Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Extreme Flight 87" Yak 54 - Build & Fly
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 01-02-2005, 03:25 PM
  #251
eb542
eb542's Avatar
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
Quick questions.... 1) KS1060 2) Futaba FM receiver 3) Smoke on Tuned pipe
1) Why does everyone talk about the KS 1060 pipe and not the KS 1050? According to the info posted on the DA web site, the 1050 should be the one!!!
KS Baffled Tuned Pipes
#1010 15cc per cyl $98.00
#1015 25cc per cyl $120.00
#1025 30cc per cyl $135.00
#1050 50cc per cyl $160.00
#1060 60/70cc per cyl $175.00
#1090 125cc per cyl $245.00
2) One more thing, it looks like most people will be using PCM RX, this is my first gas plane, is there any problem with using a standard Futaba 127 RX if installed away from ignition module?
3) OK last question...... hey I got to start somewhere right! Can you put a smoke system on the KS 1060 pipe? According to the pics in this tread, I don't see any fittings.....
Thank you all.
Old 01-02-2005, 04:36 PM
  #252
Mokken
My Feedback: (63)
Mokken's Avatar
ORIGINAL: eb542
Thank you all.
It's not the pipe, but rather the header you will need to get if you want to run smoke. Call DA and they will hook you up!!!
FM should be no problem, I've ran it before without issues.
Old 01-02-2005, 05:31 PM
  #253
Mudsurfer1234
Mudsurfer1234's Avatar
so the smoke fluid goes into the header? seems like things are pretty hot in there, would that mean i can have smoke on the canister without wrapping it in copper tubing?
and do i have to call DA only during business hours? that would be hard for me to do
Old 01-02-2005, 06:53 PM
  #254
Mokken
My Feedback: (63)
Mokken's Avatar
ORIGINAL: Mudsurfer1234
The header has a nipple you attach the smoke line to, you don't have to wrap anything, it's hot enough. And yes you will have to call DA during business hours. They are 3 hours behind you, so I'm sure you will have plenty of time to call.
Old 01-02-2005, 07:41 PM
  #255
vatechguy3
as for the size, the canisters and pipes are made in europe to limit noise, so in order to get maximum performance from them you must order them one size larger than listed. thats why there is a 125cc pipe there. those with da 150s will run two of those. for my da 100, i ordered ks 70cc cans. so for a da 50 you would also want a 70cc can or pipe.
tony
Old 01-02-2005, 08:03 PM
  #256
flyinrazrback
My Feedback: (69)
flyinrazrback's Avatar
Also, as it was explained to me by Dave at DA, the majority of the cannisters are overrated in their capacity. He said a 75cc can is more like a 60cc can, 50cc more like a 40, etc, etc, so thats why you go up one size on the cans.
  #257
Mudsurfer1234
oh yea , i forgot they were in the "Desert" so i CAN call awesome!
Old 01-02-2005, 09:35 PM
  #258
Bosshossv8
My Feedback: (10)
Nobody answered the P-P servo horn question on compatibility. Is it a phenolic??
Aerosplat:
I want to see a picture of the Stabs from the bottom looking up....I want to see if the geometry of the stabs is exactly like the the 68. THat is, the inward cut on the stab from hinge root to TE going inward to the rudder. On the 68 it is a straight line , is it the same ???
Also when crossing the the P-P wires will they touch each other and rub??
Are the stock DA Spacers the right length or do we have to cut them??
THat is enough for now, I am enjoying the afterglow of flying my 68 all day today in Chicago.
24 Yak , all Yak, all the time, nothing but, YAK-54.
Old 01-02-2005, 09:40 PM
  #259
going vert
going vert's Avatar
They must be phenolic. Just means you need to buy an aluminum hub for the servo. I won't mount the phenolic to a plastic disk.
Nelson makes the hubs.
Old 01-02-2005, 09:56 PM
  #260
Mudsurfer1234
Anyone using the carbon fiber spinner from EF? or ANY one? do you have to cut them so prop goes in? it doesn't look like they are cut out for the props
Scott
Old 01-02-2005, 10:06 PM
  #261
Mokken
My Feedback: (63)
Mokken's Avatar
Scott
You have to cut them, they are Pete Model spinners.
Old 01-02-2005, 10:12 PM
  #262
Mudsurfer1234
i went on his site, they say you can request them cut, are all cuts the same? i plane to use a carbon fiber prop, but might use wood at some point, would i have to modify it to work for all kinds or is it one fits all. cuz i had a few small spinners that owuld work with APC but not wood and vise versa
Old 01-02-2005, 10:18 PM
  #263
Aerosplat
My Feedback: (12)
No time to take a picture right now. [&o] The root rib on the stab is a straight line, but not 90 degree to the hinge line. It is cut on the same angle as the fuselage taper so the hinge line is at 90 degrees to the center thrust line.
