Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Extreme Flight 87" Yak 54 - Build & Fly
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 03-27-2005, 11:23 AM
  #3701
wgeffon
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
Mike,
I used to use them on 8411's, 4721's etc... They are called output shaft supporters.
I havent seen them used by anyone in a long time though.
Maybe I am missing something but, mine seem to be fine with the old cases and the pull pull wire on top of the servo arm.
Old 03-27-2005, 11:38 AM
  #3702
bodywerks
bodywerks's Avatar
ORIGINAL: hw123
Here are a couple more pics of another one finshed ready for its maiden flight today.
Nice plane, but what are "Fromenco" batteries??? Who did your graphics?
Old 03-27-2005, 11:40 AM
  #3703
DrScoles
My Feedback: (18)
DrScoles's Avatar
The way I see it, if the big dogs and their 40% planes are doing fine with the servos the way they are, doubt people will have a problem with these planes... Although it does make sense to keep the push-pull wires as low as possible.... This is all fairly new ground for me... I did build a 1/3 scale sukhoi, but it only survived around 40 flights.... so I can't wait to start learning all this 3D stuff
I was hoping to get this thing out this week for a first flight, the weatherman feels otherwise......[]
Wayne, will Chris have the bigger yak prototype at Toledo?? That would be fun to see.....
Mike
Old 03-27-2005, 11:46 AM
  #3704
bodywerks
bodywerks's Avatar
ORIGINAL: matus777
"First thing is, for those of you using the SWB rudder servo arm, why aren't you mounting the ball links on the bottom of the servo arm???"
Bodyworks are you using the SWB arm and if so where did you place your exit slots for the cables relative to the manual directed cutouts?
I cut the slots right where they tell you to, and yes, I am using SWB and, YES I mounted my ball links on the bottom of the arm. changing the height of the mounting location by 1/4" at the servo makes about a 1/128" difference, or less at the fuse cutout, if that's what you are worried about.
BTW, I have just the 8611 on my rudder. I am not worried about that wear so much right now, but I will ask JR if they are giving any tops out at Toledo. This servo has a TON of slop at neutral!!! With the cables plenty tight, I can move the trailing edge 1/4" in each direction! MY Hitecs, while WAY louder, don't have that slop.
Old 03-27-2005, 11:56 AM
  #3705
bodywerks
bodywerks's Avatar
ORIGINAL: Torqued-Up
ORIGINAL: bodyworks
... The Smart-Fly goes between the battery and the switch for the ignition...
Also, make sure the Smart-Fly unit is on a Rx channel that provides 100% positive signal, like the landing gear switch... Not one that is on a knob... Been there, done that...
Actually, the on/off switch is supposed to go between the battery and smart-fly>this is so you have a positive power cutoff from the smart-fly, which will drain the battery even with the receiver off...that much I know!
Anyway, I got it fixed, but not without some serious solder surgery!! I didn't account for the switch so now my sleek wiring setup is looking like a mess! Oh well[]
I have pretty much got everything setup, except the pipe and fuel line routing, and I removed the engine to epoxy the firewall and such. hopefully the wife will let me work on it tomorrow so I can get it done!
Gee, I guess I'll have to re-wire all my airplanes that have a Smart-Fly ignition cutt-off...
All my airplanes with the Smart-Fly unit are wired in the manner I have described and I've never had an issue with the ignition batteries being drained...
Buena Suerte...
Mark
The drain they speak of is likely a few milliamps, so you probably won't notice it, plus, you still have the added safety feature of a second cutoff. But recheck your instructions...it is the way I say
  #3706
wgeffon
ORIGINAL: DrScoles
Mike
I am not sure what he is bringing for everyone to see.
My guess is yes it will be there.
Bodyworks,
Fromeco is somewhat of a new guy on the Li-ion battery market.
Drew has been using his stuff for a long time and seems to really like all of it.
Last week I had a RX pack go bad in my 40% so I went to grab a spare that I had lying around. Long story short, all of my spares had problems.
It was time to switch to Fromeco.
His prices are MUCH cheaper than the other brand and the packs have matched cells.
I got the new stuff here on Friday and flew them yesterday. 2-4800 packs and one 2400 Ign pack.
6 flights on a 40% plane running 9 large digital servos and at the end of the day I was reading 7.6V under a one amp load.
The TX battery is the limiting factor now.
Good stuff!
My Yak has Poweflite batteries in them now but since they are out of business I will be switching to Fromeco's soon.
Old 03-27-2005, 12:43 PM
  #3707
jpa2002
My Feedback: (115)
jpa2002's Avatar
Torqued-Up, yes I do fly behind Salem, but I also fly at a field in Bedford that is much better to me. The field behind Timber Truss is not that great!
Fromeco has the best customer service around, and Kurt is quick to respond to emails. Go to www.fromeco.org to check out their products. I love their stuff, as it is a quality product.
How do you guys get an original quote in your message with the words highlighted or underlined?
thanks
Jon
Old 03-27-2005, 01:51 PM
  #3708
vertical ts
My Feedback: (50)
Has anyone ordered the DA logo in the "crushed ice" vinyl?I really like the look of it but have not been able to get a responce from the graphics place that EF uses.Are the any other places that use that type of material?
