Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
 Sig Extra 300 & DZY 48 Twin >
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 12-15-2008, 03:23 PM
My Feedback: (9)
Flexnbeef's Avatar
Default Sig Extra 300 & DZY 48 Twin
I just finished coaxing a DZY 48 twin into my Sig Extra. Why do I need them darn spark plugs anyway[sm=lol.gif] I hated cutting the cowl [sm=cry_smile.gif]but I don't think it looks to bad. It's only money.....
ID:	1090230   Click image for larger version
ID:	1090231   Click image for larger version
ID:	1090232   Click image for larger version
ID:	1090233   Click image for larger version
Old 12-15-2008, 03:38 PM
My Feedback: (31)
Default RE: Sig Extra 300 & DZY 48 Twin
wow i had one of these back in the day with a satio 180 to heavy for the 180 on glow it doesn't look bad at all
Old 12-15-2008, 03:58 PM
My Feedback: (9)
Flexnbeef's Avatar
I got the plane and the engine super cheap. I have to get the batteries and one servo for the rudder then I can get an idea of the wing load ..I hear these planes are on the heavy side but this motor is pretty light so I don't think it will be to bad. I just want it for a good sport plane anyway.
Old 12-15-2008, 05:14 PM
My Feedback: (31)
mine was around 12.5 to 13lbs if i am recalling correctly it flew very nice by todays standard it carries small elevator halves. knife edge was great [8D]
Old 12-15-2008, 05:25 PM
My Feedback: (54)
Steve's Avatar
Wow, thats a tight fit!! CC wise it should be a good match if its light. I put a G45 in mine and it was a little on the porky side. It flew good, but as krayzc said, the elevators are a bit small for 3D stuff.
Old 12-15-2008, 05:38 PM
My Feedback: (31)
Flex now thinking about it you should rebuild those halves larger and then you will love that plane even more
Old 12-15-2008, 11:32 PM
My Feedback: (21)
mrbigg's Avatar
Looking good Beef! Looks better than we thought it would. Do as Krazy says and enlarge them elevators. You ain't got nothing to do anyway but build.
Old 12-20-2008, 09:56 PM
My Feedback: (9)
Flexnbeef's Avatar
Fired up the twin today and it ran great...
Old 12-20-2008, 10:20 PM
My Feedback: (31)
That's Great!
Old 12-20-2008, 11:02 PM
My Feedback: (9)
T. Bob's Avatar
Great IMAC plane not much for 3-D
Old 12-21-2008, 07:20 AM
My Feedback: (9)
Flexnbeef's Avatar
That's ok with me I got my other planes for 3d.. Going to get a some batteries for my digital scale today so I can get an idea of the weight. Couldn't get a rpm reading because I was in the basement and the lights screw up the reading. I'll get it out in the yard when this weather breaks..We are in a cold snap right now...
Old 03-06-2009, 05:53 PM
My Feedback: (9)
Flexnbeef's Avatar
Well I took her up for the maiden flight today and she flew great , only a click of up and right and she was hands off.. A tad bit nose heavy but not enough to worry about on a maiden. Great nife edge and killer blenders , it did have a bad tendency to snap and roll over in a heartbeat when pushing the rate a bit, I don't like that disconnected feeling when the plane is wollering around after a movement . She Weighed in at 14.2 lbs. I think it would have been a much better flyer at 12 or so lbs . The DZY 48 Twin ran great and had plenty of power for this airframe and was about 4 ozs lighter than the Firstplace engine that they suggest so I don't know how you could shave more weight with a gas setup. A well built plane, That wing by itself was 3.2 lbs. Got about eight or so great flights on her then she went into a stall spin out above the corn field and hit the deck ............. Looking back I probably could have prevented it if I had dailed the rates back a bit. The airframe was the only loss, thankfully the soft field helped save everything else. Oh well !! on to the next one..
ID:	1151667   Click image for larger version
ID:	1151668   Click image for larger version
Old 03-07-2009, 09:07 AM
My Feedback: (21)
mrbigg's Avatar
Low and no where to go.............
Old 03-09-2009, 10:21 AM
flygilmore's Avatar
.....Or the power to get out of it
Old 03-09-2009, 04:11 PM
My Feedback: (9)
Flexnbeef's Avatar
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
