Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Powerbox Smoke Pump Help
Old 12-26-2012, 09:42 PM
Levi Wags
Levi Wags's Avatar
Default Powerbox Smoke Pump Help
Just having a few issues with my powerbox smoke pump. It's installed in a Comp ARF 2.6 Extra running through a powerbox cockpit and powerbox kill switch. I have the pump mixed to the throttle and activated by a switch. When I turn the mix on it works fine with the throttle but when I turn the mix off the pump runs flat out.
I've tried reversing the smoke channel but that only reverses the mix when it's activated. I've checked throws and end points and can't see an issue.
Any advice would be awesome.
Kind Regards
Levi
Old 01-29-2013, 12:42 PM
niteowl5001
niteowl5001's Avatar
Default RE: Powerbox Smoke Pump Help
Levi, what radio are you using? I have a JR 11x and mine works fine. I connected mine in the Aux 1/Flap channel of my Spectrum ar9000. I activate with the mix switch. I also use program mix 5 throttle to flap (because Its connected to the flap channel).
