Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
1/4 Cap 232 Servos torque requirements.
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 07-31-2006, 01:50 PM
Hibrass
Hibrass's Avatar
Default 1/4 Cap 232 Servos torque requirements.
07/31/2006
Hello All!
I posted the message below up in the Radio support forum and didn't get much feedback...
So I'm hoping for better luck here!
Basically I'm building a Midwest Cap 232 and I'm planning on using it for a sport flyer or maybe IMAC... So I was wondering what are the control surface torque requirement so I can plan on what type of servos I'm going to use...
Thanks for any suggestions!
Hibrass
07/26/2006
Hello All!
I'm trying to determine the servo Torque requirements for my Midwest 1/4 scale Cap 232. I'm at that point were I really need to start planning for the type of servo I want to use in the build... Right now I would like to run a single Rudder and Elevator servo and one servo per Aileron...
Any suggestions will help.
Hibrass
Old 07-31-2006, 08:42 PM
jon595
Default RE: 1/4 Cap 232 Servos torque requirements.
I fly the 80" H9 Cap, basically the same size. Plane weighs about 14 lbs. It has servos with 88oz/in of torque(plastic gears), except for the rudder, it has 155 oz/in (and metal gears). You might want to look into metal gear servos all the way around. I am upgrading them as my budget allows.
Old 07-31-2006, 09:48 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
I have Hitech 5645's all around on my CAP232 1/4 scale. They work great. You want at least 100 oz-in metal gear. I prefer 150 oz-in as a minimum.
Old 07-31-2006, 10:05 PM
budgetdude
budgetdude's Avatar
I second the 5645's, great servos for the price. I have used them in a 27% and in the wings of a 35%er with excellent performance.
Old 07-31-2006, 11:05 PM
ICE_MAN
ICE_MAN's Avatar
I'm going to third the 5645's. I have them on a 34% Extra and I've leaned pretty hard on them and they've held up awesome
BTW: they're on elevators and Ailerons
Old 08-02-2006, 06:22 AM
Hibrass
Hibrass's Avatar
Hiya Guys!
Thanks for the info and suggestions!
I have a pair of 9153's laying around would they be OK on the Rudder and the other driver a split elevator pushrod setup???
Hibrass
Old 08-02-2006, 08:06 AM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
At 3 oz each where would you mount them? Seems to be enough torque, a little low to split between elevator halves, but it would work.
ORIGINAL: Hibrass
Hiya Guys!
Hibrass
Old 08-02-2006, 09:02 AM
Hibrass
Hibrass's Avatar
Joe,
I'm not sure where I will mount them yet... The plane will have a Brison 2.4 gasser so it kind of depends on how it balences out in the bones... They are heavy little monsters but strong...
Hibrass
