Extreme Flight 87" Yak 54 - Build & Fly
#5552
IN
RE: Extreme Flight 87" Yak 54 - Build & Fly
Nothing against electrics, I own my fair share of foamies. However, I just do not see it for planes this size. I love my DA50 on the MTW TD75 cannister. Flew mine this morning and it just gets better and better.
Jeff W.
Jeff W.
#5554
ORIGINAL: JWilliams
Jeff W.
Jeff W.
#5555
I had a feeling this thread would go electric before to long. You electric guys need to take your skirts off and put your pants back on
This thread was started to support the 99.9% of us who have set the plane up for what it was designed for. GAS
#5556
I can work on my cars electrical system much easier than I can the engine . It isnt a Gas vs Electric anymore than it is Glow vs Gas. It just boils down to what you prefer. I was going to go Gas until my field went completely electric due to noise concerns. That made the decision much easier. With more and more fields being lost to urbanism and noise regulations, electric is becoming a valid alternative...but will never be a replacement for IC.
Of course while I was trying to start my Ryobi glow weedeater this morning....it made me wish I had a Hacker powered version on 8S lithiums.
-Mike
-Mike
#5557
ORIGINAL: Mike Parsons
It just boils down to what you perfer.
Exactly!
Keep doing what your doing Mike. I personally have enjoyed watching and reading about your E planes and projects.
#5558
My Feedback: (50)
NJ
Anyone know of a header for the DA50 that does not break?I am using the mtw flex header and it snapped today after roughly 3 gallons through the motor.Any suggestions would be appreciated
Vertical
Vertical
#5559
Those headers typically last forever .
1 -support front and rear of the can (pipe)
2 -do not use the flex section as an adjustment for alignment - the flex section is for vibration absorption.
twisting and or bending this section will almost always result in a fatigue at the compressed point in the flex.
#5560
My Feedback: (50)
NJ
I guess thats what I did wrong,I did not support the front of the pipe.This was my first plane with a pipe/header set up.I just followed the instructions[&o]
#5561
I'm just kidding with you electric folks. I watched David Payne fly his electric EF 87 Yak in Chattanooga a few weeks back and it was impressive. It had an AXI motor with 4 battery packs strapped around the engine box. It had plenty of power, no doubt about it.
Electrics have come along way in a short time and for people like me( who know nothing but gas and glow) are overwhelmed, so much to learn.....
#5562
My Feedback: (51)
Hang tight,
Electric power is in an exciting stage.... Hi Voltage ESC's, Several lithium pack manufacturers, larger, more powerful and efficient motors, etc are making it quite possible.
As time goes on, pricing will begin to drop on the technology (just as everything else is) and it will cost about the same to build something, glow, gas or electric. As it stands today, I'm not sure I want to invest upwards of $1200 more in order to go electric with my Yak. But when they cost the same to build... with similar all up wieights, GS electric is going to become much more popular. Take a look at this years NATS and check out the power setups of the pros in pattern... Just a step down from Giant Scale requirements.
Not sure it is any different in complexity than other power methods, as with gas you have the ignition to consider as well as breaking in, tuned pipes, etc... with glow you can have issues with tuning, fuel consumption, etc. Seems most of the "E-complexity" is simply selecting the right equipment up front... and there are programs out there to help... like e-calc and motor calc.
As with all techs... e-power can have it's share of failures and headaches... but none more than other power systems.
I'm still an overall value man, and right now GS aircraft is more cost efffective up front and during it's life than e-powered versions.... but as you can see from my posts on the subject, it IS of interets to me, and I keep looking for that magical next step in e-power...
I was aware of Steve's NeuMotor and the BAM... I heard about it last fall I think, but I'm not sure it's out just yet... Put it on one of the new CC 110 HV's and you may just have a monster on your hans... especially if it comes in at an optimal 65 amps. Depending on it's weight, it may very well be a 60cc-80cc gas equivilent and cost about the same sans batteries...
As it is.... a foamie with a few small lipoly packs can fill MANY evenings with top-notch fun and practice. Small, inexpensive brushless motors, ESC's and lipoliy packs have made this arena of e-flight perhaps the most popular out there....
ORIGINAL: SPACE SCOOTER
#5563
OH
Yak at the Nats
Well someone had to represent us, so I flew my 87" yak in Sportsman, at this years IMAC Nats, and yes I was the smallest plane there. Even in Sportsman, all the other planes were at least 33% and up.
I think I got the most out of the plane, and pilot, and ended up 6th out of 18. Take that all you overfed, steriod filled 40 %er's.
I've only been flying the plane for about a month, but I really like it. Some of the differences I noticed, between it and the bigger planes is, it dose'nt track or groove as well as the bigger planes, and because of the light wing loading, it does not handle the wind as well. Lucky for me, at the Nats we never really got above 8-12 kots of wind. Also it does not have near the power to weight ratio the the big boys have. You can really see in the upper classes, why they need the extra power, they have multiply manuevers on the down lines, which require the plane to fly high to start, and all the point rolls and snaps on uplines. I believe IMAC needs more power than 3D, for that very reason.
I think it's a great plane to start flying IMAC with. I'm going to fly Intermediate with it in a couple of weeks, I think it should do it just fine.
#5564
Good show !-- as for the wind - add more power - more speed .
We had our annual IMAC contest two weeks ago in 20 mph wind .
The smaller planes did well -as long as they used power and lots of positioning control.
We set up our YAK with more power to weight than the 40% stuff - you need it to fight the wind drift.
-it takes more skill to fly the smaller models really well .
#5565
harryw13,
Nice job and good luck in a couple of weeks!!
Maudib,
I certainly agree with you and when the price starts to fall I'll be right behind you. For now I'll wait, I am truly happy with my yak just the way it is.
Maudib,
#5566
My Feedback: (51)
Me too... and I sure like that Vrooom-Vrooom.
harryw13,
Maudib,
harryw13,
Maudib,
#5567
Good job Harry!
I wish I could have seen you fly but with being on seperate sites made it hard to see anything that was going on there.
#5568
ORIGINAL: Maudib
#5572
My Feedback: (51)
I was quoting Mike when he said:
Steve Neu will be releasing a 4kw motor soon. The Bam motor will swing a 27" prop on 12S for 65 amps. Static thrust was measured at 45 lbs. They are testing it in a 33% plane. This motor and two 6S packs will be about 800 dollars cheaper than my setup give or take (depends on what they price the motor at.
But if 45 lbs of thrust can be had for 65 amps... then that's pretty sweet....
Perhaps the higher voltage is allowing the more efficient amp draw?
ORIGINAL: KatManDEW
What makes 65 amps optimal? You aren't going to get 4kW on 12s with 65 amps.
#5573
IL
Off topic but might be of interest to electric converts?
One of last years top pattern flyers converted to electric this year. For the last 7 weeks he has been dealing with PCM lockout problems when applying climb power. Keep in mind that he's trying to keep weight to a minimum. Every combination of system elimination/isolation/change was tried including sending the system to a top firm for diag....no answers...no help.
Solution found: The simple solution was discovered by holding the battery packs in hand during ground testing. The packs were mounted in soft industrial velcro in a very low vibration environment. The simple solution was to go back to our basic habit of foam bedding....problem solved. No one knows why this solved the problem but it did.....much frustration ended.
FYI....this issue manifested with ALL battery packs involved so it was not a pack quality issue. Just thought i'd throw this out (all packs were large lipo's)
