PAU/BME 87" Extra 330L - Build and Fly
#155
My Feedback: (21)
NY
Mine is still ok. A little bit of rust on the pushrod ends, but I am flying in very humid climate. I was just preparing everything yesterday for a new flying season and I could not find any problems. I think I am in the 4th or 5th year with this plane.
#157
The manual's suggested CG range for the model is from 5 to 6 and 1/2" from leading edge (@ root), however the wing tube's center is exactly 6 and 1/2" from leading edge. So if I started at the wing tube's center I'd already be at the most aft recommended CG setting. I don't think I've ever run into this before as usually the center of the tube/spar is right in the middle of the recommended CG range. The manual also states for IMAC, place the CG @ 5" from leading edge. Tha't a full inch and a half forward of the center of the wing tube. I'm slightly confused....