The P-P arm is phenolic, just like the control horns. It screws into a standard servo wheel with 4 screws at 90 degrees. This is how Chris has his mounted. It has spacers to set the two halves the same spacing as the control horns so the ball link will mount in between. The servo wheel will be sandwiched between the two halves with the spacers. Very secure arrangement. Yes, the wires will rub where they cross. Some heat shrink and light grease will prevent any chafing.
The stock DA spacers ( 2 1/2 " ) are the right length.
I have the 4" CF PETE spinner I picked up from Chris. Yes, you have to cut the slots for the prop. go to troybuilt models.com and click on Giant Scale, then spinners. He has an excellent tutorial with pictures on how to make the cuts.
Old 01-02-2005, 10:46 PM
  #264
Mokken
My Feedback: (63)
Mokken's Avatar
If you have it cut for a Menz style prop it will fit any other prop you decide to use.
Old 01-02-2005, 11:46 PM
  #265
sillyness
My Feedback: (25)
sillyness's Avatar
How are the wings constructed? Have you verified that there is sufficient glue, etc in the shear webbing for all the high G stuff you see in the Yak vids?
Old 01-03-2005, 10:19 AM
  #266
Maudib
My Feedback: (51)
Maudib's Avatar
Not true Mokken...
Several props out there including Bambula and MSC will not fit the Menz cut... I know because I have a CF spinner cut for Menz... neither will fit...
ORIGINAL: Mokken
Old 01-03-2005, 10:23 AM
  #267
Mokken
My Feedback: (63)
Mokken's Avatar
ORIGINAL: Maudib
Not true Mokken...
ORIGINAL: Mokken
Sorry about that... I should have said "most widely used" (Mezjlik, Menz, NX)
Old 01-03-2005, 11:01 AM
  #268
john316
This may be a stupid question, but do any of you people actually have this aircraft?
Old 01-03-2005, 11:10 AM
  #269
Mokken
My Feedback: (63)
Mokken's Avatar
ORIGINAL: john316
HAHA....that made me laugh..
I think a couple people have got there kits.
Old 01-03-2005, 03:38 PM
  #270
Bryant330L
My Feedback: (126)
Bryant330L's Avatar
John if you read around on these forums you will quickly see that this is by far the best airplane on the market.... that nobody actually owns. And..... you would be silly to buy any plane other than this one....... even though if you haven't been on the magical list for months you can't buy one.
Old 01-03-2005, 03:56 PM
  #271
wgeffon
Eric,
Whats up with all the hostility I see in your posts lately regarding EF?
ORIGINAL: Bryant330L
I agree with you on that
You still have me agreeing with you.
Even though if you haven't been on the magical list for months you can't buy one.
What does that mean?
Old 01-03-2005, 04:05 PM
  #272
Mudsurfer1234
does anyone know how many poeple are on the waiting list yet? and how many yaks are on board? i want to try and figure out if im getting one of the first shipments, i have had many people tell me both things, yes and no, so i don't know.
And Mokken, thanks for the TBM site tip, but looking at your avatar, i get the feeling of bein yelled at by a teacher at school. weird eh?
Thanks alot guys!
Scott
woo hoo! first day in school in over 5 weeks!
Old 01-03-2005, 04:21 PM
  #273
Bryant330L
My Feedback: (126)
Bryant330L's Avatar
Wayne I don't know why you think my post was "hostile". You know I think that Chris is a great guy. I just find it amazing how many people think this is the best plane since sliced bread when very few have even laid eyes on it. I guess too many people believe everything they read on the net. I bought into the hype and ordered the 68" Yak only to find that it didn't fly as well as everybody said it did. Oh well, live and learn, that is what I get for paying $350 for a small glow plane.
Old 01-03-2005, 04:23 PM
  #274
Maudib
My Feedback: (51)
Maudib's Avatar
Hmmmm...
Well there sure seems to be a lot of excited people on this thread and not a cricket fart on the "other Yak thread"...
I suspect there will be a lot of sour grape mashin' in the next week or so judging by the pics of one of the very first recipients of Yaks that passed Chris' high standards.
Already I'm excited about the extras that sure add up to value:
Awesome Phenolic Control Horns pre-slotted... just glue them in...
Offset Servo Arm
Wing, Stab and Fuse bags
Carbon fiber wing & stab tubes
Composite Landing Gear
Titanium pushrods
Intergral Pipe Tunnel
Pre-drilled Hingepoints
Lightweight construction
Sure seems like a heck of a deal for the extra $250 PLUS knowing you are supporting future development of great flying aircraft... I feel SOOOOO bad for those who won't make the first boat (which is supposed to leave China in the next few days)...
A second batch is already under construction though so those who are ailing may still get to fly one this spring...
Old 01-03-2005, 04:41 PM
  #275
john316
OK, let me see if I got this right. If you could buy this aircraft, which you can't, then it would be the greatest aircraft you never owned and fly much better than other planes you never had? And the best part is it won't cost you anything not to own it!
Seriously though, all that really counts is that apparently everyone is enjoying this thread! More power to 'em.
John
