Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Number of servos run thru Receiver?
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 04-03-2005, 05:43 AM
Chas
My Feedback: (16)
Default Number of servos run thru Receiver?
I am running 11 servos, 7 are Hi torque thru a 9 channel pcm receiver, Is this okay? Is that to much to run thru receiver ? What other way's are there to seperate power to servos? I don't want to run 2 receivers. I am running a 2700 Mah Ni-MH but will increase it soon.
Thanks.
Chuck.
Old 04-03-2005, 06:03 AM
adrian-RCU
Default RE: Number of servos run thru Receiver?
look at - power box/smartfly/emcotech - three different options of the latest technology - i use a powerbox in my ultimate
Old 04-03-2005, 06:43 AM
Chas
My Feedback: (16)
Thanks, is that a web site or do a search on RCU ?
Chuck.
Old 04-03-2005, 08:00 AM
r degen
Chuck I am using 8 Hitec digitals on my 35% extra on one 9 channel receiver , two 6volt 1700ma nicads and two separate switches and have never had a problem. Randy
Old 04-03-2005, 08:19 AM
jsm77777
Should be just fine with that set-up. That would be my limit of servo's, through one receiver. Scott
Old 04-03-2005, 08:59 AM
Hammbone
My Feedback: (309)
The plane will fly like that, but will the servos be getting all the power they need? I'm of the opinion that they won't. The RX bus has a limit on the amount of current it can carry.
Get one of the devices mentioned above (power box/smartfly/emcotech) and know that your system will work and supply the power that your servos will need.
Jim
Old 04-03-2005, 10:30 AM
Chas
My Feedback: (16)
Thanks all for the advice. I found a nice unit thru Electro-Dynamics, that will do the job, That is if I decide to use it. This project is for a Composite ARF Rookie ( Turbine Jet ) and I just deleted 2 servos in aircraft. It is a elevon wing and has 2 surfaces per wing. I see a lot of guys are bonding the 2 flying surfaces together and useing one 168 to 220 oz servo per wing.
Thanks.
Chuck.
Old 04-03-2005, 01:20 PM
adrian-RCU
some examples
ID:	253441   Click image for larger version
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
