Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Tail Wheel Springs, What are you using?
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 06-07-2005, 09:22 AM
bob_nj
My Feedback: (62)
Default Tail Wheel Springs, What are you using?
I am looking locally at the hardware and small engine shops for those real soft and flimsy springs you might see on a tailwheel setup. Can't find exactly what I'm looking for though. I have a plane with a couple of springs about two inches long, and maybe 3/8" in diameter that are real springy and soft. They almost remind me of a mower governer or carb spring, if you know what I mean?
What are you guys using, and where are you getting them?
Pictures would be a bonus, as there are a zillion different little springie things out there [X(]
Thanks_bob
Old 06-07-2005, 09:35 AM
Geistware
My Feedback: (16)
Default RE: Tail Wheel Springs, What are you using?
Try soldering s stiff wire to the wheel assembly going straight back to the rudder then use an eyelet mounted to the rudder for the wire to go through. Works great and very stiff but flexable.
Old 06-07-2005, 09:41 AM
bob_nj
My Feedback: (62)
That's an interesting concept. Any diagrams or pictures anywhere?
Thanks_bob
Old 06-07-2005, 09:50 AM
xoon
xoon's Avatar
you mean something like a sulivan tailwheel? here is the link http://www2.towerhobbies.com/cgi-bin...?&I=LXFV48&P=K ... if you're talking about this stuff then it's great. once you use them you can't leave them, they absorb A LOT of shock when you land, that way it will prevent the back part of the fuse being ripped off
Old 06-07-2005, 09:59 AM
bob_nj
My Feedback: (62)
To be more specific, the setup is on a giant scale with a Haig style wheel assembly.
I do have one of the Sullivan units in the picture.
Maybe I can get a picture of the spring and setup when I get home.
Old 06-07-2005, 10:19 AM
rmh
rmh's Avatar
Whip on down to Harbor Freight - for a few bucks -they have a perfect spring assortment for tailwheels - I like the tightly wound 3/16" dia 2" long ones
I fasten them using big paper clip wire -rebent as needed
nice to bend and plenty strong
I am a cheap *******.
Old 06-07-2005, 10:20 AM
rmh
rmh's Avatar
Illigitimus?
Old 06-07-2005, 10:39 AM
John Murdoch
John Murdoch's Avatar
My True Value has a full drawer(s) of springs. Anything you can imagine is in one of those drawers. Some True Values' carry things that others don't. If you've got one around you, you might just want to check them out. Although, I know they're a lot more expensive than Dick's Harbor Freight idea.
Old 06-07-2005, 11:57 AM
RNick
RNick's Avatar
I got some at true value that work. I am not sure of the price but it was maybe .50 each. Cheap enough.
Randy
Old 06-07-2005, 12:04 PM
bob_nj
My Feedback: (62)
I'll have to look for a True Value around here.
Is there ever an interference issue with the paper clip rolling around on the spring?
I'll figure out something sooner or later.
Hooking to the rudder has proven to be an adventrue also.
Thanks_bob
Old 06-07-2005, 12:45 PM
jsm77777
On my Ohio Haigh style tailwheels, I've used pull-pull cables for the tailwheel steering. Once set-up properly it's way more effective than springs. Scott
Old 06-07-2005, 06:58 PM
RobT
My Feedback: (17)
RobT's Avatar
I use the pull pull cable and a spring. I get the springs at a local hardware store. I was always told not to connect the tail wheel to the rudder without a spring as it will put load directly on the servo. With a 3 servo setup I wonder if that is still an issue or a hold out from days of old.
By the way Where in NJ do you fly Giant Scale?
Rob
Old 06-07-2005, 07:03 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
The rudder servos are not designed for those shock loads felt by the tail wheel on landing. I say always use springs regardless.
Old 06-07-2005, 07:29 PM
cbk07
My Feedback: (64)
Mark Hale sells the nicest ones I have seen. My friend Bob picked these up for me a year ago at Joe Nall. A little more expensive, but worth it in my opinion. Spring works under compression so do not stretch. Mark's email should be legible in the pics. They work great. Craig
ID:	281876   Click image for larger version
ID:	281877   Click image for larger version
ID:	281878   Click image for larger version
Old 06-07-2005, 11:00 PM
RTK
RTK's Avatar
Good one Dick
ORIGINAL: dick Hanson
Illigitimus?
Old 06-08-2005, 04:21 AM
bob_nj
My Feedback: (62)
I also picked up a set from Mark at the Nall because the concept is excellent. Their are a couple of things working against me on this particular plane though. The major one is that builder didn't put any hard points or attachment devices in the rudder, and the springs in the picture won't install properly.
Another observation I had on the Hale springs is that they just seem like the servo will work very hard, and the attachment points may be strained due to the stiff spring. Just my opinion. I know they are a good product.
On two of my planes I have a similar setup as in the pictures. The springs are light and not working the servo, or straining the attachment points as much, that's all.
What I wound up doing was installing the new Haigh setup and just keeping the wheel straight with two springs that aren't attached to the rudder at all. Tried it last night, and it works great.
Thanks for the replies_bob
Old 06-08-2005, 06:46 AM
Mike3579
My Feedback: (56)
On my bigger planes I just let the tail wheel castor no springs at all and it works great
Old 06-08-2005, 08:07 AM
bob_nj
My Feedback: (62)
I thought about doing it that way Mike. Does your wheel assembly shake, rattle and roll with vibration?
I was also wondering about metal to metal contact as the Haigh is metal.
Thanks and take care_bob
Old 06-08-2005, 09:00 AM
Big_Bird
Big_Bird's Avatar
Here is a pic of a carbon fiber tail wheel assembly that friend made for me. It is light weight and very durable.
Ken
Old 06-08-2005, 09:15 AM
bob_nj
My Feedback: (62)
bigbird -> Is there any sort of shock absorbing mechanism on that set up?
As RobT pointed out, on the giant scale especially, we need springie things_bob
Old 06-08-2005, 10:28 AM
Big_Bird
Big_Bird's Avatar
Bob, it's about as springy as a CB Associates heavy duty leaf spring assembly with all of the leaves in place. In other words, fairly stiff. Of course, the tail wheel wire and tire give a little. The tiller wire back to the rudder has some spring to it.
Ken
Old 06-08-2005, 02:23 PM
rmh
rmh's Avatar
I also make my own tailwheel assemblies - this one is a semi scale YAK type ---for my YAK-oddly enough
Old 06-08-2005, 03:21 PM
bob_nj
My Feedback: (62)
The pictures are a big help.
Thanks_bob
Old 06-08-2005, 07:38 PM
Geistware
My Feedback: (16)
THis is the setup I saw with 1/2 hinge instead of an eyeloop
ORIGINAL: Big_Bird
Ken
Old 06-09-2005, 02:00 AM
bob_nj
My Feedback: (62)
Which page has the picture?
