Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Extreme Flight 87" Yak 54 - Build & Fly
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 05-23-2005, 12:18 PM
  #5001
wgeffon
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
You going to the Columbus IMAC??
Old 05-23-2005, 01:20 PM
  #5002
CHassan
My Feedback: (13)
CHassan's Avatar
I might try to make it down, don't think I'll fly, but I might come down to see how the competitions go. In-Laws are moving this weekend so I'll be up in Marion anyway. I'll have to check with the boss.
Old 05-23-2005, 02:14 PM
  #5003
BARCC
Banned
Post #5000!!! Wooeyy!!!
Old 05-23-2005, 06:49 PM
  #5004
chipwill
My Feedback: (12)
Come on to the Columbus IMAC. Should be a great turn out and hopefully I will actually get to practice some sequence flying this week. We shall see.
Chip
Old 05-23-2005, 08:18 PM
  #5005
wgeffon
Looking forward to meeting you Chip.
Thanks for the frequency info. I'm all squared away now.
Old 05-24-2005, 09:22 AM
  #5006
chipwill
My Feedback: (12)
I hope the weather Gods are on our side this week. Memorial weekend typically is wet but our meterologist at work thinks it will be fine on Sat. and Sun, but it is still pretty early, and mother nature does as she pleases.
I have to do alittle mx on the Yak- tighten eng. mounts, rebalance prop. and install a instrumant panel but I should be good to go. Got my new hatch and canopy for the Katana so it will be less ugly than it is now too hehe...
looking forward to a fun weekend.
chip
Old 05-24-2005, 09:55 AM
  #5007
cool3d
cool3d's Avatar
great looking cockpit where i can buy one?
Thank you
Assaf
Old 05-24-2005, 09:32 PM
  #5008
jrjohn
My Feedback: (24)
I have a prop question. I've been flying my yak with a 23x8 NX prop. I thought it was fairly stable in a torqueroll. Today I decided to try a 22x8 3W prop.
I swear it was more difficult to torqueroll, I couldn't get it locked in for nothing
Is it my imagination or does it make sense that the smaller prop would give me less control?
thanks
John
Old 05-25-2005, 06:46 AM
  #5009
BARCC
Banned
I have a question. how many of you guys are running an actual servo to control your choke? Because Tom at Wildhare recommends doing this, because you can operate the choke go figure, and kill the plane in the air if for some reason its on low throttle and wont quit. And IMAC recquires a wat to kill your plane in the air, if something happens. With this setup by Tom, it will kill 2 birds with 1 stone. Thanks!!
Old 05-25-2005, 07:33 AM
  #5010
NE0
My Feedback: (9)
NE0's Avatar
I prefer a fiber optic kill switch. A servo operated choke is nice, but is a tad bit heavier if you use a good servo... and, can often be a pain to install. It's usually quite crowded getting a servo and linkage to both the throttle and choke, and requires a much more "sturdy" mounting scenario for the servo than what you need for a FO kill. Mostly just a matter of preference and ease of install.
Tom
Old 05-25-2005, 07:53 AM
  #5011
CHassan
My Feedback: (13)
CHassan's Avatar
I used a opti kill whitch also. As far as operating the choke, I have a stick with a bit of wire on it, just reach in and flip it. The opti switch, IMHO, is the best way to go.
Old 05-25-2005, 08:24 AM
  #5012
wgeffon
ORIGINAL: BARCC
My 40% IMAC plane has a FO kill in it but its not requied by IMAC.
Old 05-25-2005, 08:38 AM
  #5013
bodywerks
bodywerks's Avatar
Agreed. Choke servo is not only more of a pain to install, but it also may not do you any good in the event of a RX failure, not that that would matter too much, but an out of control plane that goes in deadstick is likely to be a less costly crash. You have this feature with the Smartfly opti switch - if you have no rx signal, you have no engine.
