Setup Process
My Feedback: (16)
BC, CANADA
Setup Process
Okay I am curious as to what chain of events you guys use when you are setting up your GS planes. Your plane is already for setup, servos and engine installed, all on board equipment is installed, now you need to set throws, radio setup and whatever else you need to do, what step by step procedures do you guys use from there?
RE: Setup Process
I wrote this a while ago about setting up my Carden 260.
IMAC SET UP FOR 40% CARDEN 260
I was asked to do an article on IMAC set up in my 40% Carden 260. I’d like to start out by saying that this is purely how I do it and what works for me. The are definately different approaches to setting up a large plane for IMAC. This is just an overview of what I do. A lot of the techniques and philosophies have come to me from guys who are a lot smarter than me and have been very successful in IMAC for a long time. Peter Goldsmith and Mike McConnvile have been a huge help to me over the last couple of years. I have learned a lot from them. They subscribe to the KISS method of keeping things simple and so do I. Pete’s article on trimming a plane is very well known in the IMAC circles but in case you haven’t seen it, here’s a link. http://www.mini-iac.com/Portals/57ad...20trimming.pdf
I’ll start by listing what’s in the plane.
JR 8611A servos (8)
JR 4735 servo for throttle
JR R2000 Synthesized receiver (1)
JR Matchboxes (3)
Fromeco 4800 Mah Li-ion Packs for the RX (2)
Fromeco 2400 Mah Li-ion for ignition.
Fromeco 3 power output Regulators with Heavy duty wire and Deans connectors (2)
Fromeco single output regulator for Ignition (1)
Fromeco Badger switches for RX. (2)
JR HD Charge Switch for ignition. (1)
Electro Dynamics Fiber Optic Kill Switch.
The set up for my plane started even before the plane was being built. I knew what I wanted in a precision aircraft and because of that, some early decisions were made. The main one was that plane would not be set up at all for 3D. By not doing that, I knew I would be using short servo arms, and control horns that allow for the pivot point to be exactly over the hinge line. This allows me to get maximum servo resolution during sequence flying instead of using a very low dual rate setting for IMAC if the plane had 3D rates. It makes a huge difference in how the plane reacts and feels. I know people are thinking, the pivot point does not need to be on the hinge line. That is true but, by doing so, you do not have to use up ATV percentages to equalize travel. It makes a huge difference when its time to set the surfaces up with a throw meter.
There has been a lot of talk about where to place the control horn in relation to the servo. Some guys like the pushrod to be at 90 degrees to the hinge line while the servo is centered. I personally like to have the pushrod parallel to the side of the servo when the servo is fully deflected. When the servo is centered, there is a slight angle between the pushrod and the hinge line. I feel you have more power this way when the surface is deflected.
I bought all the linkages, servos, Pro-Links and horns prior to the build being started so everything could be planned out ahead of time. For Ailerons and Elevator this I what I came up with. I found out that placing the control horn ½†off the side of the servo case would give me a parallel pushrod at full deflection . 140% ATV on a 1“ servo arm.
For the Rudder I knew I needed a little more throw so I am using a 1-½†arm at 140% ATV. The Rudder hard points are 5/8†off of the servos side. A few discussions with Walt Beike (builder) www.builtbywalt.com about where I wanted things to go made setting the plane up after I received it a breeze. He set the servo pockets and hard points exactly where I had asked him to.
I used the new JR locking servo arms for the entire plane. The Control Horns were bought from Dubro to fit over the 8-32 horn bolts and the pushrods are Hangar Nine Pro-Links. All of these items are put together with Dubro 4-40 Ball Links.
One thing I did as the plane was being built was match the servos with JR Matchboxes on the bench. I initially looked for servos that were closest to each other without a Matchbox as far as being centered. By doing this, I was able to use less Matchbox increments to fine tune them at center. The more beeps you use to center the servos, the less end point travel you will have. (less resolution) I labeled the servos that were going to each surface and used the Matchbox to set centers. End point adjustment came later when I was adjusting throw on the surface with a meter.
