Routing Ideas??????
Routing Ideas??????
O.K., This may be a dumb one, but does anyone have any nice antenna routing ideas for my Edge 540T? I just want to make sure it looks nice. My Rx is right by the wing tube(aft side). Any suggestions would sure make my day.
TW
TW
RE: Routing Ideas??????
Run your antenna through an antenna tube routed through the inside of the fuselage with an exit on the bottom of the plane just before the tail wheel assembly.
My Feedback: (18)
GA
Well we all have different ideas on this subject. I run all my wires on the bottom of the outside of the fus. On the WH Edge, I drilled a hole in one of the supports, ran the antenna out the bottom and covered it with yellow electrical tape. cannot see it even if you look for it, and it is not close to electronics.( servos & wires.) Also, if you ever do have a problem with your Rx, it is very easy to remove and replace without threading it through a tube that MUST be fastened to the fus for obvious reasons.
CA
Need another idea? I run my antenna in the Extra Special through a tube that's located on the top edge and starboard fuse side of the wing tube former, through the next former top edge, crosses through center and through a rubber hold-down and along the top center part of the turtle deck. Keeps it away from servo wires and pull-pull wires. Tube does not exit the fuse and is not in the way when the canopy deck is removed..
Kip
Kip
