Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Yak 55SP 2.6M converted to Turboprop!!!
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 01-14-2013, 08:32 AM
geh3
My Feedback: (84)
geh3's Avatar
Default RE: Yak 55SP 2.6M converted to Turboprop!!!
Istarted to add some bling
the stars are from KIRBYGRAPHICS..
this IS a Russian plane so it will get a Russian treatment
ID:	1840327   Click image for larger version
Old 01-14-2013, 09:22 AM
daveopam
My Feedback: (9)
daveopam's Avatar
What sort of a hinge is used on those Ailes? There is sure not much of a gap.
David
Old 01-14-2013, 09:27 AM
gene6029
gene6029's Avatar
I have been following along & like your scale scheme. I did mine also off a full scale bird also. Havent run across another one yet...Gene
ID:	1840356   Click image for larger version
Old 01-14-2013, 10:13 AM
geh3
My Feedback: (84)
geh3's Avatar
the ailerons have a "live" hinge typical of most of their planes
the rudder and elevators have a 4mm alu rod supported by sturdy
phenolic posts... all of this is done at the factory..quite nice
Old 01-14-2013, 10:14 AM
geh3
My Feedback: (84)
geh3's Avatar
Thanks, mine will resemble that pictured earlier in this post
the real one of these is a very good plane!!!
Old 01-17-2013, 08:45 AM
  #31
geh3
My Feedback: (84)
geh3's Avatar
Started masking for the paint..ugh, lots to do here...
Old 01-17-2013, 09:39 AM
  #32
geh3
My Feedback: (84)
geh3's Avatar
Exhaust extensions came in for the TP!
these will be tricky to install (Dremel to the recsue!)
Old 01-19-2013, 04:58 AM
  #33
geh3
My Feedback: (84)
geh3's Avatar
Primer goes on...
then wet sand..then color
lots of work but the final result is worth it...
This plane will be decorated with a combination of paint+Vinyl graphics
ID:	1842074   Click image for larger version
Old 01-19-2013, 02:21 PM
  #34
gene6029
gene6029's Avatar
Its alot of work, but you will definately have something different.....Gene
Old 01-19-2013, 02:27 PM
  #35
geh3
My Feedback: (84)
geh3's Avatar
Yes thanks but the turbine install was not that difficult
re-engineering the LGmounts was a little tricky but Ilove to build!
esp in the winter..
Painting now...
Old 01-19-2013, 04:30 PM
  #36
gene6029
gene6029's Avatar
Hey, i hear ya about building in the winter. I'm a transplant from Pa & used to do all my building in between shoveling snow from snow storms! Down here we get snow overnite & by lunchtime its in the 50s! I still try & get at least one build in over the winter months though.....Gene
Old 01-19-2013, 08:21 PM
  #37
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
I'm curious why you are bothering with primer? I have painted directly on the Comp ARF white finish after a light scuff with great results. I can see using primer to fill the seams but not on a molded white surface.
Old 01-20-2013, 04:44 AM
  #38
geh3
My Feedback: (84)
geh3's Avatar
Yes Icould probably do that but Ilike following directions and the paint i'm using
suggests primer so Igive it some light coats and then wet sand..you can't go wrong following the directions!!!
THANKS BUT Iwill keep that in mind for the next time...
Old 01-21-2013, 06:45 AM
  #39
geh3
My Feedback: (84)
geh3's Avatar
Bling being added WOW this will look OK!
The Kirby Graphics are GREAT!!!!!
ID:	1842848   Click image for larger version
ID:	1842849   Click image for larger version
ID:	1842850   Click image for larger version
ID:	1842851   Click image for larger version
Old 01-21-2013, 08:02 AM
  #40
gene6029
gene6029's Avatar
Beautifull work!.......Gene
Old 01-21-2013, 08:08 AM
  #41
geh3
My Feedback: (84)
geh3's Avatar
Thanks, the final result should be highly visible in the air..
that's what Ilike and it is an attempt to be scale...
Old 01-23-2013, 07:41 AM
  #42
geh3
My Feedback: (84)
geh3's Avatar
In oder to make the 54TP function properly, Ihave decided to change the exhausts as shown.
This is a straight shot out of the TP so it shouldn't affect performance and it will be easy to install..
intereasting hobby this is !!!
ID:	1843489   Click image for larger version
ID:	1843490   Click image for larger version
Old 01-23-2013, 08:58 AM
  #43
geh3
My Feedback: (84)
geh3's Avatar
Icalled upon my favorite surgeon Dr.DREMEL
and we consulted and then operated, preliminary installation here
I think it will be UNIQUE to say the least. Dr. Dremel says the patient will
live to fly soon (comon spring)
ID:	1843521   Click image for larger version
ID:	1843522   Click image for larger version
ID:	1843523   Click image for larger version
Old 01-23-2013, 09:22 AM
  #44
geh3
My Feedback: (84)
geh3's Avatar
I forgot, the canopy assy is all done.
ISMOKEDit...
ID:	1843536   Click image for larger version
Old 01-23-2013, 02:21 PM
  #45
gene6029
gene6029's Avatar
Nice work on the canopy, i like the tint......Gene
Old 01-23-2013, 02:50 PM
  #46
geh3
My Feedback: (84)
geh3's Avatar
Thanks, I installed it by placing magnets all around outside and inside and then used
foam safe CA all around. Whan that cured, I put a bead of Areopoxy on the inside.. it is nice and tight to the frame!
The tint is TAMIYA # PS-31 "smoke" and boy it gives off a lot of fumes when applying... I had to evac
my worksop for a few hours... HAH
Old 01-30-2013, 12:22 PM
  #47
geh3
My Feedback: (84)
geh3's Avatar
More bling added..all Vinyl...
this approximates what the full sized one has as far as I coudl tell from the
AIRLINERS.NET photos...
more to come..white stripes on the bottom..
hey it WILL be very VISIBLE!!!!!
Old 01-31-2013, 03:00 AM
  #48
gene6029
gene6029's Avatar
When i was researching photo information for my SP-55m, i contacted the photographer that took the photos on airliners.net & told him what i was doing. He responded by sending me a 360 degree walk around set of photos & only asked that i send him pics of my finished model. Something to consider on future projects.......Gene
Old 01-31-2013, 05:40 AM
  #49
geh3
My Feedback: (84)
geh3's Avatar
NICE, thanks
for this particular plane Iwasn't so much interested in 100% scale fidelity
as I was in high visibility in most cloud conditions.. I'm not entering it in any scale events
but Ijust want to wring it out and have fun...SOI made it as "Russian" themed as possible
with the correct stars, YAk logos, russian text etc.... fun stuff...
Old 02-01-2013, 11:56 AM
  #50
geh3
My Feedback: (84)
geh3's Avatar
Ok onto final assy and CG determination, in the meantime I put it together
to get some Pics!WOW it WILL be highly visible and is does look Russian like... HAH
ID:	1846825   Click image for larger version
ID:	1846826   Click image for larger version
ID:	1846827   Click image for larger version
ID:	1846828   Click image for larger version
ID:	1846829   Click image for larger version