Old 05-25-2005, 09:34 AM
  #5014
Maudib
My Feedback: (51)
Maudib's Avatar
not to mention trying to remember which diretion the switch goes to flip a choke servo... even tho the FO swirch needs a swich, the smart-fly has an led to let you know it's hot...
safety in starting... if receiver is not on the engine won't fire...
Old 05-25-2005, 10:09 AM
  #5015
matus777
ORIGINAL: BARCC
Does this type of thing actually happen in the real world?
Old 05-25-2005, 11:45 AM
  #5016
NE0
My Feedback: (9)
NE0's Avatar
quote:
ORIGINAL: BARCC
ABSOLUTELY! Happens quite often. Has happened to me. All you need is for a throttle linkage to come unhooked, throttle servo to go bad, throttle servo arm to break, etc, and you have no control of the engine in the air.
If throttle is stuck at low/idle rpms, the engine could run a lot longer than your RX battery will. That's a disaster waiting to happen. ALL gas engines should have a means of shutting down from the TX. If you have a plane that's stuck idling, it could run 20, 30 minutes. Some big tanks will run 45 minutes. If it's your last flight of the day, you may not have 45 minutes left in your RX or TX battery.
Tom
Old 05-25-2005, 12:25 PM
  #5017
romanrc
Wayne and Chris
Good look in the XFC
Old 05-25-2005, 02:21 PM
  #5018
BARCC
Banned
It is recquired, I called them and they said yes!! Damnit!! i hate bein flamed out!! (In reply to wgeffon)
Old 05-25-2005, 02:22 PM
  #5019
stomper
My Feedback: (20)
ORIGINAL: BARCC
I run a choke servo on all my gas set-ups. Very simple to do.
I was at the field this morning and a buddy of mine was flying his 40% godfrey Extra and his throttle servo stop working at wide open throttle and no means of shutting it down.
ID:	276387   Click image for larger version
ID:	276388   Click image for larger version
Old 05-25-2005, 02:29 PM
  #5020
BARCC
Banned
Old 05-25-2005, 02:32 PM
  #5021
BARCC
Banned
ORIGINAL: wgeffon
ORIGINAL: BARCC
damnit!! i hate beiun flamed out!! I just called them and they said you have to have one!!
Old 05-25-2005, 04:29 PM
  #5022
torqmeister
torqmeister's Avatar
RCCATS has an electronic switch, which works off the transmitter. Only weighs 1/4-1/2 oz. I have one in my Yak & it works great.
Old 05-25-2005, 04:38 PM
  #5023
Josey Wales
My Feedback: (61)
Josey Wales's Avatar
I use a choke servo on my WH Edge also..Plan to put one in the Yak too!!
Old 05-25-2005, 04:59 PM
  #5024
Maudib
My Feedback: (51)
Maudib's Avatar
Chill BARCC,
What ge stated was that you did require a firber optic kill switch... indeed you are required to be able to kill the engine SOMEWAY...
Either a choke servo, a fiber optic kill, some put a servo activating the manual ignition kill, heck some form of fancy dancy fuel filter with shut off could work...
But what Wayne intended you to read was that contrary to others that use the choke servo method, he uses the fiber optic kill... not the only way to do it, but his prefered way.
It's easy to misunderstand typed messages...
Visit http://www.smart-fly.com and select ignition kill switched to see the type I use but you DON'T have to select...
ORIGINAL: BARCC
Old 05-25-2005, 05:28 PM
  #5025
rmh
rmh's Avatar
I use a choke servo - My ZDZ50 starts one flip -every time using the choke switch - the start up is very quick -even first flight of the day -no stopping and reaching under , etc.
as for weight - be serious - 2 ozs. I am still a 15 .25 lbs total
If you leave on hand at the tx you can hit the Rtx switch during choked BURP and it continues running.
also if you kill it after taxi back -using choke switch - next start is simply switch on --flip - run
simple- reliable - effective
PS if you wanted to you could set fail safe for choke on /engine throttle low - whatever . I fly PCM on everything gas .
