Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Lanier Extra 330 94" ARF
Old 05-18-2008, 12:02 PM
  #301
My Feedback: (12)
Default RE: Lanier Extra 330 94" ARF
I do have a sugestion, this engines are powerfull, do you going to fiberglass the corners or put a aluminum channel, this engine's are bad to the bone, and can pull away your firewall.
Old 05-18-2008, 07:57 PM
  #302
tkilwein's Avatar
ORIGINAL: telejojo
how do get to the needle valves? I used 1 1/4 wood dowels. I might make a mount like yours on my next one but I don't have a milling mach. I wonder if a router will work.
Took less than 5 minutes to make with the mill, a router should work fine just take a little longer. With a mill you can get all the entire surfaces true and parallel.
I have a notch midway for the needles. see picture.
Maxum, I glass the three box sides and added triangle stock on the bottom in the back, side already done. Glass can be seen in one of the pictures, I lightly roughed up the wood so the epoxy would stick better hopefully.
I have seen a 3w150 rip the nose off, made a mess of everything up front. The 90 degree triangle aluminum stock would probably be better.
Picture of it almost finished, missing wheel pants but they are going to stay off for a few flights. They are done just need to mount them.
ID:	952195   Click image for larger version
ID:	952196   Click image for larger version
Old 05-19-2008, 03:32 PM
  #303
badfish's Avatar
the firewall is pinned on the sides. I'll probably pin the top and bottom also. that should be plenty.
Old 05-19-2008, 03:37 PM
  #304
My Feedback: (12)
No Pin's will not stop the fire wall from snap off is a false sense of security, you need to fiberglass or reinforce the firewall,or you will regret it, I am a inspector of aircraft maintenance and Iam tell you if you are lucky you will loose the airplane if not you may loose your hands, don't take a chanse. The only thing we can do in this forum is give advise you do what you think is best. Good Luck.
this is my Lanier with a 100 CC ZDZ
http://www.youtube.com/watch?v=AJKhDxKuTvc
Old 05-22-2008, 08:55 PM
  #305
My Feedback: (42)
Richard D Bahmann aka/Wrongway's Avatar
Anybody need a 3W80XI to power this frame? I just put my NIB in the marketplace with side muffler, engine mount, ignition and spinner for a pretty fair deal. I put an identical engine on my brothers 95 inch yak and it had great power to 3D it well.
Lost my job and need money to insure a roof over the house.
R
Old 05-23-2008, 06:29 AM
  #306
badfish's Avatar
sorry to hear your bad news rich. hope everything works out for you.
steve.
Old 05-23-2008, 06:33 AM
  #307
My Feedback: (12)
Rich offer this power plant in the forum for the Lanier Yak54 87" this is the right engine for that airframe, sorry for you job, hope you find one soon and with better pay. Monty.
Old 05-23-2008, 09:28 AM
  #308
My Feedback: (42)
Thanks guys. I am optimistic and will keep flying too!
Old 05-23-2008, 10:17 AM
  #309
ORIGINAL: Richard D Bahmann aka/Wrongway
Great attitude! Bummer about the job. I guess it was time for something better. Chin up, Live, Fly.
Steve
Old 05-25-2008, 08:29 AM
  #310
theo63's Avatar
WARNING WARNING,,,as talked about the firewall if you do not add something to the firewall it will come apart
mine did and i was very lucky i have a da85 on mine and it was about the 8th flight and i started it up and was about to taxi out and i noticed the spinner move oh so slightly and i shut it down thought the spinner was lose,but it was not,the left side of the firewall was seperated and the factory pins was broke,wow after i tore it apart i noticed the pins for the firewall was not even hardwood
i have just fixed the problem i used carbon pins and i also added aluminum corner stock around the firewall and bolted in and re epoxy the whole front end
i am going out today to fly it again and it should be rock solid,i just want all to know that you better fix this area i got really lucky and i do not want anybody to get hurt or loose the plane for this reason,,i will take pictures of the repair if anyone wants to see it steve
Old 05-25-2008, 08:43 AM
  #311
AirWizard's Avatar
Steve
I'm mounting my DA85 and would like to see some pics of your fix
Old 05-25-2008, 09:24 AM
  #312
My Feedback: (12)
The fire wall and all gas planes need to be beefup, I fiber glass mine in my edge, but if it come lossed I will fiberglass and add the aluminum corner is a must, he is right do not risk you plane or yourself. this is a video of the second flight of my Lanier edge 94", I thing that the extra may flight even better, with this plane is not coupling at all in knife edge.