I feel that some type of matching device is required to lessen wear on servo gears and not tax the batteries with servos that fight each other. Sure, you can get away without doing so but, there’s no way to fine tune enough to reduce my concerns.
Some guys use a Multi Point mix on JR Radios to accomplish this also. I know it works but I have never done it this way. (Out of laziness mostly)
The aileron Matchboxes are powered from a lead coming directly off of the Fromeco regulators. Each aileron Matchbox is powered from a separate regulator. The Rudder Matchbox is powered from the JR R2000 Receiver.
The receiver has a total of 4 power outputs coming into it from the two regulators.
When the plane arrived I started out setting up throws. Here’s an overview of what I did.
Wings:
Inboard aileron servo was adjusted by itself first. Without any adjustment I was getting 26 degrees of throw up and down at 140% on a 1†arm. I knew I wanted my maximum rate to equal 24 degrees of throw so I mechanically adjusted the horn away from the surface to lessen throw. Again, not wanting to use the Matchbox at this point. Now the throws up and down were pretty close to the desired 24 degrees. I then used the Matchbox to fine tune the inboard servo to exactly 24 degrees up and down. This was measured using the Hangar Nine digital Angle Meter.
The outboard wing servo was adjusted the same way by itself. After that, the two servos were both connected to the aileron and powered up. A little buzzing at the endpoints was adjusted away with the Matchbox. The throw was checked again and I had found that I had lost a little in total travel from 24 degrees. I then used the ATV travel for that wing to adjust both servos at the same time back up to 24 degrees up and down.
Remember me saying my ATV’s were set to 140%? Reason being is by doing so, I have more percentages above 140% to use to fine tune at this point. If I had started at 150% there would be no room to go up if needed.
The Rudder was set up pretty much the same way as the ailerons. Mechanically at first. Then tuned with the matchbox individually. Then fine tuned together with the radios ATV function.
The elevators were tuned mechanically at first then adjusted individually through the radios ATV function. No matching required since only one servo is being used on each surface.
Here’s what I wound up with at 100% Dual Rate and very close to 140% ATV on all surfaces.
25 degrees up and down on the elevators.
40 degrees left and right on the rudder.
24 degrees up and down on each aileron.
You may be wondering why 25 degrees of up and down on the elevators. I do this because I like to flip into a higher elevator rate on landing rollout. The maximum travel is needed to be set here at 100 dual rate and 140% ATV. I use another Dual Rate setting to lessen the elevators to the desired IMAC rate. It’s a little bit of give and take at this point to get that accomplished. Not a big deal.
After all this has been done I set up the 10X to have it do what I want as far as switches and Flight Modes.
I activate the Flight Modes and also use the Extra Flight mode. (Now you have 5)
Flight Mode Trim is not used. If it was, I would have to trim for each Flight Mode individually.
My rates as described above have enough movement that I can fly the entire sequence. (including snaps)
My rudder has two rates I fly the sequence on. High rate of 40 degrees (100%) for Rolling Turns and Hammerheads and a lower rate for snaps.
I use enough expo to keep it all smooth. Generally 40-50%
FM0 is IMAC rates, (low Rudder) and low idle
FM1 is IMAC rates (low Rudder) and high idle. (Ever have the motor die in a spin during a contest? Not a good thing)
This mode also has the low throttle to down elev mix on it for straight down lines. 2% to be exact on this plane.
FM2 is IMAC rates, (Low Rudder) low idle and the higher elevator rate I described above.. (Low idle here so I can flip into this rate on landing rollout and not have the throttle bump up.)
FM3 is IMAC rates on elev and ail but now activates the higher rudder for Rolling Turns and Hammerheads.
FM4 is not used but I set it the same as FM3 so if the switch gets moved to that position by mistake, the rates are what I need.
