PRECISION AEROBATICS EDGE540T
#476
RE: PRECISION AEROBATICS EDGE540T
Hi all.
I have just about finished putting the edge together with a DL50 up front. I am just setting up the throws and was a bit confused with the measurements given in the manual. I am guessing that the throws are in millimeters not degress.
What throws have you guys got setup.
#477
Aussie what system do you use for checking your CofG ?, do you have any shots of your setup, been thinking how Im gunna do it !
Painted my Pilot last night and fitted it tonight, canopy then Im done!
Don
Don
#479
RichAur, not sure about the throws as yet, only full throws, perhaps some one will chime in with their setup's.
I could not really understand the indicated throws in the manual either, what does ? mean....
Don
Don
#480
Don,
Hopefully Adad my be still in here and clear up the ? meaning on the throws. Adad yoohooo?
I suspend my models upside down from a ceiling beam hook with three tent adjustable guy strings. One around each main landing gear and tail gear and adjust so you have level flight attitude. (Make sure its a good hook though then use a plumb bob off the same hook to find the CofG. This is the most accurate method I have found so far. I will quickly set it up and send you a picture.
#481
with this method your not trying to balance and hang onto the model at the same time which gets difficult with a larger model. Once its hanging you can add weight to the nose or tail and see the result. It is just a matter of positioning the weight inside the fuse then. I usually don't mount the planes battery's and use them as the adjusting weight so as I don't have to add weight. I find this method very accurate and have had no problems so far.
#482
ORIGINAL: RichAur
Hi all.
Hi all.
The throws in the manual are measured in degrees.
#485
Don,
U did a fantastic job on ur Pilot man, i got a pilot too but its not in my plane, i gave it to my grrrandfather to paint since he likes this sort of thing and he doesnt do much these days and anyways it looks terrible so i may have to buy another one from pa.
i used the great planes cg machine, its a little small but it does work, and then a week later i put pins in my wing and then i check the cg Upside down with my fingers and it was spot on, and since i have flown it, it was pretty much perfect i havent tried much 3d yet, but the plane flys nice and true here is a pic of my setup, i think its a little messy though
#486
Aussie, thanks for the info on CofG.
If you get a new pilot, you can use spray packs or get a cheep air brush and some acrylic hobby paint, pretty easy to do, there is a great how to article in this months RCM. The overcoat with clear varnish realy brings it up nice.
Thats not messy man, nicely cable tied in, you should see some of the setups Ive seen, there messy....
Don
Don
#487
yuh i can paint it at work being a panel beater and all, but i tell u without a trade behind u and knowing whats out there these things would be a night mare to put togethor to the un trained Eye i have seen some really simple setups with trainers and ppl still get that wrong, i dont know why but they do.
but overall iam very happy with this edge im just finding it hard to get the time to fly it, with the long w/e rain and all we are totally flooded at work.
#488
RichAur, when suspending the model what are we looking to get level when setting it up ?
Equal length on the cords ?
Wing cord line ?
Bottom of model ?
Don
Wing cord line ?
Bottom of model ?
Don
#489
Don,
How is ur progress going.?? i was just wondering if u used the original rods for hooking up the Ailerons with those new control horns u bought.?? and how did they go.??
#490
Don,
I find the tailplane cord line is accurate enough. Depending on the wing it can be difficult with dihedral, washout etc. If you have a flat tailplane you could use a spirit level lightly on it. I generally stand back and eyeball it with respect to the wing and tailplane chords so it appears to be in level flight attitude but upside down. (did that make sense?). No real science to it a bit of common sense and guestimation.
#491
Aussie, going well, RTF, just need to check CofG again, lifted off each wing tip and fairly spot on.
Yeah I used the original control rods with the Dubro horn attachments, worked fine, and the new wider rod on the rudder was better for the Pull, Pull setup as well.
Don
Don
#492
Thanks Richard, It seems that we need to get something level to achieve accurate results, so I guess the wing cord line is what we are looking at.
I will give it a try ..
Don
Don
#494
That looks great Don, Hey did u drill the hole bigger for the Blue clevis.??? and put nut and bolt on.???
i used the standard ones. thinking it should be strong enough...
#495
Aussie, I used 2mm cap heads with a 2mm nyloc nut, it threads through the blue clevis perfectly, you need to replace the short 2mm screws provided with longer ones, should be some in the kit and put a nut on for safety.
Don
Don
#496
hi guys i had a flight with steves aka aussie pilots plane today & it flys as good as most 33% planes i have flown..which is a few[8D]
the rolling harriers are a1 & the hoveing is effortless ..i hope he lets me bring it real low tail tap low lolhehe ,,hey steve[X(]
thanks for the fly mate your flying skills are great..you will shine as soon as you get a few more flights
cg
cg
#497
wifpwcf, No worries mate ur flying skills are great also i was waiting for u to bring the hover down lower next time i give u my permission as long as i got my Camera with me rolling harriers were crazyily Fast i think u gave my plane a head ache when it came down it couldnt remember if it was an edge or an extra hehe
Thanks again Glen, cant wait for next time
#498
sweet mate when ya bring it out next time we will get some wicked pics for ya.
a extra or a edge thats funny lololol
cg
cg
#499
I maidened my edge today. Put three flights on it. The first take off was a bit all over the place due to nerves and not knowing how much stick to put in. Two and three were much better. It landed like a trainer.
It has a DL-50 up the front which is more than enough power.
One very happy customer.
#500
HAY GUYS , I'M BACK IN THE LAND OF THE LIVEING AT LAST!!!!(WORK )HAD MY EDGE ABOUT 6 MTHS NOW--- TIME TO START PUTTING IT TOGETHER AT LAST!!!!GOT THE DA MOUNTED, PROP & SPINNER DRILLED,SURFACES R HINGED- NEED 2 ORDER MY SERVO'S NOW -4X5985'S, 1X5955,& A COUPLE OF NEW MINIES FOR THR & CHOKE- HERE'S A PIC OF MY HANGER!!!!