Enjoy.
http://www.youtube.com/watch?v=MHcfyl6hnN0
Old 05-25-2008, 09:43 PM
  #313
My Feedback: (20)
frieshoo's Avatar
ORIGINAL: maxun
Enjoy.
LOL!!!
Why are you flying at 1/2 and above with the 100cc twin on this ARF????
I wonder why the firewall came apart..[X(]
This is a 21lb airframe, and you are putting a 35% engine on it... and flying it like a Four Star 60.
I have 20 flights on this edge... zdz80 turning a vess 27a 6300... Mostly 3D.. but can handle Advance IMAC...
Old 05-26-2008, 01:05 PM
  #314
AirWizard's Avatar
I pinned the the firewall with carbon fiber rods and plan on using alum angle for the corners.
Old 05-26-2008, 05:58 PM
  #315
My Feedback: (12)
Can we keep this conversation in the lanier edge treat, thanks for the extra guy's if the edge do this imaginate you beautiful extra what can do. Last video
2 Parts.
http://www.youtube.com/watch?v=_Ib2og9h7i4
http://www.youtube.com/watch?v=fmGlCY-TK2I
Old 05-27-2008, 07:31 AM
  #316
My Feedback: (29)
LearnedInUk's Avatar
ORIGINAL: maxun
Can we keep this conversation in the lanier edge thread
I think you have your threads confused... Maybe you can post your Edge stuff here maxun [link]http://www.rcuniverse.com/forum/m_6835033/mpage_40/tm.htm[/link]
Anyone have the EXTRA flying yet or have any build pointers/pitfalls?
Old 05-27-2008, 08:36 AM
  #317
AirWizard's Avatar
I'm getting close.
Old 05-27-2008, 08:51 AM
  #318
theo63's Avatar
Airwizard here is the picture you ask for
here is also a picture of mine ready dor another flight,and a list of things i had problems with
get rid of the supplied fuel tank the stopper will come out and its junk the lip is not big enough on the tank
the cowl mounts needs reinforced and i used 3 small pieces if hardwood and they are not glued in well
also the canopy mounts need more glue as well as they will come out
i have about 8 flights on mine and it is a sweet flying plane so far just need to work all the bugs out
ID:	958019   Click image for larger version
Old 05-27-2008, 09:15 AM
  #319
My Feedback: (29)
Thanks theo63 that's the kind of info I was looking for. I should be starting mine in the next few weeks. I still need to pickup some batteries, servo arms, switches and extensions. Then i am set to go.
What kind of servos did you use? I picked up some of the HD servos when Troy built had them on sale. I don't fly 3d just IMAC so i don't need overkill on the servos.
I wanted to change the tanks out to the round kind with the screw on lid. I have seen them in planes but i can't recall where to get them.
I noticed when I inspected it that the cowl mounts looked suspect as well as the overall fit of the canopy hatch. Looks like it will need some reinforcement.
Did anyone do anything with the cockpit area? If so can I see some pics please.
Thanks!
Old 05-27-2008, 11:45 AM
  #320
theo63's Avatar
i have 5985 hitechs all the way around exept throttle and choke servo
here is the front of the plane for the guy that pm me about the front
Old 05-27-2008, 12:58 PM
  #321
AirWizard's Avatar
Steve.
Did you just reglue the cowl and deck mount points or did you modify them?
Old 05-27-2008, 01:02 PM
  #322
theo63's Avatar
i just reglued the deck mounts they hardly had any glue in them but for the cowl i just epoxied in some hardwood in 3 places,if you look at the picture you can see them not much but you will get the idea,they are really solid now and its had about 5 flights on it since i did that and they are good to go
Old 05-27-2008, 01:11 PM
  #323
AirWizard's Avatar
Have you had any problems with the plastic inserts?
Old 05-27-2008, 02:42 PM
  #324
theo63's Avatar
no they have been good so far,just the wood that in my opion just did not get glued in enough
Old 05-28-2008, 08:09 PM
  #325
AirWizard's Avatar
I got 2 flights on mine tonight.....took 2 clicks of up and it was tracking straight and level. I'm very happy with the plane it is very stable and flew where I pointed it and would be great for IMAC. Didn't get a chance to try any 3D yet maybe next time.
I fly off grass and the tires came off the rims so I'll change them out. Everything else worked great.
Nice Plane!!!!!!!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