I make absolutely sure that the EXPO is set the same between modes on a particular surface so you cannot see anything change when modes are switched if I am holding stick pressure.
With this set up all I have to worry about is one switch in the sequence and only for the rollers and hammers.
I taxi out in FM2 (High elev rate and low idle) and flip to FM1 before I takeoff.
I am now ready for the sequence.
When I set up to land, I flip from FM1 to FM0. The only thing that changes is now I have a lower idle and the down elevator to throttle mix goes away.
I fly with thumbs only and do not use a neck strap so my radio is supported in the back by my four fingers on each hand. This is probably why I don’t like to flip switches when flying.
After all this its finally time to fly!
This is a good time to look over Pete’s trimming chart again and try and follow it.
My 260 felt pretty good after about 30 flights of getting used to it.
It was at this time I checked all the throws again with the Angle Meter. Stuff does change initially as the plane gets a few flights on it. A little ATV tweaking takes care of this and gets things back to where they were.
Here’s what I wound up with for mixing.
3% Up Elevator with left Rudder
2% Up Elevator with right Rudder
2% Opposite Aileron to Rudder movement.
2% Down Elevator with idle power for down line tracking.
No Aileron differential.
The Rudder to Ail and Elev mix stays on at all times. I sometimes hear this referred to as a Knife Edge mix. To me, that infers "only needed in Knife Edge" In actuality, its needed any time the rudder is deflected. Get the mix set and leave it activated at all times.
After all this, the plane flies like its on rails!
I hope this has made sense and as stated earlier.. Its not the only way to do it. Its just how I do it and what I like. Your results may vary.
Wayne Geffon
JR 8611A servos (8)
JR Matchboxes (3)
Wings:
Wayne Geffon
RE: Setup Process
Wayne,
Excellent description of methodology.
I also use early planning with my own planes. First decide what you want, then obtain what will be needed. It's far easier to set up a plane on the bench, one surface at a time, before it's attached to a plane. Your linkage geometry provides the best advantage to the servo when combined with arm lengths and horn diatances.
My Feedback: (7)
AR
RE: Setup Process
Wayne
What are your low rate settings for Rudder and Elevator. Looks like you fly the same Aileron setting for all conditions once it is set to your liking. How do you go about finding that setting.
What is your method for getting the desired rudder and elevator throws for the low rates you use during sequences flying.
Mark
Mark
My Feedback: (82)
RE: Setup Process
Great setup article Wayne.
Some things I encountered that might be slightly different:
Properly programming Hitec servos once installed, saves a tremendous time later on. This assumes your linkages and geometry and setup correctly.
Various planes have very different manufacturer throw recommendations. They are also more or less sensitive to input depending on a variety of factors. I could not find any sort of common ground between my 5 GS planes. I also find I need way more expo on 3D throws than on my IMAC settings.
The Peter Goldsmith trim sheet is the bible. Going through it again and again produces a plane that flies on rails. I keep marvelling every time I go through the procedure...
RE: Setup Process
ORIGINAL: texasporty
Wayne
Mark
Wayne
Mark
I am going from memory. Its been a while since I flew and set up that plane.
Elevator:
I think I had 11 degrees up and 12-13 down on the elevators. The reason for more down than up is because of the Mixing. The rudd to ail and elev mixes are on all the time so anytime the rudder moves I get a small amount of up elevator because of the mix. The extra throw down overcomes the up that automatically comes in with rudder deflection.
Rudder:
20 degrees or so.. Not sure.
Ailerons:
The same all the time with enough expo to keep it smooth around center. 24 degrees I think with around 45% expo.
The initial set up in degrees is a combination of a guess and what others are using.
I remember for this plane it was all really close.
All the settings are tweaked in the first few flights. I snap the plane a lot and watch what it looks like. If it looks too fast and axial, I will slow the ailerons down a little and maybe add rudder and elevator. I keep doing this until the snaps looks decent to me and others who are watching.
