Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Remove & replace Robart pin hinges
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 12-03-2007, 11:21 PM
RVBlack
My Feedback: (27)
Default Remove & replace Robart pin hinges
How do you remove and replace 3/16 Robart pin hinges and keep it clean?
Old 12-03-2007, 11:27 PM
Jake Ruddy
My Feedback: (40)
Jake Ruddy's Avatar
Default RE: Remove & replace Robart pin hinges
easiest way I have found is to take a very hot soldering iron and melt out the center after you have cut the surface away. Best to cut out the metal part and dril a small pilot hole so you get it straight.
Old 12-04-2007, 06:57 AM
Cobra1
My Feedback: (42)
Cobra1's Avatar
I assume the pin has been removed and the surfaces parted. I then sharpen a 3/16 brass tube, chuch it up in my drill and core it out like an apple. This has worked well for me in the past helping some friends.
Old 12-05-2007, 06:25 PM
Panzlflyer
My Feedback: (15)
Panzlflyer's Avatar
brass tube as above and gorilla glue to re install as it takes up any slack
