Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Flex header need to wrap with teflon....help
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 05-20-2007, 01:16 AM
JEFFRO503
My Feedback: (9)
Default Flex header need to wrap with teflon....help
hey guys....I'm mounting up my BME 115 up on my 35% sukoi , and i have a set of the DA 100 ehader's with the flex. I need to wrap the flex with teflon tape of some kind so they don't leak. What teflon tape do i use? just the regular teflon stuff you get to wrap around a threaded bolt? The only kind i can find at like ace hardware is the regular plumber's tape , and it's about 3/8" wide..........will this work? Or where can i get the right stuff?
Old 05-20-2007, 05:08 AM
Supermod56
My Feedback: (36)
Default RE: Flex header need to wrap with teflon....help
That will work fine, just put about 2 layers on it, good to go
Tom
Old 05-20-2007, 05:54 AM
as722
Like tom said that 'll work fine, just remember to start and finish about an inch before and after the"flex" to avoid leaks.
Albert
Old 05-20-2007, 07:44 AM
bhanley
What, if any, glue/fastener do you use so it
doesn't unwrap???
Old 05-20-2007, 07:59 AM
ballistic1
My Feedback: (27)
No--It kinda sticks into the grooves of the flex part of the header if you pull it tight enough
Old 05-20-2007, 03:02 PM
JEFFRO503
My Feedback: (9)
OK cool guys...thank you!! Burning rubber down to the hardware store!!
Old 05-21-2007, 07:25 AM
pizza
My Feedback: (24)
pizza's Avatar
my last pair of flex headers for da100 bought from ray in Maine came with a teflon wrap but is 1-1/4" wide double wrap - wondering where a guy could get a roll of this stuff it leaked in two spots for the first few flights then sealed up nicely - over 100 flights no leakes, adjustments, etc.
Old 05-21-2007, 01:42 PM
mstroh3961
mstroh3961's Avatar
Check plumbing supply stores, not a home center item. Look in the phone book for plumbing contractors supply.
Old 05-21-2007, 02:16 PM
Hooked-On-RC
My Feedback: (16)
Hooked-On-RC's Avatar
Regular 1/2 wide teflon tape works great, wrap it twice for a double layer and after about a 100 flights you can remove it and there will be no leaks. After I put on the teflon I wrap it with aluminum foil tape that heating contractors use on household heating systems, that keeps the teflon in place and also looks a lot nicer!
Old 05-05-2011, 01:35 PM
2TALLTARY
Teflon is a great material if you need high tempature resistance and low friction. It's the best for those apps. Found some at High-Tech Plastics
They haver spec sheets and different thicknesses.
