Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Trouble entering inverted elevator
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 07-24-2014, 02:36 PM
mvallyman
My Feedback: (32)
mvallyman's Avatar
Default Trouble entering inverted elevator
I'm flying a 30% MX-2 50cc. I can be going slow inverted and pull up to enter an upright elevator and all is good, it flips right side up and into the elevator. But when I am right side up and push full down to enter inverted elevator, as soon as it inverts it flips to its left and heads down with the canopy toward me. It will do larger outside loops with power on but doesn't like anything with a lot of down elevator. Why is it ok going to upright but not inverted?
Old 07-25-2014, 07:27 PM
jetmech05
Too much throw? Or is there a mix?
Old 07-25-2014, 08:42 PM
nitro wing
try less levator and a touch of idle up to stabilize, easy on the rudder or it may fall out easily. adjust from there.
Old 07-30-2014, 05:58 AM
mvallyman
My Feedback: (32)
mvallyman's Avatar
Thanks for your input guy's. There is no mix going on and smaller amounts of elevator wont help but I did find I can do either one of two things to avoid the issue. Some left rudder for a couple seconds helps or, if I give it a small blast of prop this will also stabilize it.
