Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Extreme Flight 87" Yak 54 - Build & Fly
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 10-24-2005, 02:24 PM
  #6251
jrjohn
My Feedback: (24)
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
ORIGINAL: Gasser Flyer
John,
Why not get the new HSR-5995TG Ultra Torque for the same price. degrees
heres the link http://www.servocity.com/html/hsr-59...ra_torque.html Looks good to me.
Prime time
At 6 volts it has the exact power and speed as the 5955.
417 oz of Torque with .12 sec/60 is only at 7 volts. I doubt your running 7 volts. I believe this is the servo they were having some trouble with (locking up) when they tried to re-program it.
john
Old 10-24-2005, 02:48 PM
  #6252
cadconversions
My Feedback: (21)
cadconversions's Avatar
Yep, the 5995tg was the servo with the trouble. It's designed to rotate 180 degrees. The 5955TG is the one you want.
Old 10-24-2005, 02:54 PM
  #6253
Prime_Time
ORIGINAL: jrjohn
John,
Prime time
john
John,
Wow, Im glad i said something then. huh, you know thats the one people are going to look at. Espicially with the same price!
Did you look at the servo power gearbox, makes me wonder. I mean all that power with the 5645 and you can get a 2:1 ratio with 336oz. estimated save probly only a few bucks. I dont know, what ever your up for doing I guess. Why not use the Composite arms they give you?
Prime Time
Old 10-24-2005, 02:58 PM
  #6254
jrjohn
My Feedback: (24)
ORIGINAL: jrjohn
John,
Prime time
john
John,
Prime Time
yes you could save a few bucks, add some weight and cut your speed in half (just guessing on the speed) Get a 5955 and be done with it
john
Old 10-24-2005, 03:02 PM
  #6255
Prime_Time
John,
But what about the composite arm the give you for the Rudder. Looks Like an awesome Arm. Any comments?
Prime Time
Old 10-24-2005, 03:13 PM
  #6256
Prime_Time
Guys
Chris is coming back home wednesday, from china. I hope he has good news about the Yak and its avuability. I hope I can have one by Janurary. My budget for all this new stuff comes around to be 1900 bucks for everything. It aint cheap for a 15 year old let me tell u.
Prime Time
Old 10-24-2005, 09:49 PM
  #6257
jdavera
Does anybody tried this airplane with an evo 58???
Old 10-25-2005, 07:24 AM
  #6258
Prime_Time
ORIGINAL: jdavera
Yea, The only plane I saw with the Evolution 58 on was the KMP Yak. If you already have the motor it will work, But the Da 50 is the best motor For the EF yak. The weight of the evo might be to much. I think the 45 evo might be better. The 58 might be over kill Im not sure. Thats what I heard. heres the link http://www.horizonhobby.com/Shop/ByC...rodID=EVOE45GX
It isnt
Old 10-25-2005, 07:35 AM
  #6259
Ricmussman
My Feedback: (24)
Last 15 Posts - reverse chronological order
jdavera Date 10/25/2005 3:49:47 AM
The 58 will be too heavy, the new 45 might be a better choice. For the money of the evo's I would just get the DA, it is the best for this plane. If you want to save money and have a great engine get the Brison 3.2. I have it and it is a great engine, not as powerful as the DA, but it still will hover the plane and pull out good.
Old 10-25-2005, 05:50 PM
  #6260
torqmeister
torqmeister's Avatar
Ricmussman, what prop are you running on your Brison 3.2? Saturday I tached mine at 7470 with a 3W 22/8. Engine has about 2 1/2 gal. through it. It is ballistic. After anoter gallon, I will go to a 23/8.
ORIGINAL: Ricmussman
Old 10-26-2005, 08:05 AM
  #6261
Ricmussman
My Feedback: (24)
I am swinging a Mej 22X8. I will tach it tonight last time I checked it was 6900, I have ran a few more gallons and I will tweak it for some more power. I tried a Mej 23X8 it was too much for it. I would like to get a Mens 23X8 or the like, the CF was just too much, wood would be better in that size. Either way it still is the best flying 50cc plane ever!!!
Old 10-26-2005, 08:23 AM
  #6262
jrjohn
My Feedback: (24)
you might want to try a 23x8 NX
john
Old 10-26-2005, 09:44 AM
  #6263
bpryor
My Feedback: (45)
bpryor's Avatar
Hi Ricmussman,
If you do that, you'll be going in the wrong direction. A Menz S is a much higher load prop than the Mejzlik. Mejzlik's are one of the lowest load props there are. If your engine won't pull a Mejzlik 23X8 in the 7000 RPM range, you have an issue. It should be turning the 22X8 in the 74-7600 range. I don't know what muffler you have, but that's the first place I'd look.
BTW, the MVVS/Evo 45 will also turn those props in the same range...with the MVVS can. It is definitely an excellent alternative to the DA.
Old 10-27-2005, 01:07 AM
  #6264
GalenB
My Feedback: (18)
Next silly question -- I have 4 slotted bases for the rudder control horns. Am I supposed to use all 4 or just 2? It's not very clear if I need them all or not...
Old 10-27-2005, 09:16 AM
  #6265
wgeffon
Sounds like you have some extras. Use two for the rudder horn.
Old 10-27-2005, 09:17 AM
  #6266
jrjohn
My Feedback: (24)
I recieved 4 as well, I only used two. (one on each side fo the rudder)
john
Old 10-29-2005, 11:13 AM
  #6267
cadconversions
My Feedback: (21)
Any word from Chris from anyone? Just curious.
Old 10-29-2005, 12:02 PM
  #6268
Maudib
My Feedback: (51)
Maudib's Avatar
I recieved 4 as well...
I used two each side. Sliding one on from the back and the other from the front. I glued the one in place then placed a little epoxy on the bottom of the second one and slid it over and down onto the first. They interleave and "hold" from both sides.... but in reality one would be just fine too...
ORIGINAL: GalenB
Old 10-29-2005, 05:42 PM
  #6269
Josey Wales
My Feedback: (61)
Josey Wales's Avatar
Whats the best way to route the elevator wires into the fuse?
Old 10-29-2005, 08:57 PM
  #6270
MSP1957
For the Tru-turn spinner (4" P-51 style) what prop shaft adapter # do i need to order? Thanks.
Michael
Old 10-29-2005, 09:06 PM
  #6271
Josey Wales
My Feedback: (61)
If using a DA-50 you dont need one..the shaft is threaded and the bolt screws in
Old 10-29-2005, 09:35 PM
  #6272
MSP1957
It is a DA 50. Thanks.
Michael
GO BLUE!
Old 10-29-2005, 10:15 PM
  #6273
MSP1957
Just checked Central Hobbies, the largest TT spinner they have is 3 1/2 (P-51). Any other places to order from for 4 inch?
Michael
Old 10-29-2005, 10:20 PM
  #6274
MSP1957
Found it on TT's web site.
Michael
Old 10-29-2005, 11:03 PM
  #6275
GalenB
My Feedback: (18)
I ordered my 3 1/2" P-51 style direct from TT. Drilled for the DA-50 and cut for Mejzlik 22X10, 23X8 and a Menz 24X8 (I am going to use a tuned pipe so I might be able to use the Menz...)
