Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Extreme Flight 87" Yak 54 - Build & Fly
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 10-20-2005, 07:57 AM
  #6226
ckoerner
ckoerner's Avatar
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
Here is a stress test for the YAK. I don't know if it's one of the most violent manuevers, but close. [link=http://videos.pitsbros.com/craigk.wmv]Stress Test[/link]
The same day Wayne was doing rolling harriers real low. I can't believe there where not any grass stains on the wings. Wayne can really ring this plane out.
Old 10-20-2005, 08:17 AM
  #6227
DrFun
DrFun's Avatar
Wow, that looked cool!
Old 10-20-2005, 12:22 PM
  #6228
GalenB
My Feedback: (18)
I am finally putting my Yak together and am wondering about spinners... Since I am using a tuned pipe it seems that I will need a little nose weight so getting a Tru Turn seems like a good choice. I will also use a 23X8 Mejzlik or a 24X8 Menz prop... I know many are using a 4" P-51 style... How has that one been working? Would a smaller spinner be a better choice?
TIA!
Old 10-20-2005, 03:17 PM
  #6229
coche
coche's Avatar
4" tru turn ultimate style, menz cut, lightened back plate! [8D]
Old 10-20-2005, 05:00 PM
  #6230
torqmeister
torqmeister's Avatar
I have the 4" & the 3 1/2" Tru Turn P-51 style spinners. I think the 3 1/2" looks the best.
Old 10-20-2005, 07:03 PM
  #6231
Josey Wales
My Feedback: (61)
Josey Wales's Avatar
Did anyone have to open up the elevator servo cutouts to allow for maximum throw? Im talking about the slot for the servo arms...I can get 60 deg but I would have to cut a slot in the sheeting to allow the 4-40 bolt to pass thru..
Old 10-20-2005, 08:41 PM
  #6232
coche
coche's Avatar
yes! you have to trim a little bit! here are some pics!
ID:	341748   Click image for larger version
ID:	341749   Click image for larger version
Old 10-20-2005, 08:51 PM
  #6233
Josey Wales
My Feedback: (61)
Jose..thanks for the other pics also..Im not talking about trimming the slot lengthwise..The 4-40 screw that attaches the ball link to the the SWB arm will actually compress the sheeting down..If I want to get the full throw I would have to cut a slot to allow the head of the screw to clear the sheeting..I could just dial the throw down with the dual rates..I have my ATV's at 140%
Old 10-21-2005, 07:18 AM
  #6234
NE0
My Feedback: (9)
NE0's Avatar
Go ahead and widen the slots, I think most of us had to do that, some more than others.
Tom
Old 10-21-2005, 12:33 PM
  #6235
Mike Parsons
Mike Parsons's Avatar
ORIGINAL: ckoerner
Sweet! I love the way this plane tumbles. [link=http://www.epowerflight.com/Media/87yak/yaktumble.wmv]Semi-Anuerism[/link]
A couple of photos to share also. I have the full size and they may cool Desktop backgrounds
-Mike
ID:	341988   Click image for larger version
Old 10-22-2005, 02:50 PM
  #6236
Josey Wales
My Feedback: (61)
Ok..what is the trick to get both elevator servo arms centered? Im using a 9C, SWB arms, and 8611's..I can get 1 arm 90 deg but the other is off by a few degrees..I can however change the one that Im able to get at 90deg to match the other..the only problem with that is I can only get 50 deg of down..I dont want to get a matchbox or use subtrims if I dont have to..
Old 10-22-2005, 03:17 PM
  #6237
coche
coche's Avatar
get a servo programer, or use subtrims!
Old 10-22-2005, 03:19 PM
  #6238
Torqued-Up
My Feedback: (16)
Torqued-Up's Avatar
Adjusting endpoints and subtrim are the only way to get both servos to match through full travel in both directions...
Old 10-22-2005, 03:40 PM
  #6239
Josey Wales
My Feedback: (61)
I was afraid you guys would say that..then basically the ailevator feature is really worthless[:@]
Old 10-22-2005, 04:02 PM
  #6240
coche
coche's Avatar
NOP! ailevator feature gives you the chance to use 2 diferent chanels instead of using just one chanel and you have the chance to adjust sub-trim and end points diferent on each chanel!
