Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Extreme Flight 87" Yak 54 - Build & Fly
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 04-06-2005, 05:25 PM
  #3976
BBriBro
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
ORIGINAL: JWilliams
According to DA, cutting the header more than 1" could affect the linear throttling of the motor.
Hmm, maybe I should have just ordered the rear exhaust at that rate, and just let it exit at the back, I was hoping to have the outlet up front, in a more scale like location.
Old 04-06-2005, 06:03 PM
  #3977
747drvr
747drvr's Avatar
Hi Guys,
I'm in the process of installing my elevator servos and I've run into a slight problem . I'm using the Hitec 5945 with the supplied carbon servo arm and the the slot is too far outboard . Did people cut the already wide slot wider ? I'm surprised that I didn't hear anyone mention this unless mine is the only one like this .
Marc
Old 04-06-2005, 06:07 PM
  #3978
Hammbone
My Feedback: (309)
I used the 5945's and stock servo arms. Mine came out fine.
Do you have a pic?
Jim
Old 04-06-2005, 06:09 PM
  #3979
DrScoles
My Feedback: (18)
DrScoles's Avatar
Got three flights in today... the canopy latch aint workin, lost canopy on first flight, had to MacGuyver it to stay on. What brand/size of tubing are you guys using to get the bolts to stay in??? and come out
Is the tailwheel assembly a dubro product?? The top collar came off and the wheel fell off...I actually saw it on take off, so I tracked it down in the grass.... lost the wire that attaches to the rudder though...
One of the four bolts that holds the cowl on is was ovalling out the fiberglass.... should I just lay some glass cloth ont he back side to strenghten it? gonna use a little firmer grommets from radio shack too....
Mike
Old 04-06-2005, 06:16 PM
  #3980
747drvr
747drvr's Avatar
ORIGINAL: Hammbone
Do you have a pic?
Jim
By stock you mean the supplied carbon arms ?
Old 04-06-2005, 06:21 PM
  #3981
jpa2002
My Feedback: (115)
jpa2002's Avatar
DrScoles, get the hard cowling grommets from www.pspmfg.com.
http://www.pspmfg.com/CowlBinders.html
Jon
Old 04-06-2005, 06:25 PM
  #3982
Hammbone
My Feedback: (309)
Yes
ORIGINAL: 747drvr
ORIGINAL: Hammbone
Do you have a pic?
Jim
Old 04-06-2005, 06:30 PM
  #3983
flyingcrazy
My Feedback: (28)
Heres what I came up with it works great . I used small silicone tubing over my bolts two bolts are 1 in. and two are 1 1/2 in. hope this helps .
Old 04-06-2005, 06:37 PM
  #3984
747drvr
747drvr's Avatar
Here's a pic .
Old 04-06-2005, 06:42 PM
  #3985
Hammbone
My Feedback: (309)
That doesn't look right. Mine lines up correctly. I wonder if you could just put the carbon fiber arm under the white servo disc and make it work?
Jim
Old 04-06-2005, 06:49 PM
  #3986
747drvr
747drvr's Avatar
ORIGINAL: Hammbone
Jim
Hi Jim,
Just tried that but it doesn't work. What is the dimension from the root rib to the middle of the slot ( fore and aft middle) measured perpendicularly from the root rib ?
Marc
Old 04-06-2005, 06:52 PM
  #3987
SydDythers
SydDythers's Avatar
Marc,
Nice to see another hoser putting this plane together
Anyhow, I think u are supposed to put the servo disc on the other side of the arm. That will solve yer problem...
Cheers,
John
Old 04-06-2005, 06:53 PM
  #3988
Hammbone
My Feedback: (309)
I measure about 1-5/8ths" from the root rib to the middle of the slot.
Jim
Old 04-06-2005, 06:56 PM
  #3989
SydDythers
SydDythers's Avatar
whoops, mine is actually set up like yours in the photo....no problem with fit.
Old 04-06-2005, 07:03 PM
  #3990
747drvr
747drvr's Avatar
Well Jim and John . My dimension is the same so what the heck am I doing wrong ![:@] Could someone post a pic of a successful set-up ?
Marc
Old 04-06-2005, 07:04 PM
  #3991
Hammbone
My Feedback: (309)
Must be the servo mounts are in a different location on yours????
Jim
Old 04-06-2005, 07:07 PM
  #3992
Hammbone
My Feedback: (309)
I measure about 2-3/8ths" from the root rib to the servo mount at the middle of the slot.
Jim
Old 04-06-2005, 07:09 PM
  #3993
747drvr
747drvr's Avatar
ORIGINAL: Hammbone
Jim
That would be the strange ! Where is your CF servo arm situated in relation to the elevator horn ?
Marc
Old 04-06-2005, 07:10 PM
  #3994
Hammbone
My Feedback: (309)
I can definitely see by your pic that your servo sticks out into the slot more than my servo does.
Jim
Old 04-06-2005, 07:11 PM
  #3995
Hammbone
My Feedback: (309)
The linkage on my c/f arm has a straight shot to the horn.
Jim
ORIGINAL: 747drvr
ORIGINAL: Hammbone
Jim
Marc
Old 04-06-2005, 07:12 PM
  #3996
Hammbone
My Feedback: (309)
Give me a minute and I'll get you a pic.
Jim
Old 04-06-2005, 07:13 PM
  #3997
747drvr
747drvr's Avatar
Did you use the grommets on the servo ?
Marc
Old 04-06-2005, 07:16 PM
  #3998
flyingcrazy
My Feedback: (28)
Heres what mine looks likes the servo is a 5645 . Your servo looks to high is the lead under the servo ?
Old 04-06-2005, 07:19 PM
  #3999
Hammbone
My Feedback: (309)
Here's a pic.
Jim
Old 04-06-2005, 07:20 PM
  #4000
Hammbone
My Feedback: (309)
Yes
ORIGINAL: 747drvr
Marc
