Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Mini Smoke System
Old 02-25-2009, 09:07 AM
Default Mini Smoke System
Am in the process of installing a smoke system in my SU26 50cc. I thought that the pump that I am using may be of some interest to you guys especially if you are inolved in a weight saving exercise. It weighs less than 0.5 ozs. and consumes 0.2 amps @6v.
I have bench run the system and it woks well using water based smoke fluid, 5 x AAA battery pack and a very low cost speed controller.
Here are some pics.
Mike.
Ooops !! 2 too many, sorry.
ID:	1144443   Click image for larger version
ID:	1144444   Click image for larger version
ID:	1144445   Click image for larger version
Old 02-25-2009, 10:37 AM
bonedaddy41's Avatar
Default RE: Mini Smoke System
Hi Mike. Keep us updated. I will be interested to know how it works out.
I do have a couple of questions.
What "water based" smoke fluid are you using?
Is that glow fuel tubing? I have always had to use hi-temp neoprene tubing between the exhaust connection and the check valve.
Old 02-25-2009, 11:50 AM
RTK
RTK's Avatar
Mike, where do we find one of these little jewels??
Old 02-25-2009, 12:25 PM
Hi
The tubing is silicon for glow fuels, I have used this because the fluid is water based and it is also high temp so that it will not suffer being connected directly to the
Zimmerman cannister smoke nipple.
The smoke fluid is Glycol based which produces smoke that has no residue or detrimental effects on our model finishes. Also, we are able to get it to produce colours other than white.
Will get some pics when the plane is flown but I have 3 or 4 weeks work left to do.
Hope this helps.
Mike.
Old 02-25-2009, 12:30 PM
Sorry, forgot to say where the pump came from.
www.micropumps.co.uk
I have used the M200-P4 which has electronic supression built in.
Mike.
Old 02-25-2009, 04:59 PM
dragnbye's Avatar
wow that a nice little pump. can you set a mix to ?
Old 02-25-2009, 06:40 PM
Nice but how do we get them over here for a cheaper price??? It would cost over $100USD to buy and ship here...
Old 02-25-2009, 09:39 PM
dragnbye's Avatar
$100 you can buy a slim line for 70 anyone know of a us dealer?
Old 02-25-2009, 11:35 PM
Don't know that I'd want to use a glycol based smoke fluid. Some of them are nasty. Based on about 6 different MSDS sheets for various glycol products about the only safe one is propylene glycol. Breath enough f that and you'd still be stuck sitting on the crapper for awhile.
However, I am curious as to how that pupm would work out with Super Dri. It's a lot more viscous than water and requires a pretty good pump.
Old 03-01-2009, 11:48 AM
I noticed you mentioned being able to produce different colors of smoke other than white. Please let us know how that turns out !! If other colors are possible, this will be a fantastic invention for a gas eng !! As far as I know, only a turbine eng. is possible to produce colored smoke !!
Thanks !!
John
Old 03-02-2009, 02:42 AM
Hello John
Fluid is available here to produce red,blue,green and yellow smoke, but there is a downside.
The powerful colourants used tend to cause unacceptable levels of staining to all that the smoke contacts making it very difficult to remove.
We also have various fruit "flavours", that can be added to water based smoke fluids to make the smoke smell very pleasant !!
Mike.
Old 03-02-2009, 11:52 AM
Thanks Mike ! That is very interesting to know about the colored smoke now !! I hope they develope more technology to make it more user friendly or at least where we can use this somehow. That's very encouraging news & keep us posted on your progress !!
Thanks again !!
John
Old 04-03-2009, 12:25 PM
Bill Martins's Avatar
Mike I PM'd you.
Bill
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
