Extreme Flight 87" Yak 54 - Build & Fly
#3176
RE: Extreme Flight 87" Yak 54 - Build & Fly
Dave about where did you place your batteries with the Hide canister ? I used the KS 75 can and mine is bigger and set back futher but about the same weight.
I'm at the point of locking down all the wires and stuff for the innards of the fuse and need an idea where I
should stuff the batterey.
The KS /MTW 75cc cannister needed some mods to get some airspace around it but with out cutting the header or the plane up it worked out and it's right on the CG.
I guess I just need some input to where the CG ends up with the stock Muff or Can up front.
Den
Den
#3177
NY
Den,
I have an MTW "?" mark header and can for this plane. My header doesn't show the angles you have at the can intake. Is yours stock, or, did you cut and weld to get that orientation?
#3179
IL
That is the failsafe setup.
3 leads plug into the receiver.
1 lead is for charging
1 lead 14 guage is for the battery
and the switch is connected directly to the regulator.
call if you have any questions.
Drew
Drew
ORIGINAL: jpa2002
Drew, why do you have 4 leads coming out of your regulator and then the switch? I only have two leads and my switch?
#3180
IL
inside the fuse in a plastic antenna tube.
ORIGINAL: jrjohn
How are you guys running the antenna wire? if somebody has a nice inconspicous method, I'd love to see it.
John
John
#3181
ORIGINAL: Apples
Den,
Den,
I cut and welded it only because the it didn't line up by 1/2 the diamiter , I called DA to see what matierial it was ans they said it's stainless steel.
I have a small welding setup so I went for it.
The Chip Hide Can has a smaller Dia @ the back so I guess it fits better past the gear block I just went with what I had.
I used High Temp 600 deg RTV silicone blobs to secure it and it's not going anywhere.
Den
#3182
NY
Den,
Thank you for the reply..I understood from DA that the TMK header and can would lign up perfectly in the 87". I guess it doesn't.
#3183
TX
Bill,
I am in San Antonio as well. I'm at Randolph for a few months for instructor training. I have a Yak coming this week as well. I'd like to ask you a few questions about your set-up. I'll send you a PM. Thanks Nick
#3184
Anyone who is after a perfectly lined up header for the Yak may wish to contact KS. I have spent some time working with them to get it spot on as their new pipe is so wide it needs to be perfectly centered and i am selling them as part of a combo deal with the Yak, all sold by the way before anyone starts asking questions[8D]. Anyway we got through four of them and it fits perfectly, one piece steel cut to any length you want.
#3185
AZ
ORIGINAL: J. AVANT
Nice job Bill, Where did your batts end up with the pipe ? I have the same setup. Where did it balance?
Good to hear from you !!! I have 2X 4400mah Li-Ions one on the motorbox side and one on the top of the motorbox. Cg is on the trailing edge of the yellow strip. Test flew it today, and it felt great !!!
-Bill
#3186
WA
Few problems are keeping me from flying my Yak....first one of my brand new Hite 5945 quits when I was setting up the radio then now I can get the engine to start. bear in mind that this is my first gas engine.
ZDZ 50 with Falkon ignition. 6v to ignition using regulator. How can I check and see if my ignition OR the sensor is bad? Thanks in advance
#3187
KY
ORIGINAL: WaPilot
#3188
TX
Same, glad to hear your response. I saw your post a while back about the pipe. Is your motor new? and did you seem to have a on the pipe off the pipe feel when in a hover. If your motor is new i'm sure it's to early to tell.
Are you running a true turn spinner too. Did you need it for balance? Sorry for all the questions.
#3189
Wayne,
I plan to use the stock (DA) muffler: we don't have noise restrictions here, and I think the engine will be easier to tune. Do I need the extra power of the cannister, or you guys use it for noise restrictions?
Thank for the info.
Thank for the info.
#3195
WA
can't tell since I can't get the plug out... Called you back Ron but didn't answer. Which vinyl u want?
can I get the plus from auto store? then what size?
#3196
KY
ORIGINAL: WaPilot
crap! Looks like I need a special spark plug wrench to get the plug out ! any suggestions on where to get this? thanks!
#3198
WA
You may have to push start it.
Nah... I already tried it. Had my kid jump on the fus then rollingdown the hill but no luck
Even tried to have my neighbor kid stick his toung on the plug but no spark.....
#3200
My Feedback: (28)
Find someone who has used gas engines close to you that can help you . You dont want to mess up your engine or have trouble when you get it ready to fly.