This is what works for me. You could fly my plane and hate the way it feels.
I fly a friend of mines planes a lot and in his hands they look extremely smooth and steady. If I fly them, they look shakey and not smooth at all. He uses a lot more throw and very little expo.
Using what others use is a good place to start and then tweak to your liking.
My Feedback: (7)
AR
RE: Setup Process
Understand it's a personal thing.
I think you also answered how you determine the proper roll, pitch and yaw characteristics of a new plane during its first flights. Sounds like you work on snaps both pos and neg to get the elevator and rudder where you want it. Then there is the a condition for rollers and hammerheads.
I like the idea of the least amount of switch flipping. But, realize some is neccassary.
Super post and thanks for the quick response.
RE: Setup Process
Mark,
I dont use a neckstrap and fly with thumbs only so for me, flipping switches kinda sucks so I try to minimize it.
The 260 needed that higher rudder rate for rollers and hammers.
Last season I flew a Carden 300 and found out late in the season that I could get away with no switching at all. I used a slightly higher rudder rate than on my 260 and used a tad bit more expo.
The increased side area of the 300 is why I am sure.
Heres some shots of both planes.
The 260 has the single place canopy and the 300 has the two place.
I still have the 300 but sold the 260 to a buddy of mine a few months ago.
My Feedback: (62)
NJ
RE: Setup Process
Here's what I go over when I pick up a used plane that I neither built, nor set up.
Recently did this where the seller downloaded his 10x to mine to save me radio set up time.
ENGINE -> Check head, backplate, carb, and muffler bolts. Install ignition cut off switch and set failsafe on the transmitter.
Check the timing against manufacturers recommendations. Balance prop(s) laterally and hub. Clean and gap spark plug. Get carb model and note rebuild and diaphram kit numbers for future reference. While the cowl is off, run throttle ATV to maximum. Move servo linkage as far in on output gear, and as far out on the carb as possible. Adjust linkage to use full range of servo travel.
Note direction of choke ON/OFF for future reference. Check and adjust up and right thrust if needed.
Note needle settings where motor was run and adjust from there at the field. This gives an idea of actual versus recommended, and again is for future reference. I put split tubing over any ignition wires that are laying on, or going through wood to reduce the risk of vibration chewing through the wire.
BATTERIES -> I keep an excel sheet on all of my batteries since the old memory isn't what it used to be. Cycle igntion and Rx batteries and compare present capacity to new. I use a C10 rate to charge. Peaking isn't what I want here.
LANDING GGear -> Check and tighten gear bolts and wheel collars. Note any wrinkles in covering present from any less than perfect landings.
TANK -> Always, always check the lines inside the tank. The one I just looked at was so stiff that the
line didn't move to the top of the tank when inverted. I also use a brake pump to pressurize the tank and check for leaks.
I also put a label on the tank noting when the lines were changed last.
SET UP -> Again I run the ATV's all the way up and check up and down throws on all surfaces. Remove any trim and sub trim in the transmitter. Adjust to recommended, or whatever suits you. This may take some time as some servo arms need to replaced if you don't have programmables, and some linkages need to be lengthened/shortened or moved in or out on the servo spline accordingly. Use throw meters to get desired results.
I use the Central Hobbies meters for deflections up to 45°, and the Aeroperfect digital meter for some others.
INCIDENCE -> Check Incidence and decalage. Again, you may be surprised at what some guys compensate for. Also note any trim that may have been in the surfaces and try to determine why it's there. Seal your hingle lines. Some guys don't bother with the rudder, but I do it anyway.
CG -> Check to see where you stand. You may be a precision flyer and it's at the 3D mark, or vice versa.
CG with spinner on and off. Maybe you can switch between the two without having to add weight.
Weigh the plane if possible to give you an idea how it compares to others.
Whewwww, that was easy [X(]
