Extreme Flight 87" Yak 54 - Build & Fly
#3751
RE: Extreme Flight 87" Yak 54 - Build & Fly
I have been using nylon screws (plus an O-ring) to secure canopies and cowls on all my current planes, it works great. I drill & tap the wood, then put thin CA, and finally I re-thread with a metal screw. That keeps the Nylon screws just tight enough.
#3752
ORIGINAL: DrScoles
So how many times should I have to flip this motor over before I see fuel goiing to the carb???
Thanks, Mike
Thanks, Mike
Mike,
Try this for a starting sequence.
* Throttle open all the way. Choke closed. Ignition off.
* Pull the prop through compresion about ten times.
* Throttle idle. Ignition on. Choke closed. Try and start the motor. It should pop after several flips. It will die after it pops because the choke is closed.
* Choke off and after a few more flips it will be running.
If not, Check all your plumbing. Make sure every fuel conection has a tie wrap on it. Even inside the tank.
I have 8 tie wraps on my 2 line fuel system.
#3753
My Feedback: (18)
Oh Boy! Just ran the motor in the front yard for a few minutes.. I'm sure the neighbors are pleased.... It started on the second flip after choking..... very nice! I ran it up a couple times after it warmed up and held the stabs behind my ankles.... awesome ! I can't wait to see this thing climb!!
I didn't touch the needles... I got right at 6300 rpm full throttle... with a 23x8 bolly.. lawnboy ashless 36:1... that sound about right? It idled perfectly, I do not plan on touching the needles....
Come on nice weather!!!!!!!!!!!!!!
Mike
Mike
#3754
My Feedback: (28)
I just went about fixing mine a different way I did not add a lot of weight to the tube so not to hurt it i wet the inside and let the weight un twist the tail a little at a time . It takes a little longer to do it this way but the twist does not go all the way to the engine box so why twist the whole fuse ?
#3755
NJ
Hey guys,
I just got a Yak Pit Kit for my Yak from Kregg.
I ordered it from him last Wednesday.
It looks awesome. A very nice color manual is included in the kit
that explains every step, and then some, of what needs to be done
to make this perfect.
It even has notches that will fit the wood notches inside the
Yak canopy and make for a perfect and fool proof fit.
I can't wait for the matched pilot from litepilots.com to arrive and put this thing
together. It should look fantastic on the plane.
I'll post more pictures as soon as it is ready.
Stratos.-
Stratos.-
#3756
My Feedback: (12)
IL
ORIGINAL: Stratos
Hey guys,
Stratos.-
Hey guys,
Stratos.-
How Much $$$$$$
#3757
My Feedback: (12)
IL
Need HELP:
Without reading all the pages:
I am looking for the person that has the (RED BULL) ALL WHITE YAK as a friend has bought one and we are going to RE-cover over the white covering and wanted to know HOW EASY it was/will be.
KY
ORIGINAL: ROGER RUSSELL
Need HELP:
Need HELP:
Edit, I just did the research, [link=http://www.rcuniverse.com/forum/m_2408226/mpage_89/key_/tm.htm]CLICK HERE[/link] for page 89, and look at post # 2649 for his pics.
Brian
#3759
PA
anyone know where i can get a good 3D deflection meter that measures in degrees? i have one from great planes or somthing, but it's too small and i would like some better quality.
Scott
Scott
#3760
My Feedback: (115)
VA
For the question on the pull-pull cables, I have attached a pic of my setup. I also ordered the wire from www.swbmfg.com and it came with nice stainless crimps. You can get a good crimp tool in the electrical section at lowes that will make good solid crimps. I used my old set of Klein crimpers for non-insulated wire, and you can see the results. I always loop it a couple of times. The 10' of wire from SWB is plenty of wire, and again the crimps are really nice. Also, you cannot tell it by the pics, but I make 2 crimps at 90 degrees to each other.