Old 03-27-2005, 03:23 PM
  #3709
stomper
My Feedback: (20)
Try Kirbys > http://www.kirbysgraphics.com/
HTH
Old 03-27-2005, 03:45 PM
  #3710
wgeffon
www.aero3Dgfx.com
Old 03-27-2005, 03:53 PM
  #3711
jpa2002
My Feedback: (115)
jpa2002's Avatar
I get all of my graphics from aero3dfx, and I have been very happy with their service. Just ask, and I am sure they will cut whatever you want.
www.aero3dgfx.com
Jon
Old 03-27-2005, 04:01 PM
  #3712
vertical ts
My Feedback: (50)
Thanks guys!
Old 03-27-2005, 05:15 PM
  #3713
BBriBro
ORIGINAL: wgeffon
Bodyworks,
Wayne, I think Bodyworks had reference to the Typo it's spelled Fromenco on his airplane !! I think it was a rhetorical question.
Old 03-27-2005, 05:17 PM
  #3714
wgeffon
ORIGINAL: BBriBro
ORIGINAL: wgeffon
Bodyworks,
LOL.. Now that I look at it I think your right.
Oh well. Maybe someone who didnt know about Fromeco does now.
Old 03-27-2005, 08:55 PM
  #3715
bodywerks
bodywerks's Avatar
ORIGINAL: bodyworks
ORIGINAL: bodyworks
Buena Suerte...
Mark
I decided to measure the drain they speak of...including the smart-fly regulator, you're looking at 6.3 mah....not much.
Old 03-27-2005, 08:56 PM
  #3716
jpa2002
My Feedback: (115)
jpa2002's Avatar
Has anyone tried the new snaplock's from Slimline. These are used to keep connectors from pulling apart. I used heat shrink on the majority of mine, but I am going to use these on the ailerons. I guess you could easily glue or epoxy these down also.
Check em out!
Jon
ID:	250179   Click image for larger version
ID:	250180   Click image for larger version
Old 03-27-2005, 09:00 PM
  #3717
bodywerks
bodywerks's Avatar
ORIGINAL: wgeffon
Bodyworks,
LOL!!!!! I know what Fromeco is, I am using these batteries that Kurt builds myself...my question was what is fromeNco, as that is what the decal says on hw123's plane
Old 03-27-2005, 09:05 PM
  #3718
bodywerks
bodywerks's Avatar
here are those wire clips I was talking about and one of the places I used them. I found them at ACE hardware...
ID:	250186   Click image for larger version
Old 03-27-2005, 09:09 PM
  #3719
jpa2002
My Feedback: (115)
jpa2002's Avatar
Yes, those are excellent, but like you said, glue them down, as the sticky tape on them does not hold up well.
Jon
Old 03-27-2005, 09:13 PM
  #3720
basmntdweller
My Feedback: (9)
Those look pretty good! I'll look for some tomorrow if I can break away from building my Yak. I didn't get a lot done today so it'll be a long day tomorrow to finish it up.
Matt
Old 03-27-2005, 09:15 PM
  #3721
bodywerks
bodywerks's Avatar
I got everything done now except the final mounting of the Rx battery and the decals. I was within 2 or so ounces of my origional estimate...15lbs, 8.2 ounces. A little heavier than I wanted (remember, though, that I am using the Hyde silencer), and I may have to sacrifice another 2 ounces by switching back to the dubro wheels...the Dave browns don't like the 15 pounds!!!
I also will have to mount the battery about half way hanging off the end of the firewall to get this thing to balance at 7 1/8"...hmmm
Here's the aircraft mechanic in me at work... I used .025 stainless safety wire to secure the 1/4X20 bolts at the firewall. This way I didn't have to overtighten and crush the ply and I don't have to worry about them coming loose. I later isolated the wire with a dab of silicone at each bolt to prevent any harmonic vibration...
ID:	250205   Click image for larger version
Old 03-27-2005, 09:22 PM
  #3722
jpa2002
My Feedback: (115)
jpa2002's Avatar
Do you guys find it necessary to run a fuel filter if your fueling setup has a filter system on it?
Jon
Old 03-27-2005, 09:28 PM
  #3723
Yak Man
Yak Man's Avatar
hw123,
Where did you get the White JR decals on the rudder? Are they vinyl and what is the demensions of the JR logo?
Doug
Old 03-27-2005, 10:09 PM
  #3724
basmntdweller
My Feedback: (9)
I was wondering about the fuel filter issue as well!
My firewall seems awfully soft also. I read where someone suggested a couple small dowels and that got me to thinking. I am planning to drill four small holes around each bolt hole and epoxy in a short piece of carbon rod. That should be much stronger and more crush resistant than a dowel. I have some .080 carbon that should be just about right.
Does the ignition box need foam padding or anything? It looks like Drew's box on his site has mounting ears on it. Mine is just a plain box.
DrScoles, did you do anything to keep your elevator extensions from falling back inside the fuse when your stabs are off? I can't use the 24" extensions I originally bought, they are just too short. I'll have to get a pair of 36" or just double up extensions and get a couple more 12"ers. I wonder how much power loss is in an additional connector?
Do you use tygon inside the tank? I cut a piece and put the clunk on it but it's too stiff to fall on it's own. Instructions with the gas stopper say to use the black stuff (brain fart, I can't think of the name). The next size down in tygon might be flexible enough but I don't have any handy.
Matt
Old 03-27-2005, 10:25 PM
  #3725
hw123
JDS158, I got the JR stickers from Horizon Hobby and they are 12'' they a couple different sizes of them.