Old 10-22-2005, 04:19 PM
  #6241
Josey Wales
My Feedback: (61)
I see your point but I always hear how you should use as little subtrim or end point adj as you need to because you are decreasing the speed of one servo vs the other
I messed around a bit more with the linkage and I had to decrease the endpoint on 1 servo to 130 from 140..I can get 65deg up and 50 down and they are even thru out full travel
Old 10-23-2005, 09:06 PM
  #6242
Prime_Time
Guys,
For the following season I plan on getting the EF Yak. And I have a question on servos. I am getting all new stuff for this plane so I am all ears . I was planning on getting Hitec 5645's all through out the plane. Do you have any suggestions on what to do for a rudder servo. I was looking at the Servo Power Gearbox. If I put a 5645 or a 5625 in the gear box I would have over 655 oz of power. My question is, If I went that route how would I mount it? They cost around 40 bucks, and you also have to get a 3in arm for about 8 bucks. It seems duable, are they worth the extra 40 bucks? heres the link http://www.servocity.com/html/robotzone_servos.html
Prime Time
Old 10-23-2005, 09:10 PM
  #6243
jrjohn
My Feedback: (24)
ORIGINAL: Gasser Flyer
Guys,
Prime Time
PT get a 5955 and an SWB arm. set it and forget it.
JOhn
Old 10-23-2005, 09:21 PM
  #6244
GalenB
My Feedback: (18)
I knew that my fuse has a slight twist in it, but before I worked the twist using Bodyworks technique I wanted to mount the wings and stabs and look at from that perspective. I know from using a level that my wings and stabs are about 3/4 of a bubble off from one another... The wings fits great -- nice and snug. The stabs fit great too, until I looked at them closely... The twist is there, but it's not very bad. However, when looking from all angle I could see that when the elevators are flush with the stabs that they don't line up! I put my Robart incidence meters on the stabs and there is 2 degrees difference between the two. At this point I don't know which one is at the correct incidence...[:@] And only one of the four 6-32 cap screws would thread into the fuse and blind nut...
I know others had the twist -- has anyone else seen the incidence problem?
Old 10-23-2005, 09:43 PM
  #6245
wgeffon
Galen,
My new Yak also has a slight twist. I have not checked the incidence though (and probably wont)
My advice is to go fly the plane as is. See what you think. If you think its doing something weird due to the incidence then you can fix it but my guess is that the plane will fly fine.
You may save yourself a lot of hassle trying to fix a problem that may or not affect the plane in an adverse way.
Also, if one of your blind nuts are stubborn, run a 6-32 tap into it. That should help.
Old 10-24-2005, 06:54 AM
  #6246
Muza
Just quick, the weight requirements in Oz are 7kg (~15.5lbs), any larger and a special permit is required.
Would it be able get under this with a CF spinner, wood prop, std muffler, minus the pants.
Old 10-24-2005, 07:09 AM
  #6247
flat spin
Easy. Mine weighs 15Lb 8 Ounces with KS cannister 250g, Mejzlik prop and Spinner and i run lipo's on ignition and receiver. You could lose wight on the prop and cannister setup and no more is required on the battery side of things. However, you should still have enough margin for redundancy if you wanted to go down that route.
Old 10-24-2005, 07:42 AM
  #6248
NE0
My Feedback: (9)
NE0's Avatar
Mine is 15.25 lbs with the setup you described (CF spinner, wood prop, etc), so if I dropped the wheel pants I would be well under 15 lbs.
Tom
Old 10-24-2005, 02:07 PM
  #6249
Prime_Time
John,
Why not get the new HSR-5995TG Ultra Torque for the same price. With 417 oz of Torque with .12 sec/60 degrees
heres the link http://www.servocity.com/html/hsr-59...ra_torque.html Looks good to me.
Prime time
Old 10-24-2005, 02:15 PM
  #6250
jrjohn
My Feedback: (24)
John,
Prime time
I had called Hitec last year when I was about to buy this servo and they talked me out of it, they told me to get the 5955 instead, I can't remember why.
John