For all of the cowl cutters, see the pics of my cowl cutout. A few years ago, I butchered several cowls, before I was told use the dremel tool. You can use one of those roto-zip bits to do the ROUGH cutting, then you can use the drum sander with fine sandpaper to do the detail work. I think they do a really nice job. Anyway, my cowl cutting has come a long ways in 2 years.
Jon
Jon
#3761
My Feedback: (115)
VA
MudSurfer, go here http://www.rcaccessory.com There is a menu on the side, just click on "throwmeters." They have some of the nicest ones that I have seen.
Jon
Jon
#3762
My Feedback: (12)
IL
I PM'd him for info.
ORIGINAL: BBriBro
That is Ricmussman
Brian
Need HELP:
Need HELP:
Brian
#3763
IN
Firewall revisited......I have not got my engine yet(on order) but for those who are having firewall squishing, perhaps this is an idea[sm=idea.gif]. Seems many are not using the stock CF arms(quantity 4) How about cutting off the arm leaving a round disk and using it for a nice "light" and strong washer for the standoff bolts. That combined with thin CA on the firewall and using the "safety wire" method Bodyworks showed(so you don't have to crank the bolts real tight) sounds like a solution. Just a thought. Not sure if the bolt head is to small for the exsting hole in the CF arms but if so a second small washer could be used to make up the difference.
#3766
IN
ORIGINAL: Stratos
Hey guys,
Stratos.-
Hey guys,
Stratos.-
I don't understand why there is no head?? I mean if the picture can capture everything else photo-realistically.....why not a head? Is it just so the head can stick up into the canopy?
#3768
NY
turbo4,
Yes the pilot's head should stick up in the canopy. You supply your own head, or, bust of your liking to complete the digital cockpit visual.
Go here, http://www.rcuniverse.com/forum/m_27...tm.htm#2814912 to see the results. Look at post #24.
#3769
Stratos,
Drew and I have the cockpit kits coming as well. We will document the process and give you our opinions on the website.
Roger,
If I am correct, I believe Ric's Yak was an standard scheme. I think he rippied all the covering off and started over.
Roger,
#3770
My Feedback: (12)
IL
WAYNE:
HOW MUCH FOR THE COCKPITS?
OK THANKS:
I think he has a scheme picked out and a couple guys in the club are going to cover it.
ORIGINAL: wgeffon
Stratos,
Roger,
Stratos,
Roger,
#3771
My Feedback: (18)
Hey guys,
It event has notches that will fit the wood notches inside the
Stratos.-
Stratos.-
Joe !~)
#3772
IN
ORIGINAL: Mudsurfer1234
Scott
Scott
#3774
My Feedback: (24)
WOW, I didn't read the blog for one day and several ppl are talking about me[:-] Any how I am still here and my plane is coming along well. I have an engine now and it is installed. The radio is installed and programmed.
My cockpit was the one that was used for templates for "Kregg's Cool Cockpit Pics." I will be picking that up tonight I hope. For those that are wondering the kit will be $45.00 I think. Kregg didn't want to advertise a price on the blog because RCU doesn't want us to do that. So PM him if you want one.
I plan to get props, pilot, spinner at Toledo this weekend. Then the "Red Bull" will be off to the painter for cowl and canopy painting
I understand Chris still has a few all white's left[:-] For those that really want one, I would do it soon....... Wayne is right I pulled the white off in the large areas and re-covered in Pearl Blue Metalic and Silver. Then I added stripping to cover the seams. Fianally I added a bunch of Kiby's Customs, and it looks sweet now. I was going to post some pics but I am going to wait until it come home from the painter before I unlease it again...
Have a good day and stopping talkin about me....
#3775
NJ
How Much $$$$$$
ORIGINAL: Stratos
Hey guys,
Stratos.-
Hey guys,
Stratos.-
How Much $$$$$$
It was $45. I think it's a great value considering you need
$40 to get one of these
Kregg was really nice talking to me and making sure his cockpit will be suited for the pilot I choose.
I can't wait for 'Tony' to get here and put the thing together: http://litepilots.com/25civilianp.htm in red
Stratos.-
