35% TOC1 Yak54
RE: 35% TOC1 Yak54
i have the 30% - if the 35 is the same just bigger it will be awsome - this plane is pretty good at most - you can look at the video lower down in this thread(toc1 yak) - it was a little windy on the day and the engine was brand new so i did not want to TR much - best
http://www.planesandmodels.com/image...s/yak_high.wmv
RE: 35% TOC1 Yak54
I am flying the DA100 in mine and it is awesome! The plane is an IMAC stud! It is perfect for the DA100. My friend and fellow IMAC competitor has won the last 4 IMAC events we flew with his TOC1. 1st place. Good luck, go for it, you'll not be disappointed!
ten pillows
ten pillows
RE: 35% TOC1 Yak54
hey ten pillows thats good new.
What is your setup, servoes, tuned pipe or standard?
Any motor standoffs?
How wide is the cowl on the inside?
What is the vertical performance?
Would I be able to put a 32 inch prop and still get ground clearance?
thanks
thanks
RE: 35% TOC1 Yak54
ORIGINAL: My friend and fellow IMAC competitor has won the last 4 IMAC events we flew with his TOC1. 1st place.
ten pillows
ten pillows
