Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Sukhoi Su26 help 72" span!!
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 02-07-2005, 07:49 PM
GeeBeeMan21
My Feedback: (110)
Default Sukhoi Su26 help 72" span!!
I bought a used Sukhoi. It has a 72" span. When i seen the pictures of it, I figured it was a Carl Goldberg. When I got it home, It is nothing like a CG sukhoi. It has alot wider fuse, thick tail surfaces. It has a complete scale outline. It has a round fuse. It is powered by a quadra-US engine 42 cc. It needs some help in the covering, but it is built very strong. It could use a new canopy and cowl. If anyone has any info on this kit, I would appricate it.
I will include some before pictures. I am doing some dressing up too it.
ID:	226234   Click image for larger version
ID:	226235   Click image for larger version
Old 02-07-2005, 09:34 PM
Bryant330L
My Feedback: (126)
Bryant330L's Avatar
Default RE: Sukhoi Su26 help 72" span!!
Ohio RC used to make a Sukhoi around this size. That is the only one that I can think of.
Old 02-08-2005, 01:13 AM
3DFanatic
I had a CG Suk and that one sure looks like a CG. What makes you think it's not?
Old 02-08-2005, 08:29 AM
GeeBeeMan21
My Feedback: (110)
I have a goldberg sukhoi that my dad built. They are nothing alike. The wing and landing gear set up is completely different. The fuse has a box construction with formers glued around the outside of the box, the entire fuse is sheet. Its not plywood like the CG sukhoi. This Su-26 is over built in about everyway. The tail surfaces are airfoiled slightly and are a 1/2 thick. They are built up and sheeted, unlike the Goldberg version. These pictures are the same pictures I seen before I bought it. I thought it was a Goldberg before I seen it in person. I will take some pictures of the two together this afternoon. Then it will be pretty obvious its not a Goldberg kit. I would say by the condition and building structor of the plane, it would be an 80's maybe early 90's kit.
I am not sure about the Ohio RC version. I seen they have a 69" and an 84". I never heard anything about a 72"? version. It might be some scratch built kit. I wondering, if i should balance near the main spar, or just go about 25% for starters? Any ideas?
Thanks, Todd
Old 02-08-2005, 06:33 PM
GeeBeeMan21
My Feedback: (110)
Alright, I am going too post some pictures. You will see a big difference in fin size, width and shape of fuse. You will also see a completely different way the wing goes on. I included a picture of the cowl. It could really use too be replaced. It looks pretty bad. The purple one, is the Carl Goldberg that my Dad built. If you recognize anything, let me know.
Thanks, Todd
ID:	226601   Click image for larger version
ID:	226602   Click image for larger version
ID:	226603   Click image for larger version
Old 02-08-2005, 09:36 PM
EXTRA ADDICT
Well I own the CG sukhoi ARF which is different from the kit built one . It has a 72 inch wingspan and the tail surfaces are airfoiled unlike the kit . The kit has flat tail surfaces that is the difference you are seeing there in your pics. The ARF comes covered in blue but someone could have re covered it. That is the best guess I can give you but goldberg is the only one I know of with a 72 inch span.
Old 02-08-2005, 09:39 PM
EXTRA ADDICT
Well sorry I am wrong the ARF has 2 piece wing. Take a look at sig or cermark it might be one of those.
Old 02-09-2005, 05:30 AM
khan
Hi
It looks like a Yellow Aircraft Suk to me.
Old 02-09-2005, 09:05 AM
GeeBeeMan21
My Feedback: (110)
Yellow aircraft has a different rear turtle deck. I will include the picture of the Yellow Sukhoi and my sukhoi. It was a good idea though.
ID:	226857   Click image for larger version
Old 03-27-2005, 07:36 PM
JRC
JRC's Avatar
sorry don't know how to delete post
Old 03-28-2005, 12:06 PM
v-snap
My Feedback: (18)
v-snap's Avatar
Not ohio RC to small..May be a sig recovered?
Old 03-28-2005, 02:53 PM
GeeBeeMan21
My Feedback: (110)
Sigs have a 78" span. Its too small for that too.
Thanks Todd
