Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Lanier Extra 330 94" ARF
Old 08-17-2009, 08:17 PM
  #376
wrcflyer
My Feedback: (24)
Default RE: Lanier Extra 330 94
greatone - i had no problems with the 330 - it is a great flyer - like the best plane i ever had - i hit a barbed wire fence - the wing is like a chainsaw hit it - the wing can be repaired - but if i can a wing i would go that way - i am using a g-62 in my 330 it fly great for me - thanks for the interest - bill -wrcflyer
Old 08-18-2009, 10:23 AM
  #377
GreaTOne_65
Sorry to hear about your accident. The reason I was being nosiy was if there was an issue that guys still flying that plane would have a heads up. Finding another wing will probably be a chore, as they sold every one they had. I just wish I had know the plane was going to be that good, I would have bought a dozen!!LOL!!
Thanks for the reply, hope something works out.
BTW: As and aside, I had a GP Christen Eagle, that I mangled up pretty good, both wings and a small amount of fuselage damage, and I rebuilt that, recut the feathers and all. It took me nearly as long to cut the feathers as it did to rebuild the plane! So it can be done! Good Luck.
Dale
Old 08-19-2009, 10:04 AM
  #378
LearnedInUk
My Feedback: (29)
LearnedInUk's Avatar
I need a rudder if anyone comes across one. mine is still warped.
Old 08-19-2009, 05:51 PM
  #379
GreaTOne_65
Hey, learned, I'm sure you have already tried it, but sometimes if you put pressure on the top and bottom, and then heat the covering, on either side, you can make the covering pull the warp out? Sorry if this has already been tried, or you have been advised about this before. I have a flying friend that found the wing on a giant Ugly Stick was warped and that was how he took the warp out.
Old 08-19-2009, 06:06 PM
  #380
LearnedInUk
My Feedback: (29)
Yep it worked great for about 90% of it. I even removed all the covering and soaked the wood with a water solution and left it sandwiched between two boards i got 75% of the warp out that way. Then recovered and shrunk carefully that got about 15% more out. I still fly it with 10% screwed up and once I trimed the rudder it is not a big deal. But it's not perfect.
Even with the screwed up rudder I still love flying it. It is a blast!
Old 08-19-2009, 06:30 PM
  #381
GreaTOne_65
Sounds like you've done about all that can be done, short of building a new one. Have you given that any thought? It wouldn't be that hard, considering you have a pattern. This comes from a man who has built a lot of scratch built planes, it's not that difficult. Like you I have a little streak of perfection in my genes!!LOL!!
Old 08-19-2009, 06:55 PM
  #382
LearnedInUk
My Feedback: (29)
Yes, I did consider it. But I can't build worth a crap! I do have a guy at the field that is a great scratch builder. I think I will ask him to make me a new one over the winter.
Old 08-19-2009, 07:22 PM
  #383
GreaTOne_65
Sounds like a plan to me. The hardest thing will be to replace the covering, even that too can be done, with a little patience.
Good luck, it is a good flying plane.
Dale
Old 01-12-2010, 08:39 AM
  #384
kochj
I still haven't had time to put mine together... but I have advice on how to get rid of the warp....
If it is the trailing edge...... Cut a goove with a Dremel down the legth of the warp....
1. place a carbon rod in the groove for fitment
2. mix with some gorilla glue
3. place back into groove and frame it up with some wax paper on glued side and wood on both sides
4. place 2 or more clamps on the wood frame and squeeze untill flat...
5. let dry overnight..
6 sand out extra glue, and cover with a balsa filler or a thin sheet of balsa... done
You could cover the hole with a sheet of balsa (cut to fit) proir to clamping, that would save quite a bit of time...
Good luck..
Justin
Old 03-07-2015, 04:51 AM
  #385
jetmek2009
Ha guys i know this is a old post but i need some help!
I just got the laneir 94" extra 330 with no manual.
I really thinck it is learnedinuk old plane! Due to pics of pilot.
Need some help with CG and throws.thanks!
Old 03-07-2015, 06:21 AM
  #386
computermonkey
My Feedback: (90)
opps thats the 84 in
File Type: pdf
Old 03-07-2015, 06:26 AM
  #387
computermonkey
My Feedback: (90)
might be able to find the instructions here have to search through the list or if you know the part number
http://manuals.hobbico.com/lan/
Old 09-02-2015, 02:56 AM
  #388
itizme_ca
I have manual, pic from just now
Great plane, wish I had spares
Name:	94 Extra.jpg
Old 07-08-2022, 08:54 PM
  #389
AAMULK
I just acquired one of these and it was missing the manual. Any chance of getting a copy of yours. I have the manual for the 94" Yak but, I'm not sure it is the same.
Old 07-09-2022, 06:00 AM
  #390
itizme_ca
Gave to the guy that bought her a few years ago. That "lana9072" a few posts above is close enough
