Composite-Arf 2.3 Construction
Are any of you guys reinforcing the landing gear mounting on the 2.3? It looks life awfully thin plywood that the carbon gear legs are attached to. With those two piece legs, the forces are much higher on the landing gear plate than with a one piece design. Also what tial wheel assembly are you guys using? I was very surprised that one didn't comne with the kit.
jmw[8D]
jmw[8D]
WA
RE: Composite-Arf 2.3 Construction
I layered the entire landing gear area with a single layer of
Kevlar cloth and epoxy and then made a 1/4" aircraft ply
plate that sits on top of and spans
the two gear pieces (side of fuse to other side of fuse and as wide
as the gear channel in the bottom of the fuse) and
is pierced by the four landing gear bolts. This requires longer
bolts. Don't remember the exact length.... Then used large
washers under the bolt heads to further spread the load over
the ply plate.
Bruce
the ply plate.
Bruce
ORIGINAL: bhanley
the ply plate.
Bruce
the ply plate.
Bruce
jmw
My Feedback: (18)
I did not glass or reinforce my landing gear mount. All is well after 100 flights. Nothing about this plane is meant to be crashed or abused, but it is surprizingly tougher than I thought it would be. I got the graphtech tail wheel and carbon stab tube.
joe
joe
My Feedback: (31)
Helllo John,
I know it can be tempting to reinforce an existing construction that might appear weak.
In this case dont do it!
The Composite ARF line of aircraft is proven to be well engineered there is no need for additional strenght of the landing gear plate.
If you do choose to reinforce, The result will most likely be disastrous the day when you will have to do a rough landing.
Instead of the landing gear plate collecting all force and break like a fuse, it will distribute all force out to the fuselage and know you will have a mess to clean up. Thrust me i have seen it happen.
The following text is from the instruction manual, Please follow it , these guys know!!
The landing gear mount is strong and doesn’t need any extra reinforcement. You have an extremely light weight fuselage, and the gear loads need to be led into the structure gently. No glue joint needs to be stronger than the materials that it is attached to, as it would just result in increased weight for no advantage. The landing gear is a fairly flexible design, which works very much like shock absorbers. This plane is not made for crashing, but the landing gear will take some hard landings without problems. Do not change or modify it, as the results would only be negative. We had plenty of time and experience to engineer the strength needed in this area -and we did!
Best Regards,
Niklas Nyroth
Composite-Arf Field Rep
Best Regards,
Niklas Nyroth
My Feedback: (38)
I agree, leave it alone. It is stronger than the surrounding fuselage already. I have 3 extra's. I have landed all of them hard enough for the landing gear to flex up into the edge of the fuselage 1/2", damaging this area of the fuselage yet the landing gear plywood bracket assembly held. All you will be adding is weight and not gaining any fuselage strenth. Just my two cents worth.
OK, I'll leave gear structure as is. Only thing I changed in the gear department so far was to go to slightly larger diameter washers under the landing gear bolt heads. Stock ones are a bit small, not much bigger than the bolt head itself. I have superficial damage to the gear legs themselves where they chafed during transit. Not serious but would like to polish out if possible. Anybody with suggestions on this??
jmw
jmw
My Feedback: (31)
John,
You can easily fix most scrape marks with some wet sanding and then rubbing compound then end with some polish/wax.
Start out with 400 wet sand then work your way to at least 800, then compoound and polish as needed.
Good luck,
Niklas
Good luck,
Niklas
OK, I'll try a micromesh kit we use to repair scratches in aircraft plexiglass windows. Should work fine.
Found a really cool tailwheel assembly at http://www.cactusaviation.com/Produc...els/wheel.html
jmw
jmw
My Feedback: (119)
Hi guys.
Am just ordering the last of the stuff I need for my 2.3 jr scheme. I can get some nice'n lite wheels but they are 4.33" does anyone know if that will fit ok in the wheel pants.
It sure is a nice model huh.
Mattyb
Mattyb
Matty, I think you can use up to a 5 inch wheel, I am going with 4.5 Dubro Low Bounce wheels on mine. Did you end up going with the ZDZ 60 or the 80? I was curious as to how it balanced. Also, what tail wheel did you go with?
jmw
jmw
I was going to order some custom standoffs from Aerografix http://www.aerografixs.com/ and was wondering if I need to add additional right thrust. The motor domei s slightly offset to the right on the 2.3, haven't measured the angle yet but I think the ZDZ 80 I'm usingi s going to need more. How much rightthrust are you guys usingwith the bigger engines?
jmw
jmw
My Feedback: (20)
NC
These are the wheels going my Yak. 5" superLight big scale airwheels from Kavan. Take a look half way down the page > http://www.hobby-lobby.com/wheels.htm
HTH
HTH
John,
I ended up buying the zdz60, price was to good to pass up. it is being sent to me soon. as for tail wheel it looks like i will get the one from Precision Aerobatics aswell as the wheels which will be 4.33" . wont know how she will balance yet as am waiting for all this to come from other side of Australia. and the muffler is still 3 weeks away, but what a beauty it is.
I am thinking that i will just make some out of hard wood. or go buy some solid Aluminium tube stuff from a hardware place. Make it up that way. I dont think its all to hard. People have made them out of oak dowel.
ORIGINAL: Mattyb
Hi guys.
Mattyb
Hi guys.
Mattyb
jmw
WA
On eng stand offs - suggest that you look at Lowes or a good hardware store in
your area for nylon spacers/bushings. Have tested them for resistance to
gasoline and for compression stability and they hold up. They are cylindrical
in shape, come in various lenths and drilled down the center. The center hole
size is varied but I tend to use 1/4" for 1/4x20 bolts. These offer a light,
simple and cheap solution - look OK as well.
Bruce
Bruce
ORIGINAL: bhanley
Bruce
Bruce
John
those bushings sound like a great idea. will have a hunt for them tomorrow. its not a matter of money for me but more about timing, i have 10 days off over xmas and i always have to mail order my stuff and i need it all by then so i can start building . not rushing or skimping on anything, but if there is a quicker easier way, thats what i will do
hey bruce,
What section would those nylon bushings be in. i know what they are but cant think what they are usually used for. had a quick hunt today and couldnt find any.
Matt
Matt
