QQ 102" Yak - Discussion and Build thread
#1051
RE: QQ 102" Yak - Discussion and Build thread
Aris, most guys on this forum that have Yaks say the the distance between the spinner back plate and the cowl lip is about 3/4 to 1 inch. If your standoffs give more than that you may want to consider cutting them off a bit.
Boby
Boby
#1052
I think longer protrusion of the spinner backplate is a good thing. Spacing the prop out allows more air to flow around the cowl and become thrust. I believe QQ said as much early in this thread. I also need the motor further forward to balance the plane with pipes and the CG location I like. Otherwise, it's a matter of aesthetics.
Dan
Dan
#1053
Hello.
Well, I was also concerned about this problem when I was building mine, but I discovered this distance is normal in a Yak.
At first, like underdw said, this is not bad, cause you get more air to flow to keep your engine cold. I even not use spinner in my Yak...
And, considering this Yak a semi-scale, take a look on this distance in a full scale plane. The pic is below...
#1054
Dear All
Many thanks for the thoughts.
I will consider them all and see what is best for my flying.
Will take some pictures of the G3.
Cheers
Cheers
#1055
Hey Guys,
Side line question here: I am about to pull the trigger on one of these 102" but needed some info, Can someone give me the measurements for the height of the plane while on the ground? I need to know ground to top of rudder? also ground to top of cowl?
Thanks, Bender
Thanks, Bender
#1056
I can give you this numbers, but I am keeping my plane in a hangar on our field. So, I need some days to go there and get it to you.
