Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Pull a 5x8 enclosed trailer with a car?
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 03-15-2007, 10:30 AM
bubbagates
My Feedback: (32)
bubbagates's Avatar
Default RE: Pull a 5x8 enclosed trailer with a car?
ORIGINAL: HeaterMan
I bet opposite rudder on the turns will help keep the rear axel on the ground!!! (:-)))))))
Well, I noticed the elevators were not on in the pic, maybe if he leaves them on and goes full up on 3D rates he could get the front of the car in the air.
Oh Dick gets some strange looks alright, but it is not because of his airplane hauling methods
I'm not gonna touch this one at all....The forum word censors would make the post look completely unreadable
Old 03-15-2007, 10:36 AM
bubbagates
My Feedback: (32)
bubbagates's Avatar
ORIGINAL: dick Hanson
I also get the question--
what if it rains?
answer
I don't fly in the rain
question
what if someone runs into you ?
answer
they get to buy a Subaru and a 42% Radiocraft
In Utah , the guy who runs into you from behind is at fault - no matter what .
In Pa it's the same way, if you are run into from behind it's automatically that persons fault unless it can be proven the brake lights were not working.
I love the answer to all the questions, especially the 3rd one
Old 03-15-2007, 11:24 AM
rmh
rmh's Avatar
off subject -
one of our remaining GOOD laws is the "failure to keep a sharp lookout" provision
so unless you are driving at night -the brake light issue is a non issue.
we did have an old farmer up north ,who let his cows wander onto a 55mph state road -and he knew it was happening
eventually , a lady hit one -at night - and the driver and cow were killed .
The farmer was held culpable because he had previous knowledge the cows could and did wander onto the road.
Old 03-15-2007, 09:51 PM
tkilwein
tkilwein's Avatar
I pulled my 5x5x12 enclosed trailer behind my 84 honda acord at sea level and 5000ft elevation with no problems other than the hills.
It would slow down to ~45-50 then. Brakes held out fine. did this for over 8 years with no problems.
Stock car, stick and brakes, the hitch i custom made to go to the center cross beam where the back axle center pivot point
was. Did not have extra oil cooler for transaxle or engine, did not overheat any time during the years of use.
I did plan on brake action a little early, it will not stop on a dime with the trailer behind. I had ~ 200lbs of tongue weight.
Old 03-16-2007, 08:15 AM
dgfick
I have a 6x10 aero-express trailer that I pull with my Maxima....works great, light weight
The guy that had it before me towed it with a 4cyl Subaru with great results.
Old 03-16-2007, 08:56 AM
  #31
Richard D Bahmann aka/Wrongway
My Feedback: (42)
Richard D Bahmann aka/Wrongway's Avatar
dgfick,
Nicde rig. do you think it might hold two 50CC's and a 100CC bird?
Old 03-16-2007, 09:16 AM
  #32
rmh
rmh's Avatar
That trailer design is great for models -first -it allows a full rear view . secondly in white it reflects heat - in early 90's I had a custom made one much like that -with double walls -and white fluted aluminum skin.
It would stay cool inside even in 100f heat and with the wheels and axle I used - trailed perfectly behind my then new 93 Sable Wagon.
  #33
dgfick
ORIGINAL: rdb127
dgfick,
With stabs off and stagger the gear it wouldn't be a problem at all. When I got it there was a wing rack that hung down. I had to pull it out because my 40% was too tall, but I bet depending how tall the 100cc was you'd be able to have the wing rack on top. With a little care 2-40% could be hauled with it. The trailer is perfect for 2-35% or combination of smaller planes. Like I said earlier this trailer is perfect for towing with a car. I would suggest though that you use those little concave passing mirrors on your side view mirrors as it is 6' wide.
Old 03-16-2007, 09:24 AM
  #34
CAPtain232
My Feedback: (40)
I too would suggest the trans cooler....consider it cheap insurance, at least cheaper than a trans rebuild or replacement
Old 03-16-2007, 09:26 AM
  #35
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Where do you get these?
ORIGINAL: dgfick
Old 03-16-2007, 09:30 AM
  #36
dgfick
I found mine used. They are few and far between though.
I'm going to send ya a PM
Old 03-16-2007, 09:55 AM
  #37
rmh
rmh's Avatar
old- stripped out Coleman camping trailers also work --lots of old crap like that around
offer to haul it off n fix it up.
Old 03-16-2007, 11:00 AM
  #38
BaldEagel
BaldEagel's Avatar
Alternativly find yourself a scrap van or estate car, cut the front off and weld in a tow bar, I did this years ago with a Austin Mini Van as it was so small I could see over the top of it form inside the car, the mini was ideal for this as it was front wheel drive and had a seperate rear subframe for the running gear so you just welded a draw bar too the subframe, I am sure there must be something suitable in the US also, just bigger.
Mike
Old 03-16-2007, 04:10 PM
  #39
ag4ever
My dad towed a 3500 pound boat with an '86 dodge caravan with a 4cyl, I am sure a newish accord could easily handle a trailer for short distances.
