Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Tack gluing?
Old 04-20-2006, 10:08 PM
Mr.Extra 260
Default Tack gluing?
I just started the build on my 40% edge and im not sure what tack glueing is?
Old 04-20-2006, 10:42 PM
MR G
Default RE: Tack gluing?
Tack glueing is glueing pieces with a miniscule amount of glue(Cynoacralate glue)...just enough to hold the piece where you want it. After the piece is examined and it is decided that it is correct, the piece can be glued permanently with a different glue such as epoxy or alphatic resin, or even more cynoaclralte.
I hope this helps.
Old 04-20-2006, 11:14 PM
Mr.Extra 260
Thanks! But now I have another problem! I accidently put the aluminum landing gear support in the wrong space! I epoxied it with 5 min and then realized it after it was done! Is there any way to undo or un bound epoxy? Any way to sepperate it from wood? If I cant seperate it I will have to buy a now engine box!
Old 04-20-2006, 11:26 PM
Bass1
Bass1's Avatar
Can you cut/saw out the support that you glued in? I'm not sure how your kit is setup but you could also drill many lightening holes in it and leave it. Then cut a new support plate out of whatever thickness ply/aluminum the kit calls for. Been there, done that![X(] I call it extra reinforcement.
Old 04-20-2006, 11:54 PM
rcblimppro
rcblimppro's Avatar
Heat the aluminum up with a soldering iron and it will soften the epoxy up enough for you to pop the part off.
Shawn
Old 04-21-2006, 12:13 AM
Bass1
Bass1's Avatar
The blimpman speaketh with great wisdom. Very good idea![sm=idea.gif]
Old 04-21-2006, 06:10 AM
stomper
My Feedback: (20)
Your building a 40% plane using five minute epoxy????
Old 04-21-2006, 07:48 AM
Mr.Extra 260
Thats what it called for in the kit! I was qeustioning it to. I have a soldering iron would this really work? Its a large peice of aluminum maybe 3x2
Old 04-21-2006, 08:24 AM
gboulton
My Feedback: (15)
gboulton's Avatar
I've also used a covering heat gun on an epoxied area...just heat it up, and GENTLY wiggle the part until it comes loose.
Old 04-21-2006, 08:30 AM
Mr.Extra 260
Thank you guys so much!!!! I got it of with a chizzel! thanks again problem solved!
