Sig 1/4 Scale Spacewalker II control throws
My Feedback: (38)
Can anyone help with some control throws to start with on this model? I have the plans but no instructions and they are not on the plans. I have them set for TLAR (That looks about right) but am not sure I have enough, especially on the ailerons.
My Feedback: (40)
NH
Manual says +/- 3/4" on elevators, L/R 1" on rudder, 1" up & 3/4" down on ailerons. I would consider these to be maximum throws on elevators & ailerons, and probably set up lower throws on dual rates for first flights, keep the higher throws a flick of the switch away. The aileron differential I would bet is important for good behavior in turns. Mine is still in the box, don't know when I'll get it onto the bench. Good luck with your project, should be a sweet flier.
