS engine?
Old 04-10-2012, 04:23 AM
grant118
My Feedback: (26)
Default RE: Bridi Big Kaos engine choices???
That looks like a great engine. I have a RC Showcase 180 gas engine that is similar and would work very nicely. The RCS may be a littly bit lighter though. Look at the spec for the RCs and it should give you an idea of the thrust/prop to use and you could check the thrust to weight ratio for your set up. The Moki would give you the most power but I know you want to stay with gas. Keep posting your build picks.
chris
Old 04-10-2012, 08:43 AM
Zippi
My Feedback: (10)
Zippi's Avatar
OS AX120 spinning a 17X6 prop.
Old 04-10-2012, 08:56 AM
Sport_Pilot
Sport_Pilot's Avatar
I think the OS FX 160 is the most common engine used and should be used for comparison.
Old 04-10-2012, 07:52 PM
Scota4570
OS 160 SPECIFICATIONS
Displacement: 1.60 cu in (26 cc)
Bore: 1.32 in (33.6 mm)
Stroke: 1.16 in (29.6 mm)
Practical rpm: 1,800-10,000
Output: 3.7 hp @ 9,000 rpm
Engine weight: 32.6 oz (925 g)
Muffler weight: 9.7 oz (275 g)
That would make my engine 1.7-pounds heavier. Would 1.7-pounds turn a nice flying aiplane, of this size, into a pig?
Old 04-11-2012, 04:09 AM
Sport_Pilot
I doubt that would be significant on this sized plane, but maybe if you could shorten the nose you could remove weight from the tail. I would ask this question on the classic pattern forum, I am sure sombody there has one.
Old 04-11-2012, 08:53 AM
MetallicaJunkie
MetallicaJunkie's Avatar
do you have pics... id love to see a giant Kaos.... a buddy of mine keeps saying he wants to blow up a kaos to 50cc size
Old 04-11-2012, 04:00 PM
Scota4570
ORIGINAL: MetallicaJunkie
The Bridi Big Bee has a simmilar wing as the Kaos. The airplane is larger. A 50cc, is about perfect. I would lighten the fuse a bit, it is lite ply and a little beefier than necessary IMHO. I have one and like it very much. The BME 50 has been the best match so far. I am now flying it with a 65cc conversion. I first flew it with a Zenoah 41cc conversion. The plans suggest a G-38. Flip the fuse over and make a low wing Big Bee and I think you will be close to your 50cc Kaos.
Old 04-11-2012, 04:01 PM
Scota4570
nm
Old 04-11-2012, 05:36 PM
Texastbird
Texastbird's Avatar
Big Bee has a 96" wing compared to 80" on the Kaos.
