Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Gas Tank 50cc gas 540
Old 12-23-2007, 08:51 PM
Default Gas Tank 50cc gas 540
Where is the best place to mount a gas tank forward or aft of the wing tube for best balancing.
Old 12-23-2007, 09:18 PM
tail strike's Avatar
Default RE: Gas Tank 50cc gas 540
Forward
Old 12-23-2007, 09:43 PM
Behind COG/Tube would make flying more excicting till the gas burnt off. Weight would shift forward for better landing with the tank emptied. You probably would not be able to notice much diference either way.
Old 12-26-2007, 01:07 PM
My Feedback: (9)
I always try to position the tank over the CG. Gas engines can easily pull from a tank centered over the CG. This way, there is no change in balance from full tank to empty.
Z
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
